Old Dec 21, 2010, 08:06 PM
Staggerflyer is offline
Find More Posts by Staggerflyer
Staggerflyer's Avatar
Tama, Iowa USA
Joined Dec 2007
Originally Posted by wizprod View Post
If you read the doc for the rpm sensor, this is clearly stated as well
Yes, that document is where I learned it.
Staggerflyer is offline Find More Posts by Staggerflyer
Old Feb 02, 2011, 01:57 PM
jfflyer is offline
Find More Posts by jfflyer
John Foltz
jfflyer's Avatar
Woodstock, GA
Joined Jan 2011
Originally Posted by Moby58 View Post
E-Flight Park 480 BL 12 poles
We need to be clear about all the different "480" motors sold by Horizon Hobby.
I'm almost positive that the 480 and 480BL brushless outrunner 960Kv have 14 poles/magnets. This is from a "feel" test with the ESC brake on, but others claim to have disassembled the motor and confirmed it, as posted in these forums. The motor has 12 stator arms, but 14 magnet poles, which is a common combination for high-torque brushless motors.
A version of this 480 960kv motor comes in a whole bunch of Parkzone planes. The reverse-shaft version comes in the Radians.
There are other "480 size" motors sold by Parkzone and E-Flite, but I'm referring to the 960kv ones. I know there is an E-Flite 1010kv one that says 12 poles on their web site, and they also have a 4000kv one that says 6 poles. These are all 480 size motors, which is a loose designation of the physical size.
Here's what a brushless outrunner looks like. The pole count is the number of magnets in the outer shell. It will always be different than the number of arms on the stator.
This is a 14 pole motor, but it has 12 stator arms and 6 coils. It isn't the Parkzone motor, just an example image I found that is very close to it.
jfflyer is offline Find More Posts by jfflyer
Old Feb 08, 2011, 06:39 AM
jfflyer is offline
John Foltz
jfflyer's Avatar
Woodstock, GA
Joined Jan 2011
I've confirmed this RadianOne and RadianPro motor:
480B BL Outrunner Motor; 960Kv Reverse Shaft
has 14 poles. Also, with the propeller and adaptor removed (down to the bare shaft) I get about 935kv out of it (11,395 RPM @ 12.2V) using the stock ESC. It's rated at 960 so that's pretty close.
Old Feb 13, 2011, 09:54 PM
MJRnewb is offline
Find More Posts by MJRnewb
Joined Feb 2011
The Turnigy Typhoon 500H Heli Motor 1800kv (500 Class) has 6 poles/magnets. Not sure how many stator arms but it does have six magnets.
MJRnewb is offline Find More Posts by MJRnewb
Old Mar 06, 2011, 10:08 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I think it has to have 9 wound stator arms... 6-magnets or 12-magnets work with 9-arms.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 23, 2011, 09:31 AM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Hobbypartz Monster Power .15,25,32,46,60 All 14 pole
Melnic is offline Find More Posts by Melnic
Old Mar 23, 2011, 09:59 AM
jfflyer is offline
John Foltz
jfflyer's Avatar
Woodstock, GA
Joined Jan 2011
So does any other even number in a reasonable range. In outrunners, 9-arm stators come with every even number from 6 to 16 magnets, maybe others too. I don't think you can make any assumption.
Old Apr 14, 2011, 09:17 AM
Rockin Robbins is offline
Find More Posts by Rockin Robbins
Drone offender FA377YHFNC
United States, FL, DeLand
Joined Mar 2009
Turnigy 2217-20 14 poles
Rockin Robbins is offline Find More Posts by Rockin Robbins
Old May 02, 2011, 07:20 AM
seaking63 is offline
Find More Posts by seaking63
Fly Crash Repair and Fly again
Singapore, Singapore
both outrunner motors Esky 3100kv(400 class) & Esky 3900kv(400 class) have 6 magnets with 9 coiled stator arms
seaking63 is offline Find More Posts by seaking63
Old Jun 24, 2011, 05:25 PM
ids911 is offline
Find More Posts by ids911
ids911
ids911's Avatar
GA
Joined Jan 2009
Anyone know the pole count for a Torque 22T/930 motor?
found out from mfg: 12 pole
ids911 is offline Find More Posts by ids911
Old Jul 01, 2011, 09:27 AM
brinky is offline
Find More Posts by brinky
Naperville, IL
Joined May 2009
Rimfire .60 50-55-650:
12 Stator Poles
14 Rotor Magnets
28 Rotor Poles (always twice the magnet count).
brinky is offline Find More Posts by brinky
Old Jul 01, 2011, 11:39 AM
jfflyer is offline
John Foltz
jfflyer's Avatar
Woodstock, GA
Joined Jan 2011
12 Stator Poles
14 Rotor Magnets
No. Rotor poles = magnet count. If you set it the way you describe then the sensor is showing you half the actual RPM.
And stator arms isn't relevant for configuring an RPM sensor.
Old Jul 02, 2011, 10:25 AM
brinky is offline
Naperville, IL
Joined May 2009
Oops. You're right, John. I was thinking of magnetic poles, rather than the number of poles the stator sees. The motor only sees the inside pole of the magnet and the outside poles (ie. where the magnet is glued to the rotor) are ignored. Thanks.
Old Oct 03, 2011, 07:25 AM
Geni is offline
Find More Posts by Geni
Schweiz
Joined Apr 2008
NTM Prop Drive 35-36A 1800 10 poles
Geni is offline Find More Posts by Geni
Old Oct 07, 2011, 09:10 PM
habu2010 is offline
Find More Posts by habu2010
USA, VA, Gloucester
Joined Jul 2010
Does anyone know how many poles for NTM Prop Drive Series 35-42A 1250Kv 600W?
habu2010 is offline Find More Posts by habu2010
Please Post your Aerial Photos here.... kepople Aerial Photography 262 Aug 27, 2015 10:13 PM
Please Post your Aerial Photos here....See Aerial Photo Forum kepople Aerial Photography 234 Apr 29, 2015 11:29 AM
Please post your Small EPP 3D airplanes Here fly4fun 3D Flying 39 Nov 30, 2005 03:10 PM
Yippee! Please post your links to free plans HERE! CactusJackSlade 3D Flying 12 Oct 08, 2004 01:30 PM
Please post your flight times for brushless Voyager E's Astro30 Electric Heli Talk 4 Mar 16, 2003 06:31 PM
