Awesome looking plane; I hope that it flies as great as it looks for you!
Target |
Latest blog entry: Stork 4 Pro X-tail from...
Attached are pictures of the balsa elevator Vs. the carbon one and a cross section of the first test elevator.
I used the balsa elevator on my modified Perfect:http://www.rcgroups.com/forums/showthread.php?t=892808 see post 21 Roy |
I was asked to give some more information about my elevator so here goes.
I started out with a broken Pike Perfect elevator a friend gave me, It was severely damaged but I could salvage the root interface which suited me fine because I wanted an elevator interface identical to the Perfect since I wanted to be able to use the Perfect Elevator with my rudder on my modified Perfect. I rebuilt the LE and the Dbox and shortened it so its size was reduced to 7 dm instead the 7.5 dm of the Perfect elevator. The tip shape was changed and shaped to provide lines I was more comfortable with. After completing the master, shaping, sanding, painting it to perfection I molded it and made joggle molds detachable to the elevator molds. The idea behind the joggle is to have overlapping material in the leading edge and spar to provide a solid load bearing joint. If you compare it to a conventional joint it isn't necessarily heavier as the amount of glue used to join the parts is minimal and the strength is maximized due to the fact that the loads are transferred through the laminate itself and not through glue with microbaloons which is brittle. In the pictures provided you will see the production stages, the molds, the joggle, the overlapping etc. The elevator itself has very little material in it, I've found that the outside layer which is 90 grams/m^2 carbon weighs only 7 grams with glue since there is so little material. If I was to change it to 25 grams/m^2 glass I would save just 5 grams which would be mostly added back by overlapping carbon over the glass at the root, tip and web areas (as I discovered when I built a balsa and glass elevator). The reduction in weight was simply not worth the effort and the increase in strength was more than worth it. On a fully molded tail however, changing the glass to carbon would be equal to at least 15 grams more weight which is considerable. In a fully molded elevator the entire structure works to strengthen the elevator in torsion so it’s also stiff enough and does not require full carbon construction to achieve the required strength. A d-box elevator however, can suffer from lack of strength if not built correctly and benefits greatly from the carbon construction. The core is 1.2 mm Herex, same as I used in the wing. It weighed 3.5 grams for the entire elevator, Balsa .6 weighed 3 grams, lighter balsa was out of the question for it would have greatly suffered from hanger rash and at such a thin core would have affected the strength as well. The inner fabric is 25 grams/M^2 glass. The root is reinforced up to the aft location pin and is very flimsy aft of it, where strength is not really required, same at the tip, it’s just as strong as is needed. The spar is made of UD tapered down from 6 mm in width at the root to 2 at the tip, thickness is also tapered from .4 mm to .2 mm. The web is made from the 90 gram carbon of the outside skin (at 45 deg) and an additional 90 gram fabric with 0-90 orientation, adding both to the spar strength and preventing buckling of the web. The trailing edge is a spur of the moment idea, I already started mixing the gel coat for the mold when I decided to leave space for a spar at the TE should I want to glue it with the same glue used to close the two halves, I took a piece of spruce, tape it over and glued it to the parting line just before pouring the gel coat on. this gave me a compartment I could place a carbon strip when closing the two halves, after completing the elevator by gluing in place the ribs and adding carbon cap strips to them I can sand the TE to size, 4 mm at the root going down to 1.5 at the tip, the TE is just .5 mm in thickness. The joiner system weight to those wondering is 3 grams for the joiners, another 1 for the tube and about 1 gram extra of glue, which adds to 5 grams in total. The root is about 1.5 grams so if I had wanted to make a one piece elevator I could have built one at around 30 to 35 grams.
| Thread Tools | |
| My Firefox project | slowjoe170 | Electric Ducted Fan Jet Talk | 10 | Mar 19, 2005 01:03 AM |
| My Electrajet project | slowjoe170 | Foamies (Kits) | 66 | Dec 11, 2002 06:26 PM |
| My next project....the RAKE | Tres Wright | Parkflyers | 12 | May 20, 2002 10:55 AM |
| My Python Project | squelchF18 | High Performance | 4 | May 01, 2002 08:54 AM |
| -= Pics of my latest project =- | Jensst | High Performance | 15 | Jun 05, 2001 04:51 PM |
