Old Sep 02, 2009, 01:57 PM
ttuzun is offline
Find More Posts by ttuzun
Joined Aug 2009
New plane, New Problems
Hi everyone, I just got my Art Tech Spitfire and put it together however i have a few concerns. I would really appreciate if someone can help me.
1) The elevator upwards throw is about half of downwards because inside the fuselage the control horn bends that way. Is there anything that can be done or should be ok?
2) There are 2 screws that holds the main wing connected to the fuselage and 1 of them is just loose. the hole is too big for it. The other one fits perfectly. What can be done?
If someone can help me with these questions i would be really grateful.
Thank You before hand!
ttuzun is offline Find More Posts by ttuzun
Old Sep 02, 2009, 02:45 PM
gnats82 is offline
Find More Posts by gnats82
Coy, peruser of worlds
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
ttuzun -
Check the manual that came with the plane for control throw allowances. You're o.k. if it falls in that range. My guess would be in the area of 1/2" each way is enough. May need to have some clearance cut in the rudder area to allow the horn more movement.
Try getting a larger dia. screw to fit the troublesome threaded hole but still small enough to fit through the wing. If you ordered it from HL direct, they might be able to help via e-mail or phone.
gnats82 is offline Find More Posts by gnats82
Old Sep 03, 2009, 01:36 AM
ttuzun is offline
Joined Aug 2009
I solved the screw problem however the movement doesnt seem enough. The manual doesnt say anything about it either. The upwards movement is about quarter of an inch. Considering it might bend more in the air i dont feel confident.
If ı could open up the fuselage i would be able to fix it np however ı dont want to destroy it.
I was planning on drilling tiny holes and passing through a tin wire and then tie it up outside to hold horn in place and prevent it from bending. I ll try to figure out other ways too.
Old Sep 03, 2009, 03:41 AM
gnats82 is offline
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
ttuzun -
I may be having a misunderstanding. When you say the control horn is bending, do you mean by some force acting on it (deforming) or is it molded or attached curved? I assumed curved as originally stated.
The elevator should move freely and the control horn should not bend or deform to move it nor should the linkage bind in any way.
Also, with the control linkage detached from the horn at the elevator, the elevator should move freely up and down, at least 1/2" each way (measured at the trailing edge of the elevator). If it is stiff or very resistant to movement, that would need to be corrected
I just checked the HL website and it has a good view of the elevator hook-up and it the simplest kind and would need no modification if hooked up correctly. If it is just a matter of the push-rod binding against the fuselage where it comes out, the rod can be carefully bent to relieve that.
Have you set up any other r/c planes?
Old Sep 03, 2009, 04:14 AM
ttuzun is offline
Joined Aug 2009
i am sorry. Its my bad. I wanted to say control rod not horn. I apologize.
The elevator does move more then 1/2 " however its not too free a little stiff.
It is the rod that bends inside. I am also considering buying steel rods and changing it with the original.
Old Sep 03, 2009, 04:23 AM
gnats82 is offline
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
These planes will work fine with the control parts they have made it with, no need to replace the control rod - sounds like you just need to make small adjustments to it where it exits the fuselage until the binding is relieved. Just unlink the rod from the control horn and bend it gradually until it lay straight to the elevator horn then reattach and test.
Somewhere along the line it might have been bumped to deform the rod.
Addit.: Check out the test and review of this model in this forum if you already haven't. Just saw the kind of hinging they're using and it is prone to some stiffness. With the control rod detached, you could work it up and down to work out some of that stiffness.
Old Sep 04, 2009, 02:44 AM
ttuzun is offline
Joined Aug 2009
i ll try doing it tonight. If somehow i cant make it work. I am planning on getting some cover for it (like hollow carbon fiber? or wood?) and put the rod in it or find a way to hold it in place.
Old Sep 04, 2009, 07:31 AM
gnats82 is offline
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
I feel like we must be overlooking something here. You are trying to move the control surface with the radio aren't you? If you're trying to force it physically, that won't work with the linkage still attached at the servo. Have you checked to make sure there isn't something wrong with the linkage inside the fuselage like a foreign object jamming the linkage?
There should be no need to modify this what-so-ever, just a careful check over of the existing airframe. The only thing that is to hold the rod "in place" would be it's attachment to the control arm at the servo and the clevis link at the elevator control horn. Driven by the servo, it needs to float freely through the fuselage side slot/exit with no binding and no additional guide.
As I asked earlier, have you set up any other r/c planes?
Old Sep 04, 2009, 07:37 AM
ttuzun is offline
Joined Aug 2009
I move it with the radio. i can even see it being bent inside no matter what the servo does. Its just not aligned properly. The rod is almost 40cm long. Personally unles it is secured somehow, a 1mm rod would bend no matter. I asked other people who had this plane and it seem to be a common problem with several different fixes. I am going to try the carbon fiber rod fix and see what happens.
Old Sep 04, 2009, 07:52 AM
gnats82 is offline
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
ttusun --
This really reads to me like a problem with the elevator hinging being too stiff, causing the rod to deform. Making the rod more rigid seems sensible however the servo will be forced into a higher loading just to move this and cause a faster battery drain and ultimately possibly ruin the servo gears.
I set up a Thunder Tiger P-40 that uses a very similar hinging method and chose to cut the elevator off from the stabilizer and re-hinged using small Dubro pin hinges.
FWIW.
From reading the test of this model, it looks like it is very sensitive to elevator throws so 1/4" each way from neutral may be o.k. but ideally with the servo not having to fight so hard to get the movement.
Old Sep 04, 2009, 08:00 AM
ttuzun is offline
Joined Aug 2009
I ll try to take of some of the stiffness, support the rod and eventually try to change the hinges. I need to order the hinges from somewhere though, possibly hobby king
Old Sep 04, 2009, 08:03 AM
gnats82 is offline
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
ttusun -
Do you have a fairly local hobby shop? Sad that you would have to order something like a pkg. of hinges.
Old Sep 04, 2009, 08:15 AM
ttuzun is offline
Joined Aug 2009
I do however,
1) Yesterday because they turned on the controller with full throttle on my plane blew to pieces. I tried to repair it all night.
2) they sell about everything AT LEAST twice the price of ordering (including shipping)
So i dont wanna buy anything from there as long as its not urgent or really cheap. Also they dont have many options idk if they would even carry small hinges.
Old Sep 04, 2009, 08:58 AM
gnats82 is offline
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
ttuzun -
FWIW - If you're deciding to make an exit guide for the control rod, a good source I've found for the tubing would be that from an old spray dispenser like a household cleaner product, the tube that protrudes down into the bottle. It's about 1/8" inside diameter and a slippery material.
Good luck.
Old Sep 08, 2009, 12:57 AM
ttuzun is offline
Joined Aug 2009
Covering even only half (maybe less) of the push rods with carbon fibre tubing (5mm out, 3mm inside diameter) worked wonders. now i have no bending and full control.
I realized one of the main wing screws (i fixed the other already) was lose because of the crash so i fixed that. I moved it around my parking lot on the ground and everything seemed fine. I couldnt lift it up because i didnt have enough space and i was in a hurry. I wont be able to try it for sometime. I am really excited though.
Thanks for the help
Discussion HOSS down for new problems mhills51 Mini Helis 6 Jun 20, 2008 09:31 PM
Help! New Problems-Blade CX Lizard Boy Coaxial Helicopters 11 Sep 02, 2007 01:47 AM
New Problems bombstopr BladeRunner Heli 3 Dec 14, 2004 07:03 AM
Dragonfly wobbles solved, new problems! hifi Micro Helis 10 Oct 09, 2004 10:12 AM
Monster Astro SS Maiden and new problems boomerace Parkflyers 13 Jun 23, 2003 04:16 PM
