Old Feb 24, 2012, 11:47 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Originally Posted by giammi77 View Post
Very good work !!
++1, Roy!
Thanks for documenting the process with pictures also. I know how much this normally slows the procedure.
Thank you.
R,
Target
target is offline Find More Posts by target
Old Feb 24, 2012, 01:34 PM
chetosmachine is offline
Find More Posts by chetosmachine
chetosmachine's Avatar
Madrid, Spain
Joined Sep 2004
Excellent work there!
I'm sourprised you had troubles working with the textreme. Which carbon did you use? Does it have some kind of binder?
chetosmachine is offline Find More Posts by chetosmachine
Old Feb 24, 2012, 03:19 PM
DrFragnasty is online now
Find More Posts by DrFragnasty
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
Measuring spar depth
Looks great Roy, thanks for posting.
How did you determine the depth to cut the main spar? I'm guessing bits of putty at points along the wing, close the mold, squash the putty, remove wing-half, measure heights, subtract 1mm for the bog mix?
Chris.
DrFragnasty is online now Find More Posts by DrFragnasty
Old Feb 24, 2012, 03:31 PM
roydor is online now
Find More Posts by roydor
In F3J size does matter!
roydor's Avatar
Israel
Joined Nov 2006
The fabric kept trying to roll back to the shape it had when packaged. In addition the UD tows became disorganized at some places and gaps formed between them. When cutting the fabric the edges wanted to break apart. I used a thin sheet of nylon film and used 3M adhesive to stick it to the spread tow and then it became real easy to handle the fabric, cut it accurately and place it in the mold. After placing it in the mold the I removed the nylon film but had to find a way to remove it without messing the edges when pulling it out. In the end I managed doing it well but it takes more time in comparison to "regular" carbon. Great mechanical properties but requires special care which wasn't required in the past.
roydor is online now Find More Posts by roydor
Old Feb 24, 2012, 03:54 PM
roydor's Avatar
Israel
Joined Nov 2006
DrFragnasty,
I calculated the height of the web at 20 cm intervals from the airfoils and laminate thickness and made small blocks 1 mm lower. I put tape on the spars to prevent them from getting dirty and then I put polyester putty on the blocks, top and bottom, and placed them at 20 cm intervals and closed the molds. 15 minutes later I had myself small posts of hard material showing me the local thickness and I could measure it accurately using a caliper. I sanded my webs to 0.5 mm of that measurement and as always, I ended putting just a little bit more epoxy to make sure I had a good bond. If I had to guess I would say I have no more than 10 to 15 grams of extra epoxy per panel for safety reasons.
Roy
Old Feb 24, 2012, 04:00 PM
roydor's Avatar
Israel
Joined Nov 2006
I actually feel a little ashamed, I planned to take much more pictures then I ended up taking but got lazy. Also, I took many pictures with my cell phone camera because I forgot my good camera at home. The previous Gremlins were more documented and I initially planned to do more then I ended up doing.
Old Feb 24, 2012, 05:14 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Well, I'm happy for any pictures that get posted of build techniques....
Thanks again.
R,
Target
Old Feb 24, 2012, 05:20 PM
jojoen is offline
Find More Posts by jojoen
jojoen's Avatar
Norway
Joined Dec 2003
Thanks for the updates. Watching closely
jojoen is offline Find More Posts by jojoen
Old Feb 26, 2012, 04:00 PM
OZPAF is offline
Find More Posts by OZPAF
Sydney
Joined Apr 2009
Thanks for the photos and info Roy. Really nice work.
John
OZPAF is offline Find More Posts by OZPAF
Old Mar 03, 2012, 10:44 AM
roydor's Avatar
Israel
Joined Nov 2006
I had some time today so I opened the servo bays in the wing.
I'm REALY happy with what I saw. The web is glued to the spar cap very cleanly, no blobs of epoxy and no voids in all four bays. Obviously I can't see the entire web and the aft web obstructs the view of the front one but since the web on all four bays looks good, I feel it's a good representation for the rest of the wing. I've attached pictures of the webs from all four bays which aren't very good (the pics) as they make the leftovers look more then they actually are with some voids which in reality aren't there, it's just full to the right extent.
The carbon socks seem to have come out nicely as well and the epoxy soaked sponge is nice and rigid. It can be crushed with some pressure but that kind of pressure doesn't exist in that area anyways and it took no time at all to do.
The servo bays themselves came out rigid and I couldn't see skin flex when I pressed on them from the outside.
Also, the wing looks plenty stiff and has a good chance of being an all weather model. First flights will show if this is true or not
BTW, after finishing the trimming of the leading and trailing edges and opening the servo bays the weight of the left wing is 542.3 grams and the right wing is 541.3 grams
I'm going to wait with opening of the flaps and ailerons until I complete the pod and check the alignment of the wings relative to one another, it's simply easier before cutting them as I can measure the angle more easily with a stiff wing (no flapping surfaces).
I've ordered servos for the wing. Going with 761's for the flaps and 809's for the ailerons. From what I've heard so far the 809's should be sufficient even for strong launches in windy conditions.
This week I hope to get the molds of the rudder and pod ready for molding and to prepare the materials for them. I want to mold them both on the same day so to save the setup and cleaning time involved in the molding process.
Roy
Old Mar 03, 2012, 10:56 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
That DOES look like a great bond to the skins. Thats as good or better than I've seen in any production molded plane.
Good job and congrats!
The 11mm servos (Airt 809, Hyperion DS11) have been nothing but stellar for me. I have them in all the aileron positions of my TD planes, including the 4M Xplorer.
They are great for F3B and F3F v-tails also.
I like the Hyperion DS11 a little better for the v-tails; they are available in resin/carbonite gears, so zero slop.
R,
Target
Old Mar 05, 2012, 09:09 AM
roydor's Avatar
Israel
Joined Nov 2006
I decided to go ahead and open the ailerons and flaps as I thought of a way to check their alignment to the fuselage regardless of them being cut. On this model I decided to make the flaps and ailerons the entire span of the wing.
I hate not having a fixed reference to their alignment when flying in order to check for thermal drift (servo) and bent pushrods, but it ends up slightly lighter and more aerodynamically efficient so I decided to give it a go.
After opening the moving surfaces I found excellent bonds on all and super stiff surfaces due to the carbon tubes and spread tow combo. This wing is VERY strong in torsion and if the spar system ends up as strong, I'm expecting an all weather model for sure!
I'm extremely happy with the results so far
Old Mar 05, 2012, 09:19 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Looks great!
R,
Target
Old Mar 07, 2012, 03:11 PM
roydor's Avatar
Israel
Joined Nov 2006
I molded the flaps gap seal. Made it out of epoxy and micro-balloons using tape as a guide for the shape. For the ailerons I plan on using tape to save some weight.
I also installed the locating pins at the root, two stainless steel pins 4 mm in diameter per wing panel.
The weight of the wing panels is now 549.5 grams and 549.9 grams
Next step will be to install brass horns for the ailerons and flaps.
After that install the servos and solder and install the wing harness and the wing will be finished.
I haven't decided which color servo covers I'll use, I have carbon servo covers and I have red covers I made a year ago. I might make yellow ones to blend in with the wing next time I paint something (fuse or ruder), we'll see...
Old Mar 07, 2012, 04:16 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Its going to fly much better with the red covers!
R,
Target
My Firefox project slowjoe170 Electric Ducted Fan Jet Talk 10 Mar 19, 2005 01:03 AM
My Electrajet project slowjoe170 Foamies (Kits) 66 Dec 11, 2002 06:26 PM
My next project....the RAKE Tres Wright Parkflyers 12 May 20, 2002 10:55 AM
My Python Project squelchF18 High Performance 4 May 01, 2002 08:54 AM
-= Pics of my latest project =- Jensst High Performance 15 Jun 05, 2001 04:51 PM
