This thread is privately moderated by Pontus Claesson, who may elect to delete unwanted replies.
Old Sep 23, 2009, 01:51 PM
joenella is offline
Find More Posts by joenella
Joined Jun 2009
Hi.
If you ganna make 11S2P I'm afraid you will ruin your lipo's.
I don't think it is wise to make 2P with different capacity of the lipo, the 3350 wil be empty before the 3800, this means the 3800 try to charge the 3350 and that's an bad idea!
Just a small warning, I hope I'm wrong but not sure.
joenella is offline Find More Posts by joenella
Old Sep 23, 2009, 02:26 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Originally Posted by joenella
Hi.
I think you are misunderstanding his setup. He is using the two different capacities in parrallel to make a larger capacity 6S pack. He is then doing the same to make the larger capacity 5S pack. Both 5S & 6S packs will be 7150mAh. He is then hooking these two identical-capacity packs together in series to make an 11S-7150mAh battery.
chalmrast is offline Find More Posts by chalmrast
Old Sep 23, 2009, 02:39 PM
Pontus Claesson is offline
Find More Posts by Pontus Claesson
Pontus Claesson's Avatar
Sweden
Joined Dec 2003
Paralleling different capacities....
Hi.
Thank you for your concern joenella!
In fact, there is no, or very small risk, with connecting and using different capacities in parallel as long as it is the same type of cells (chemistry, brand, age etc).
Another precaution is to see to that all cells/packs get reasonable equal cooling.
What happens when paralleling is that the cells are forced to have the same voltage.
Because of that, they will each charge/discharge at the same C-rate too.
The small risk is if the Ri of the different cells sizes are very far away of being proportional to their capacity.
If a very high continuous C-rate discharge is applied
and the lower capacity cell also happens to have the lowest
Ri, it will deliver more amps. However, in practical use, there are 2 mechanisms that compensate for this potential problem:
1. In almost all cases, there are very varying loads on the battery during a fligh. In low C passes, the parallel cells will balance out.
2. As both Ri and cell voltage drops during discharge, the cell that eventually has lost a little more capacity will deliver less amps until balance is restored.
I will always keep all cells groups parallel over the balancing connectors of course.
Pontus Claesson is offline Find More Posts by Pontus Claesson
Old Sep 23, 2009, 02:45 PM
Sweden
Joined Dec 2003
config
Old Sep 30, 2009, 06:39 AM
Jocke is offline
Find More Posts by Jocke
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
Very nice build Pontus, good to see you have come such long way already, cant whait to see this bird in action!
Jocke is offline Find More Posts by Jocke
Old Oct 04, 2009, 01:24 PM
Sweden
Joined Dec 2003
Motor fitting
Some more progress on the motor mount, see picture texts.
Sorry for the poor image quality, again I only had my phone camera at hand...
Weight of the cowl as it is right now is 460 gr. So I have added 190 gr and will need 4 pcs 25 mm long stand off's to final the motor mounting.
The 375 gr of motor dome is not needed any longer. If I had used it, I've had to add about 150 mm long stand off's or so.
I think the weight saving is well over 200 gr.
Last edited by Pontus Claesson; Oct 04, 2009 at 01:51 PM. Reason: Adding weight info
Old Oct 05, 2009, 07:08 AM
Sweden
Joined Dec 2003
Strength of motor mount
Have made a calculation of what kind of forces or moment loads that will appear on the motor mount at extreme manouvers like full power snaps etc. Found out that a bending moment of up to 10 Nm is definitely a level that should be possible to resist (prefferable with a good margin)
Anyone that have some rule of thumb about this?
Old Oct 15, 2009, 05:54 PM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
Pontus - This is a really fantastic aircraft. I am realy keen to watch the progress. Its always a really pleasure to watch a GS Elrectric take shape by someone who knows what there doing. Best of luck from us Australian GS flyers !!
OzparkPilot is offline Find More Posts by OzparkPilot
Old Oct 16, 2009, 09:02 AM
Sweden
Joined Dec 2003
Thank you BingWing!
The build is ongoing but at the moment mostly the more main stream activties like servo installtion etc. Waiting for some parts needed for the battery installation, then there will be more posts and pictures again, stay tunded!
Old Oct 18, 2009, 05:17 PM
Watts up ?
Joined Nov 2006
will do !
Old Dec 07, 2009, 12:00 PM
Sweden
Joined Dec 2003
Battery tray
Have started to make battery trays.
Will tie the packs down and also secure with velcro.
Steel pin in front edge will give vertical support, dowels with pins will
lock in rear in all directions.
Old Dec 07, 2009, 12:04 PM
Sweden
Joined Dec 2003
Unusual solution again
Have put ring solder ends on all batterys.
Will make all power inteconnections with three pole screws.
Old Dec 07, 2009, 12:12 PM
Sweden
Joined Dec 2003
Servo cradle
Made my own rudder servo cradle with help of some part from a brushless motor.
Old Dec 07, 2009, 12:15 PM
Sweden
Joined Dec 2003
Landing gears
Do NOT like the landing gear legs included (for sale!)
My own construction are now baking in the owen.
Will weigh about 100 gr less and be flexible and somewhat higher (in case I want to test a 28" prop)
Old Mar 11, 2010, 09:55 AM
Sweden
Joined Dec 2003
Finnished but not flown yet!
Sorry I left you guys, I continnued the story "back home"
You can watch if you want here:
http://mini-iac.se/forum/topic.asp?T...34&whichpage=7
For Sale 1/4 Scale 80" CMP Extra 330L Electric flyrobert Aircraft - Electric - Airplanes (FS/W) 0 Dec 12, 2008 10:26 PM
Wattage Extra 330L ARF , Like New BrandoUno Aircraft - Electric - Airplanes (FS/W) 7 Dec 14, 2002 05:07 PM
NIB Wattage Extra 330L ARF mickydee Aircraft - Electric - Airplanes (FS/W) 1 Dec 07, 2002 01:55 PM
Anyone have the Wattage Extra 330L EP ARF mefly2 Parkflyers 1 Aug 03, 2002 05:42 PM
Anyone seen this Extra 330L ARF? cenman Electric Plane Talk 2 Sep 06, 2001 07:39 PM
