Old Sep 04, 2009, 10:23 AM
adbradley is offline
Find More Posts by adbradley
adbradley's Avatar
Joined Mar 2007
18.5" Depron Profile EuroFighter Typhoon
Here is the newest edition to www.nicohobbies.com that is in the works. Its a Eurofighter Typhoon with a wingspan of 18.5" made from mostly 3mm depron. Specs are as follows
18.5" WS
26.75" LENGTH
5-7 oz. AUW
500-800 MAH battery
5 Gram servos
18mm 2500 KV motor
10 amp esc
4.5x3 or 4.5x4 prop
Attatched are some pic of the prototype build CRXMANPAT is working on
adbradley is offline Find More Posts by adbradley
Old Sep 04, 2009, 11:49 AM
RacerX208 is offline
Find More Posts by RacerX208
RacerX208's Avatar
Joined Apr 2004
Sharp!
RacerX208 is offline Find More Posts by RacerX208
Old Sep 04, 2009, 01:53 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
kewl....... gotta build one.
Joe 1320 is offline Find More Posts by Joe 1320
Old Sep 04, 2009, 02:17 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Yep, as he said I'm doing the beta build on this. Got the plans yesterday morning, hit the LHS in the afternoon for some foam, and had a plane cut out by 8pm.
So far so good, and I may have it in the air by Monday or sooner.
I'm using all parts from Nico Hobbies for the electronics except for the servos (had 2 GWS Picos sitting around needing a home). I'm shooting for somewhere between 5 and 6oz AUW just like with the other planes. I'll also be using the new Hyperion lipo instead of the Turnigy. Be interesting to see if there's any difference in power.
The pics are just of the dry fit. I'll take more for the build.
EDIT - Plans, build guide and decals added to this post.
Full color Build Guide
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Sep 07, 2009, 01:15 AM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
OK, plane's all built and ready for maiden tomorrow morning. Here's my setup:
1806N 2500kv motor from Nico
10A ESC from Nico
2x GWS Pico Standard servos
GWS 4.5x3 prop
Hyperion G3 3S 450mAh lipo
XPS 6-ch parkflyer RX
Dry weight (no lipo) - 3.6oz/103g
AUW with Hyperion lipo - 5.1oz/146g
No paint so far, just all white. Should have paint and decals done by next weekend.
Here's a quick build outline and photos:
Step 1 - Join the front and rear fuselage halves with your preferred glue.
Step 2 - Glue in the CF spar with epoxy.
Step 3 - Hinge the control surfaces and attach them to the wing (easier to do now rather than later).
Step 4 - Glue on the lower intake sides.
Step 5 - Glue on the vertical stabilizer.
Step 6 - Glue on the lower vertical stabilizer locking piece.
Step 7 - Glue on the rear belly pan support.
Step 8 - Glue on the lower fuselage section.
Step 9 - Glue on the upper fuselage section.
Step 10 - Glue on the belly pan.
Step 11 - Glue on the wingtip rails.
Step 12 - Hot glue the ply motor mount to the foam motor mount. Use the motor base to mark and pre-drill your screw holes in the ply mount, then secure the base to the mount. Hot glue the motor mount assembly in place.
Step 13 - Install the ply control horns.
Step 14 - Install the electronics. The lipo should be placed all the way forward in the electronics bay and should be turned sideways.
Step 15 - Go fly!
Pat
Old Sep 07, 2009, 01:48 AM
eliworm is offline
Find More Posts by eliworm
You sabotaged my plane.
eliworm's Avatar
Arizona
Joined Jun 2002
I just cut a few of these for Adam. These are one cool looking plane. I might have to get one of these flying when I get back from Michigan.
Jim
eliworm is offline Find More Posts by eliworm
Old Sep 07, 2009, 02:01 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Success!
Maiden went off without a hitch, just as I expected. I think the CG set on the current plan may be at the forward edge of the flight envelope. I had to add a decent amount of up into it. But overall, another great flyer!
Got a total of two flights in. First flight was about 5 minutes of mixed throttle. I put a total of 396mAh back into the Hyperion G3, and the best part was it only took 8:13 to charge at a rate of 3 amps! I love these new G3's!
One thing different about this bird is that it doesn't flip right over like the others. I think that's because there is no control surface area in the prop wash. But that's OK, it still flies great. Vertical is unlimited with the recommended power setup.
Pat
Old Sep 07, 2009, 04:19 PM
adbradley's Avatar
Joined Mar 2007
Great job pat, this plane looks great in the air with a crazy fast roll rate. Slow speed performance was very nice as well.
Old Sep 08, 2009, 02:36 PM
SilverHeli2000 is offline
Find More Posts by SilverHeli2000
SilverHeli2000's Avatar
United States, IN, New Palestine
Joined Jun 2004
Very nice looking! I would like to see the slow flying performance of this.
SilverHeli2000 is offline Find More Posts by SilverHeli2000
Old Sep 08, 2009, 02:49 PM
adbradley's Avatar
Joined Mar 2007
I watched pat fly it yesterday, he went up a few hundred feet and completely killed the motor, and it was like a glider! looks to me like it may have better slow performance than the F15, or the F22, you just dont get any thrust deflection like you do on those models, so the high alpha performance wont be as good. I plan on trying a working canard mod though, and see what that will do.
Adam
Old Sep 08, 2009, 02:52 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Yeah, it floats like a dream, but high alpha slow flight is not as good as say the F-22 or F-15 as there is no control surface in the prop wash. But it will hover in a slight breeze. I did manage to do that on the second flight when the breeze started to pick up.
All in all a great flyer, and speed on the flat level passes is nice! I think this one comes in second in top speed right behind the F-18.
Pat
Old Sep 09, 2009, 11:42 AM
Joined Jun 2004
Adam, these are really looking good! what about scaling one up to 6mm, and using 2 of the motors?? might even be able to do a little vector thrust on them?
Old Sep 09, 2009, 12:02 PM
adbradley's Avatar
Joined Mar 2007
I actualy have another plane in the design stages that would be a better candidate for that, i will keep you posted
Old Oct 01, 2009, 12:11 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Adam had me detail one for his show display, so I decided to dress mine up at the same time.
Pat
Old Oct 01, 2009, 01:54 PM
adbradley's Avatar
Joined Mar 2007
Those look awesome pat, and they fly just as well!
Discussion Quick-Build Profile Eurofighter Typhoon tomhe Pusher Prop Jet Models 575 Jan 27, 2016 11:53 AM
Discussion 18" WS 3mm Depron Profile F15 WITH PLANS! adbradley Pusher Prop Jet Models 213 Oct 28, 2014 07:51 PM
Discussion Eurofighter Typhoon (EF-2000)depron plane aero-dreamworks Foamies (Kits) 6 Dec 05, 2007 03:36 AM
FA-18 Hornet wing profile?? Appie Electric Ducted Fan Jet Talk 8 Jan 20, 2003 03:40 AM
just 18.5 grams airtoi Scratchbuilt Indoor and Micro Models 7 Jun 28, 2002 10:51 PM
