Old Sep 02, 2009, 09:41 AM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Question
Twisty wing servos
Hi Everyone,
What servos are people using for twist wing aeroplanes?
I'm in the process of puting together a little (2M) twist wing thing and servo recomendations would be welcomed. I'm thinking digital and really 'play free' mechanicals but which to go for? Also, they can be standard size items.
Thanks for reading and hopefully suggesting,
S
Shedofdread is offline Find More Posts by Shedofdread
Old Sep 02, 2009, 10:49 AM
slopemeno is online now
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
Well, I have two HS-645MG's in my Shredder, which is a pitcheron.
That servo is probably at the upper end of its abilities on 4.8 volts, and at speeds above 100 mph (on radar) it does start to have a bit of lag/hunt. Banging turns on the frontside the'yre great, though. The price is really good considering the specs too.
For my next Shredder I'll want something with pretty massive torque/precision/speed. I'll probably go 6.0 volts too, since the plane needs a ton of noseweight it might as well be in the form of receiver batteries.
slopemeno is online now Find More Posts by slopemeno
Old Sep 02, 2009, 10:58 AM
Dale Thompson is offline
Find More Posts by Dale Thompson
F3J-F3K-F3F- What to Fly??
Dale Thompson's Avatar
Cupertino CA
Joined Aug 2005
JR 8717's
196 in oz and .07 speed on 6 volts
snappy!!
Dale Thompson is offline Find More Posts by Dale Thompson
Old Sep 02, 2009, 11:10 AM
Tailslide UK is offline
Find More Posts by Tailslide UK
Go fast, turn hard
Tailslide UK's Avatar
Berkshire, England
Joined Aug 2006
For high perfomance FS, go with a minimum of 2X wingspan. For example a 78 inch span would want 156 oz-in on each wing.
Look for digitals with two ball bearings. I prefer karbonite or synthetic gears to metal because of reduced slop. If the choice is nylon or metal, go metal.
Another consideration is your linkage on these type of servos. Us the heavy arms and helicopter type rod ends. There is no point having 200 oz-in of torque if the linkage flexes or breaks at 100.
Finally, make for abloute certain that your battery can handle the current load that two of these servos can impart. Big diameter cells of lower capacity are always better than AA's. Even on 5 cells, AA's can drop too much voltage if a wing binds a little at high G.
Let us know what you do!
Tailslide
Tailslide UK is offline Find More Posts by Tailslide UK
Old Sep 02, 2009, 11:14 AM
davekra is offline
Find More Posts by davekra
Milwaukee G Mitchell, Wisconsin, United States
Joined Mar 2002
JR 8611, http://www.horizonhobby.com/Explore/...ArticleID=1450
260 to 280 oz/in of torque
JR 8411, http://www.horizonhobby.com/Products...odID=JRPS8411R
150 oz/in
or for slop free (nylon) gears
JR 8411sa, http://www.horizonhobby.com/Products...dID=JRPS8411SA
150 oz/in
davekra is offline Find More Posts by davekra
Old Sep 02, 2009, 12:15 PM
bcc1955 is offline
Find More Posts by bcc1955
bcc1955's Avatar
San Mateo
Joined Aug 2004
I can not imagine needing nearly 200 oz/in torque servos for a 2M. I am running a pair Hitec HS5245s (about 60 oz/in) on my 60" Shrike. I bet even these would work on a 2M if one was seeking to make a lighter weight one. If you want a high wing loading or need more weight to balance anyway then going for larger servos makes a lot of sense. But I think it depends on your application.
I second point. It is standard practice to put very strong servos in pitcherons. When you think about it why is this necessary? I understand that there is a fair bit of mass to the wing but the resistance that needs to be overcome against the wind is probably LESS, since the air itself actually assists the rotation of the wing. I am guessing it is probably needed to hold the entire wing steady during high stress maneuvers like tight fast loops.
bcc1955 is offline Find More Posts by bcc1955
Old Sep 02, 2009, 12:42 PM
screamin' eagle is online now
Find More Posts by screamin' eagle
Chronic
screamin' eagle's Avatar
Pacific Palisades, CA
Joined Jul 2004
Bigger surfaces equal more force against the surface, not less.
screamin' eagle is online now Find More Posts by screamin' eagle
Old Sep 02, 2009, 12:44 PM
davekra is offline
Joined Mar 2002
For a TW plane I'd use the largest servos that are appropriate. Bigger servos give more holding power, stronger gears and power to overcome friction or binding.
Flight loads aren't where the servo is likely fail. Landings can sometimes be abrupt and smaller servos with weaker gears might give where a larger ones won't.
For the Vector2's I'm building I'll use one of the three I listed.
davidk
Old Sep 02, 2009, 12:49 PM
Cupertino CA
Joined Aug 2005
A Wingeron and a Pitcheron have very different servo loads.
Wingerons are more balanced on the servo load with each wing rotating with opposite loadings ( one goes up while the other goes down)
A pitcheron servo resists what ever twist loading each wing half experiences.
That's where the OMG torque is needed. As the mass of the plane increases and the speeds go up so do the loadings.
A 2M TW plane can weigh up in the 80oz range with Ballast for a big day.
I would want as much horsepower as possible on the wingrod when pulling out of a high speed dive.
Old Sep 02, 2009, 01:03 PM
c0dem0nkey is online now
Find More Posts by c0dem0nkey
I want it to go fast...
c0dem0nkey's Avatar
United States, OR, Bend
Joined Sep 2006
The engineer in me wants some sort of equation...
Wing area * wind speed * mechanical advantage / weight = torque
The test pilot in me says...just put somethin in and fly...
I think the Shrike is a good starting point to determine weight and wing span need a what type of servo.
I need help finding servors for
Snipe
Shredder
Spyder
I would be interested if people could chime in on what servos have failed for them in twisty wings.
c0dem0nkey is online now Find More Posts by c0dem0nkey
Old Sep 02, 2009, 02:44 PM
winchdoc is online now
Find More Posts by winchdoc
Yes, ALL your money...
winchdoc's Avatar
A hut in the woods in Oregon
Joined Jan 2003
I've always wanted better resolution in my TWF linkages. Every time motion in transferred, there is an opportunity for play in they system.
A common weak link is the servos themselves.
First is a good geartrain
My old kitbash hornet rotor has had several different sets of servos over it's lifetime. Each time I would replace a pair of servos, the plane flew better.
This was probably as much new gear trains as it was improved digital amplifiers.
I like those lighter nylon gear servos in my Shrikes.
More's theory (more is better)
I'm running the biggest digital servos I can fit in my performance TWF planes
So far they all seem to work equally well. the airtronics 94258's seem to be the quickest, although the JR DS8711's can follow the stick movement when you 'boink' the springs.
The other thing we want in TWF servos is some sort of holding power, especially for pitcherons, where the servo's performance shows up in ability to hold roll AND pitch headings without perceptable deadband. This is where digital servos get my nod, but with a bad (loose) gear train, the holding power is wasted, and centering is compromised.
Oh yeah, centering. Real important!
Be sure your servos and linkages return to the same zero point when bench flying them.
I mount Robart incidence meters on the surfaces and wiggle the sticks. The Robart meters are accurate enough to show any hysteresis in the control system.
WinchDoc
winchdoc is online now Find More Posts by winchdoc
Old Sep 02, 2009, 03:37 PM
Derbyshire, UK
Joined Aug 2008
Wow, thanks everyone for the input.
It may be 2M span but it's only 0.27m2 wing area and the section has a low pitching moment. Roll and pitch will be controlled by wing twist. Also the wing will probably (not decided whether to bother or not yet) be mass balanced.
The conclusion would seem to be digital, as large as practical, double ball race, good centring, fast and probably metal gears.
Indarotor - 80oz!!!!! I think your slope may be a little larger than the one I usually fly at. If it weighs half that I'll be dissapointed.
Thanks again and keep the info coming - I'm sure many will benefit from the input.
S
Old Sep 02, 2009, 03:54 PM
Go fast, turn hard
Berkshire, England
Joined Aug 2006
Thanks for posting more details of the model you are working on. Everything in the thread is spot on. Just remember that when you say pitcheron around here it cojures up a certain image in peoples mind.......
"Start with a solid block of high density Carbon fiber/epoxy matrix. Mill away everything that does not look like an airplane. Add ballast and radio......"
Tailslide
Old Sep 02, 2009, 04:11 PM
winchdoc's Avatar
Joined Jan 2003
SHHHhhhhhhhh!!!!
Old Sep 03, 2009, 05:34 AM
Go fast, turn hard
Berkshire, England
Joined Aug 2006
iiiiiiiittttttt!
Small Wing Servos Radek Z Slope 8 Oct 31, 2006 08:03 PM
FS - HiTec Sailplane wing servos snoozer Aircraft - Sailplanes (FS/W) 2 Aug 27, 2002 11:17 AM
Hitec Digital Wing Servos HS-5125 Andy W Electric Plane Talk 3 Aug 23, 2002 08:53 AM
Small Wing Servos Radek Z Electric Sailplanes 11 May 29, 2002 07:06 AM
Wing Servos Wiring Radek Z Power Systems 2 Mar 20, 2002 09:58 AM
