Old Sep 07, 2009, 02:21 PM
Senor Jack is offline
Find More Posts by Senor Jack
Senor Jack's Avatar
United States, AZ, Yuma
Joined Jul 2006
Determining the Center of Gravity
In order for an airplane to fly correctly, you NEED to determine the CG ( or Center of Gravity) of that airplane & then add weight accordingly to the NOSE or TAIL to get it perfectly balanced, thus, increasing your chances for a successful flight. ( I use to term PERFECTLY very loosely, since NOTHING in this world is PERFECT, except, according to my wife, HER... )
Now you can go and buy something if you have lots of money to burn, but to be honest with you, I would rather put my money into my airplane(s). Wouldn't you ?
So I am posting this "TIP" for making your own little "JIG" to determine where the CG is on ANY given airplane.
First you need a hook of some sort... ( I used a simple "Eye" bolt) and then you need 3 (three) pieces of string. ( I used some left over Venetian Blinds cord).
And you need some sort of "PENDULUM"
Make sure that the 2 of the cords are the same length, make a SLING from both pieces of cord & fasten them to the "Hook" to make 2 "Slings" to hold the airplane.
Load your airplane with EVERYTHING you would like you were getting ready for TAKE-OFF to fly it. (I.E. Battery, ESC, etc.)
Next, place the FIRST sling around the FRONT body of the plane. (In FRONT of the WING.)
Then place the 2nd sling BEHIND the WING. ( See Photo).
You can "Eyeball" it to make sure it is level Parallel to the floor, but I suggest using a small level on the top of the wing to make dead sure that it is level BOTH ways. (Front to Back and Side to Side)
If your wing is FLAT, all the better but if it is CURVED, then you MUST put the Level on the HIGHEST point of the CURVE to make sure it is level.
Once you have it level, then hang the Pendulum from the SAME HOOK as the SLINGS and let it stop swinging. ( I used a pair of TWEEZERS because it had a POINT that showed me the EXACT CG on the wing).
Viola !! Now you know where the CG is of your airplane !
In my case, I have a Skyartec Cessna 182 and they give NO MENTION of the CG in the manual. I determined it to be 55-56 mm from the “Notch” on the LEADING Edge of the wing. (See Picture)
I believe in DOUBLE-CHECKING even if they DID give a CG, just to make sure that the CG is correct.
I hope this helps someone!
Senor Jack is offline Find More Posts by Senor Jack
Old Nov 03, 2009, 09:28 AM
jaav is offline
Find More Posts by jaav
Cptn Blinky Broome West Aust
Australia, WA, Cable Beach
Joined Aug 2007
Thanks Ill give it a try..
jaav is offline Find More Posts by jaav
Center of gravity byebyeplane Beginner Training Area (Aircraft-Electric) 20 Jun 03, 2008 03:13 PM
Center of Gravity cenman Electric Plane Talk 4 Jul 17, 2001 08:35 AM
What is the center of gravity for the IFO? spy0o7 Electric Plane Talk 3 Jun 20, 2001 10:02 AM
Full Fuse stik center of Gravity Problems. kist2001 Parkflyers 3 May 30, 2001 03:45 PM
How do you determine the Center of Gravity?? Dandi6065 Parkflyers 8 May 07, 2001 04:44 PM
