Old Sep 02, 2009, 06:14 AM
steveburns is online now
Find More Posts by steveburns
steveburns's Avatar
Chipping Norton, UK
Joined Jan 2005
Hacker B50 6L vs. FAI B50 6L, What’s the difference?
Anyone know what the difference is between the Hacker B50 6L and the Hacker FAI B50 6L other than the carbon can and just over £100 in price?
steveburns is online now Find More Posts by steveburns
Old Sep 02, 2009, 02:05 PM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
To the best of my knowledge, none...Could be that the FAI has better protection for high RPM?
WimH is offline Find More Posts by WimH
Old Sep 02, 2009, 02:26 PM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
I thought i read once that the "FAI" motors were the cream-of-the-crop. Picked for exceptionally low resistance when compared to its similarly wound counterparts, etc. But I could easily be mistaken...
Thekid3418 is offline Find More Posts by Thekid3418
Old Sep 02, 2009, 03:02 PM
Darron is offline
Find More Posts by Darron
Darron's Avatar
London
Joined Jul 2003
According to Hacker just weight.
Darron is offline Find More Posts by Darron
Old Sep 02, 2009, 04:02 PM
jjmouris is online now
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
Bearings?!
Magnet strenght?!
jjmouris is online now Find More Posts by jjmouris
Old Sep 02, 2009, 04:08 PM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
Someone on here did a side-by-side once upon a time. If I recall correctly, the amp draw on the fai motor was over 10% less than that of the standard motor, though I couldn't tell you how hacker attained the lower draw (he did mention that they had the same kv though, so it wasn't simply less revs)
la528it is offline Find More Posts by la528it
Old Sep 03, 2009, 10:06 AM
jjmouris's Avatar
Joined Aug 2008
10% less current would be equal to 10% less power for what you seem to say was the same RPM of the prop?
That would be saying it's 10% more efficient....... i doubt that is even possible.
If it was just the KV that was the same, if some of the other parameters changed you would see less RPM of the prop and this could be equal to the drop in power consumed.
I also know that one motor to the next will use more or less power on the same setup.
So basically this is not enough information to tell anything.
Old Sep 03, 2009, 11:54 AM
la528it is offline
la528it's Avatar
Joined Dec 2007
WHAT?!? One observation point is insufficient
I'm with you Joseph, but this is not a conclusion, only a single data point. Now that the curtain has fallen, you would think hacker would be more straightforward discussing the benefits of their fai motors; e.g. kv
Old Sep 03, 2009, 12:00 PM
steveburns's Avatar
Chipping Norton, UK
Joined Jan 2005
I have sent them a email but they are on holiday this week and it's always nice if you can find someone who has practical experience of the subject.
Old Sep 03, 2009, 12:12 PM
Darron is offline
Darron's Avatar
London
Joined Jul 2003
Hacker's response verbatim from the 27/4/09.
"the difference between both motors is only the housing. The FAI Version has a Carbon - housing. The normal version has a housing made of aluminium.
Therefore the FAI version is more lightweight. The price is also different. The FAI-version is more expensive."
Darron
*edit - on a B40 the FAI version is 10g lighter, not much but meant alot in the pre-LiPo era.
Old Sep 03, 2009, 12:20 PM
steveburns's Avatar
Chipping Norton, UK
Joined Jan 2005
Thanks Darron,
I was hoping that was the case.
Steve
Old Sep 03, 2009, 12:38 PM
Darron is offline
Darron's Avatar
London
Joined Jul 2003
I guess that's £10 per gram - They're in the wrong business .
I see people still buy them thinking that there is something special about the FAI version, then add nose weight.
I also suspect that the ali casing is better at dissipating heat and that Carbon/Epoxy is a good insulator.
Anyone want to buy my B40 11L FAI?
Old Sep 03, 2009, 01:15 PM
bigslopegrin is offline
Find More Posts by bigslopegrin
Wind Happens
bigslopegrin's Avatar
So California
Joined Feb 2009
the dif between a B50 and carbon vers. is 13 grams - otherwise identical.
bigslopegrin is offline Find More Posts by bigslopegrin
Old Nov 17, 2010, 05:11 AM
jjmouris's Avatar
Joined Aug 2008
Just got told exactly the same on the phone.
Don't think i will loose sleep over those few grams.
Joe
Old Nov 17, 2010, 03:45 PM
George Shering is online now
Find More Posts by George Shering
Scotland
Joined May 2005
If you pile it in it is easier to repair the FAI one one with epoxy and chopped glass fibre. Done it with a replacement rear plate. Don't know how you would fix a concertina-ed alu casing? There was a sugestion at one time that the FAI used higher spec Neodimium? hence lower rpm? But maybe not now.
George Shering is online now Find More Posts by George Shering
Discussion Raptor 50 SE vs Raptor 50 Titan - what's the difference? Steve Klyce Fuel Heli Talk 3 Feb 05, 2008 01:51 PM
Discussion Logictech 2100T w/servo vs. the HiTec version - what's the difference? GBR2 Mini Helis 2 Jan 30, 2008 12:19 PM
GWS-EDF-40 vs GWS-EDF-50. What's the difference? beemer Micro Helis 11 Jul 13, 2005 09:04 PM
Razor/Gearbox -VS- Direct Drive Outrunner (What's the difference)? mrebman Power Systems 9 Nov 19, 2003 10:28 AM
GWS R4-P -vs- GWR R-4N (What's the difference) mrebman Parkflyers 4 Dec 26, 2002 11:18 PM
