Old Sep 05, 2009, 03:43 PM
warydragon is offline
Find More Posts by warydragon
Fred
warydragon's Avatar
Concord, North Carolina, USA
Joined Jun 2009
Gluing carbon fiber rods together - Problem?
I am building a foam wing and tail feather airplane for aerial photography with a carbon fiber (CF) tube fuselage and CF braced landing gear. I was planning to tack the CF matrix together and then wrap each joint several times with Kevlar thread in such a way that the Kevlar would hold the CF in position. I would then soak the Kevlar reinforced joint with epoxy and have a substantial joint, probably stronger than the CF itself. I sanded the CF and used Hobby Town epoxy to tack the structure together. The structure falls apart with very little force.
The epoxy does not stick to the CF tubes. It's like I used a release agent. Then I scraped the epoxy off, cleaned the contact areas with alcohol and re-sanded the joints and tried CA glue. It would not hold the CF tubes together either. It's like the CF wouldn't allow the adhesives to stick.
Does anyone know what I'm doing wrong? This should work. I know people glue CF tubes together and I thought the strongest adhesive would be epoxy.
Attached is a photo of one of my joints and one of the broken joints.
Fred
warydragon is offline Find More Posts by warydragon
Old Sep 05, 2009, 03:57 PM
rjarois is online now
Find More Posts by rjarois
rjarois's Avatar
royal oak, michigan
Joined Sep 2004
glue..
use ca glue, carbon graphite loves it...
rjarois is online now Find More Posts by rjarois
Old Sep 05, 2009, 04:43 PM
Mikey C. is offline
Find More Posts by Mikey C.
"Hobby Apparatus" Flyer
Mikey C.'s Avatar
Oxford, PA
Joined Aug 2003
I've glued CF rods together with 5-min epoxy with no problem and just a little sanding on the rods. I would think CA would be too brittle but I haven't done it so I can't say for sure. You're right though, it should work the way you've tried... Silly question, but is your epoxy good (and did you mix it right?)
Mikey C. is offline Find More Posts by Mikey C.
Old Sep 05, 2009, 04:46 PM
Fred
warydragon's Avatar
Joined Jun 2009
Something is not right
I bought the 5 minute epoxy a month or so ago and have used it several times. I like it because of the small nozzles that facilitate pouring out equal beads of each part. I have not destructive tested an epoxy joint on anything I've used it for. I have used it to glue some 1/8" oak scabs on two CF rods supporting a dihedral wing. Those joints have not broken yet, but they have not been involved in a "rough landing", yet. I guess I need to do a destructive test of my epoxy on some other material. I'll try it on some wood tonight.
I feel like this problem has something to do with the CF itself.
Fred
Old Sep 05, 2009, 05:10 PM
Challenger 413 is offline
Find More Posts by Challenger 413
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
Every time I use epoxy on carbon fiber, I sand the area, wipe it down with rubbing alcohol and glue. Whenever I am removing the epoxy off the carbon fiber tubes, I have to scrap it off. Try sanding the area and cleaning off the residue, then wipe it with rubbing alcohol (91%), before gluing. I use 15 minute epoxy...
Challenger413
Challenger 413 is offline Find More Posts by Challenger 413
Old Sep 05, 2009, 05:28 PM
Greg D is offline
Find More Posts by Greg D
Aircraft Part Separator
Greg D's Avatar
United States, IA, Tabor
Joined Aug 2003
I bought some CF tubes for spars on a 1/4 scale project from a local kite shop need 6 to have enough length for the 4 spars as it comes too short. They sell a fiberglass ferule that slips into the joint and locks with CA. 3/8s tube the ferule is about 2" long, CA it 1/2 in one piece then slip the other over & CA it.
IFOs are built with CF rod, you bind it with kevlar thread and soak it with thin CA, works real good especially if you hit it with kicker.
I don't know if you could cut a scarf joint with a cutoff wheel, bind it and CA it or not, might be worth a try though.
Greg D is offline Find More Posts by Greg D
Old Sep 05, 2009, 05:32 PM
RogueTitan is offline
Find More Posts by RogueTitan
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
It is very hard to find and pretty expensive but Loctite 404 CA iwill make a permanent bond to carbon fiber rod and Tubes
I used to work as an Archery Technician for High Country Archery out of Dunlap TN and we used to have problems with keeping the aluminum inserts from pulling out of the ends of the carbon arrows until we came across this loctite 404 Cyanoacrylate adhesive .
Also, as C43 said you will want to sand the area that will be bonded, I would go a step further by cleaning the sanded material with alcohol.
There is an outer oily film on carbon which is a waxy residual release agent used in the tube manufacturing process that keeps pretty much anything from sticking very well to the carbon material.
Also, if you plan to paint the rod you may as well go ahead and sand the whole rod in order to get the paint to stick.
EDIT: OH I almost forgot JB Weld works excellently for bonding carbon tube together as well but has a longer cure time than CA like 24 hours but works better than CA. one other method and probably the best method would be to tack together the parts with CA then wrap them with thin strips of carbon fiber mat then applying polymer epoxy resin, AKA Fiber glass resin.
you will still need to sand and clean the tubes regardlessof which method you decide to use.
RogueTitan is offline Find More Posts by RogueTitan
Last edited by RogueTitan; Sep 05, 2009 at 05:47 PM. Reason: Fix typos and punctuation
Old Sep 05, 2009, 07:06 PM
trevjonez is offline
Find More Posts by trevjonez
United States, UT, St George
Joined Jun 2009
what kind of ca glue are you using? i just did some gluing to CF today and my 5 min epoxy didn't stick. then after that i cleaned it up and tryed odorless ca. and it broke off because i didn't clean it good enough. the third time i used a regular old super glue with my kicker and it did the trick! thin super glue is so much easyer to use.
trevjonez is offline Find More Posts by trevjonez
Old Sep 05, 2009, 10:43 PM
ToxicToast is offline
Find More Posts by ToxicToast
Phlathead
ToxicToast's Avatar
Roseville, CA
Joined Aug 2006
I've had luck with doing a wrap of fibrous thread wrapped around a tack bonded connection. Then soak the thread with thin CA and let it air cure or super light misting. This has been rock solid for me.
I've even used this to mount hacker cross style mounts to firewalls and had no problems with the motor ripping out (on an A30 mind you!).
ToxicToast is offline Find More Posts by ToxicToast
Old Sep 06, 2009, 10:29 AM
oct2633 is offline
Find More Posts by oct2633
Joined Jul 2005
Gluing CF rods (or slats)
Warydragon, Try high temp hot melt. It will hold almost anything and is slightly flexible. You may be surprised (and delighted)!
Fred
oct2633 is offline Find More Posts by oct2633
Old Sep 06, 2009, 11:51 AM
Fred
warydragon's Avatar
Joined Jun 2009
Sanding CF tube
Last night I re-sanded my CF parts and applied another epoxy, Scotch Weld 2216 to the joints. It took overnight to cure and seems to be holding today. I'll clean and re-sand the rest of the CF structure today and tack the joints with the Scotch Weld 2216.
I guess I wasn't sanding and cleaning the joints enough to remove all of the release agent from the carbon fiber tubes.
I may use hot glue the next time.
Thanks for the advise,
I'll let you know how it turned out.
Fred
Old Sep 07, 2009, 07:37 AM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
Hot glue, CA, and 5 min epoxy do not work well for CF. If you need good adhesion and strength slow set epoxy and PU (Gorilla/Sumo) are the best choice.
rich smith is offline Find More Posts by rich smith
Carbon Fiber Rods rplourdejr Scratchbuilt Indoor and Micro Models 13 Apr 08, 2011 12:34 AM
Question about Carbon Fiber Rods (Soarstar Landing gear) joemi Parkflyers 6 May 09, 2002 02:16 PM
Carbon Fiber Rods for Wing Spars Jim Young Power Systems 7 Dec 21, 2001 12:52 PM
Cool Carbon Fiber Rods Planeboy P51 Parkflyers 5 Dec 16, 2001 12:15 AM
Source for Carbon Fiber rods Twmaster Parkflyers 11 Sep 27, 2001 12:23 AM
