Old Sep 04, 2009, 05:18 AM
blerot is offline
Find More Posts by blerot
blerot's Avatar
France, Alsace, Molsheim
Joined Jun 2005
DC3 Top Flite electric conversion
The flight of an American Airlines DC3 Top Flite
DC-3 RC Top Flite Maiden Flight (3 min 59 sec)
A comment about the figure at 2'18" : I had some troubles when I activated the flaps
- 1st trail with elevator mixed with flaps as written in the manual (2.5mm up): the plane goes up.
- 2sd trail with elevator mixed with flaps 1mm down. You can see the result on the video at 2'18": a kind of roll over. It's the reason I don't use them for the landing and had some stress for the landing.
Jean-Marc
blerot is offline Find More Posts by blerot
Old Sep 10, 2009, 10:27 AM
Thrawn150 is offline
Find More Posts by Thrawn150
Thrawn150's Avatar
USA, IL, Oak Lawn
Joined Apr 2007
That looks great.
Thrawn150 is offline Find More Posts by Thrawn150
Old Sep 11, 2009, 11:40 AM
ezrydr is offline
Find More Posts by ezrydr
what goes up...
ezrydr's Avatar
Alton Iowa
Joined Aug 2006
thanks for posting that - very nice looking DC3
upon takeoff did you notice the plane wanting to roll to the right?
if it did, did you have to put in much correction?
ezrydr is offline Find More Posts by ezrydr
Old Sep 11, 2009, 12:42 PM
blerot is offline
blerot's Avatar
Joined Jun 2005
Thanks for your comments,
I had just to trim (a little bit) the elevator.
The problem with the flaps seems fixed (less stroke for the flaps and 1mm elevator down with the flaps open)
I had just to take time to make the 4th flight to try this and to land more slowly...
Jean-Marc
Some pictures about the construction in the section Joe's Hangar
http://www.wix.com/jiminez/MonGarage
Old Sep 12, 2009, 07:38 AM
ezrydr is offline
what goes up...
ezrydr's Avatar
Alton Iowa
Joined Aug 2006
Jean-Marc
could you please post details of your power system and final weight of your DC3?
thanks,
Steve
Old Sep 13, 2009, 12:01 PM
blerot is offline
blerot's Avatar
Joined Jun 2005
Hi Steve,
Some details about the weight
- Fuse with 2 servos: 1107g (2.43lbs)
- Wing complete with 2 electric motors, 2 controllers, 5 servos, flaps and robart retact: 2496g (5.49 lbs)
- Batteries : 757g (1.66 lbs)
The total weight is : 4360g (9.59 lbs)
the weight of the Robart retacts cylinders, air tank and the legs is 350g, the wheels 236g and the motors + controllers 420g
and about the motors
I use 2 AXI 2826/12 motors with jeti 40 opto + controllers, an external UBEC 5A and the batteries are Hyperion 4S3300mAh.
Props : graupner cam prop 11 x 6 (9800 rpm at 25 A)
Flying time 12 to 15 mn
Half throttle is enough to fly scale.
I made the 4th fly today with a very nice landing.
Jean-Marc
