Old Sep 05, 2009, 06:25 PM
flyguide7 is offline
Find More Posts by flyguide7
Planes, need more planes
flyguide7's Avatar
United States, MO, Chesterfield
Joined Feb 2006
Another Falcon 120 Twin EDF
Well after seeing Knife Liddle's incredible Falcon 120 wing conversion I decided to have a go at it. Since I am not a man on significant means I am going with Knifes latest set-up using ARC 36-75-1t motors, midi fans and Turnigy 100 HV speed controls. I do have a few questions:
1. I want to use a 8S set-up so I guess I need a total of 16 cells on board is that correct?
2. I need to know what you fellas recommend for the thrust angle.
Is it true that Nitro planes is thinking about discontinuing this airplane? I was thinking about building a mold to make some glass wings for this, and perhaps could make them available if there was some interest.
Thanks in advance.
Here are some pix.
flyguide7 is offline Find More Posts by flyguide7
Old Sep 06, 2009, 01:02 AM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Yep, 16 cells. I`m using 4 x 4s XPS 5000mah 30c packs. Two for each motor. As far as the wiring goes, I have two completely separate systems. Two separate 8s batteries going to the separate esc. You could hook the two 8s packs together in parallel and then run both motors off of the one big battery, but it`s not necessary.
Fiberglass wings would be awesome. Sign me up!!
With all of these planes that have been sold world wide, I`m surprised that someone hasn`t already done it. You know the turbine guys would love to have composite wings for this plane. I think that the market would be huge.
Knife Liddle is offline Find More Posts by Knife Liddle
Old Sep 06, 2009, 12:08 PM
flyguide7's Avatar
Joined Feb 2006
Yeah, I would like build the wings but I am hesitant to tear mine apart to make the plug. Are there companies that can cut foam wing cores to order? That might be the best way to go. Skin them with balsa or just mylar and use those instead.
Build Log Falcon 120 Wing...NEW Twin 90mm flight video link in post #127...181mph!! Knife Liddle Electric Ducted Fan Jet Talk 448 Jun 04, 2012 11:58 PM
Video Falcon 120 Flying Wing twin EDF with +6kw..Flts 3, 4&5 Knife Liddle Electric Plane Talk 10 Jun 07, 2009 10:54 PM
Discussion Falcon 120 EDF Conversion flyguide7 Electric Ducted Fan Jet Talk 6 Nov 28, 2008 08:04 AM
Video Falcon 120 edf at TEAM 08 darren jakel Electric Plane Talk 1 Oct 27, 2008 06:35 PM
Discussion Falcon 25 Twin EDF conversion flyguide7 Electric Ducted Fan Jet Talk 0 Aug 11, 2008 04:10 PM
