I just put another 4 batts through, definately no vert performance, but has no problem pulling through the air.
I'm getting 15 minutes easy flying, love the scale look, very easy to fly. I'm finding flaps are useless for land, she noses right up, and to fly slow she just wants to stall. I get the impression she needs to be heavier to justify flaps, but I have no doubt flaps would help to get off water, if ever I venture down that track. So landing, start the decent miles away with no motor & keep pushing her down, just keeps on gliding! Great scale flight very enjoyable
USA, VT, Newport
Joined Jul 2010
Thanks for the paint tips. I did some experimenting, and I can't eliminate the foam cell outlines without "creaming" it with light spackling first. I'm getting about 10 minutes on 3s 2200 mah battery running it down 1400 mah. I'm a bit of a novice, I've had trouble with eratic taxi on take-off. Everything else has been smooth. I love landing this bird, slides in slow and easy. I may have too much throw on the tail wheel. I play with the flaps and enjoy the affect. I used my transmitter to adjust a little elevator to counter the nose up with the flaps on. Also adjusted the flap throw quite low. I'll measure it if anyone wants the info. I encountered the cheesy two push rods hooking to the one servo for the elevator problem. I had to reaarange one of the horns by adding a shim to get the two sides going up and down the same amount (since they connect to different holes on the servo arm). Only other way around it would be to join the two push rods and attach to the servo through one connector. Don't know how to do that.
thanks, Len Len |
I had started an installation in the cessna, but have shelved that idea for now because the cockpit is too restrictive view for camera P&T. If later I try the floats, I'll then look at some interesting camera work heh heh, most likely a spectacular splash! I've started a rebuild on my P-51 Mustang, with 1500mm wingspan should be a fun short-ish distance fpv. SN555 camera Lawmate 900mhz 500mw Tx EzOSD with current sensor 8db patch antenna Scherrer UHF This worked well just as a naked cam/ Tx/ patch, but havent yet plugged in my Ez gear, I'll be getting it all together on the P-51. Never enough time to play... I've got another setup I'm hoping to get together by xmas: DX201 camera 2.4ghz 1000mw Tx Dual Rx's / diversity Dragon DOSD+V2 8dbi patch antennas Dragon UHF I have the Ez antenna tracker, I'm hoping to make this work with the Dragon gear, at least until the Dragon tracker is released. All this will be going on my new build Cularis, hoping for some degree of thermalling, even if it's power assisted. I'll start this build when my last remaining dragon gear arrives ![]() I have yet to try to upload photos onto RCG... Cheers |
I have read short distance can sometimes work, but you need to activate the 2.4 vid before the 2.4 rc, so the spread sprectrum can find clear freq's... but you are risking in the least glitches, I've read even total blockouts. Also try and set up your plane with rf sensitive components far and away from rf noisy gear. I've not tried sharing 2.4, I'm not going to risk it. That's why I bought 900mhz vid, so short distance fpv I can get away with 2.4 fasst rc. I'm in my fpv infancy, but I hope that helps you ![]() Cheers |
Joined Aug 2008
Just bought one. and the reviews here are scary...
First up, I noticed that mine might be a later revision from E-DOMODEL.
Both anchor points of the wing-support struts are aluminum. Motor mount is ply-wood. Small hatch is attached with magnets, but big hatch is secured with 2 hex screws. I primarily want to use this plane on floats, may I know what's the best way to make sure no water gets into the floats? Anyone ever tried cutting open the seams and filling with something like PU foam? ![]() ![]() Is it normal for motors to be mounted pointing to the right? |
Methuen, MA
Joined Sep 2002
Most planes need a bit of right thrust to counter thrust assymmetry from a clockwise-rotating prop. Look up P-factor. |
| Thread Tools | |
| Discussion E domodel Cessna 182 with floats | panamarenko | Foamies (Kits) | 0 | Apr 19, 2009 12:41 PM |
| For Sale Cessna 185 on floats... | JerryHall | Aircraft - Electric - Airplanes (FS/W) | 1 | Dec 21, 2005 11:18 AM |
| Cessna 185 with floats in foam project.. | JerryHall | Foamies (Kits) | 48 | Nov 09, 2003 02:29 PM |
| Colorful Cessna 185 | Ron Williams | Scale Electric Planes | 4 | Jul 17, 2002 02:12 AM |
| Source for GWS micro retractable l/g? | PeterH | Vendor Talk | 5 | Dec 18, 2001 11:49 AM |
