Old Sep 03, 2009, 04:18 AM
Faro69 is offline
Find More Posts by Faro69
Joined Jul 2009
Anyone ever use 23 dBi 900 Mhz. antenna
Anyone ever use this ? Where to buy ? If compare thai with pacth antenna 8 dBi it better ?
Technical Specifications
BATTERY POWER
7.5 V - 12 V
GAIN
23 dB / 900 MHz
CURRENT CONSUMPTION
55 mA
SIZE:
1.0" x 0.7" X 0.2"
RF IN/OUT
50 ohms
ANTENNA CONNECTORS
SMA/BNC
LOW NOISE
BUILT-IN SPECIAL BAND PASS FILTER
FREQUENCY RANGE
900-928 MHz
Faro69 is offline Find More Posts by Faro69
Old Sep 03, 2009, 08:59 PM
Faro69 is offline
Joined Jul 2009
Anyone can advise me?
Old Sep 03, 2009, 09:22 PM
Faro69 is offline
Joined Jul 2009
Other model
Old Sep 03, 2009, 10:43 PM
JanBoothius is offline
Find More Posts by JanBoothius
Joined Feb 2008
high dBi means more directional.
do research on the forum, all the answers are there, that is why you're not getting any replies yet (cmon FPV guru's, prove me wrong and help this poor fellow).
this might also help, good luck.
http://rcexplorer.se/page14/gain/gain.html
if you have a diversity video setup, have an omni (http://www.nghobbies.com/cart/index....roducts_id=221) on one receiver (and transmitter), and a patch (http://www.nghobbies.com/cart/index....roducts_id=220) on the other receiver, pointed at the plane at all times if possible
JanBoothius is offline Find More Posts by JanBoothius
Old Sep 03, 2009, 10:49 PM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Technical specs mean nothing unless we can get it. Who manufacturers this thing. 23db gain is large along with the noise it must have.
Martin Y is offline Find More Posts by Martin Y
Old Sep 03, 2009, 11:03 PM
JustinONE is offline
Find More Posts by JustinONE
Torrance
Joined Feb 2005
I think for best all around flying, you want lower dbi antenna, used in conjuction with higher power amp. I think this will give a better radiation pattern with out any dead spots of a super high gain antenna.
JustinONE is offline Find More Posts by JustinONE
Old Sep 03, 2009, 11:24 PM
Martin Y is offline
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
A low gain antenna and high pre-amp can lead to all sorts of problems, including noise (unwanted signals) reception and self oscillation, the possibility of damaging the input stage of your RX, to name a few.
Old Sep 04, 2009, 05:11 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Hey, dudes, this is not an antenna, is an amplifier !
It not affects any way the radiation pattern of the existing antenna, but I doubt it is equivalent with a 23dB Yagi, because it amplifies the noise too.
renatoa is online now Find More Posts by renatoa
Did anyone ever use/modify a l`espion digital camera for rc aerial photography? blue_bull DIY Electronics 0 Mar 24, 2004 04:56 AM
Anyone ever use this camera? Acer Aerial Photography 2 Jun 09, 2003 03:26 AM
Anyone ever use mono-cote for wipers? pullin-gs Electric Plane Talk 9 May 30, 2003 10:10 AM
Anyone Ever Use a Wingo Porter For A/P ? Buzz_Man Aerial Photography 2 Feb 01, 2003 12:29 AM
Question Anyone ever use an 8 cell 700mah NiMH pack on a TM? Scomis Parkflyers 2 Feb 17, 2002 09:38 PM
