Old Sep 01, 2009, 06:40 PM
Maverick3n1 is offline
Find More Posts by Maverick3n1
Joined May 2009
Motors for dummies?
Where do we go to learn the basics? I consistantly see people talking about using a 11, 12, or 13t gear on their motor to spin the main gear on their heli, but what I need to understand is how to calculate which gear you will need to obtain the head speed you desire. I understand the conversion of taking the main gears number of teeth and dividing it by the motor gear's teeth, and that gives you the rotation ratio (Say 10-1 for example), but if I want a 3,000 RPM head speed, how do I know what motor I need and what battery it needs backing it to make it run at 30k RPM? How do I know what the amperage draw will be on the motor when it's running at 30k RPM, so I don't get an undersized ESC and smoke it? I'm looking into getting a T-rex 450 with a 430XL motor, as it seems to be highly recommended, but I'd like to understand why it's highly recommended, rather than just blindly trusting other's opinions. How do I know how much leeway I have (IE: How do I know if I'm running 3k RPM head speed on that motor with only 30% power, so I have a huge amount of torque I haven't accessed, so when I put it under load, it will maintain a 3k head speed? Obviously once I purchase it, I'd learn that simply by seeing what head speed it has when I spin up the blades, but I want to know how to calculate this stuff ahead of time so I can make educated decisions. I'm a nitro guy, still new to the electric erra, so I still don't know why I'd use a 2850kv motor over a 3500kv motor. How I know one will be more powerful than I need, and I should downsize a little to give me longer flights etc...
Lots of questions, I know. I'm sure someone probably has a link that will explain it all.
Maverick3n1 is offline Find More Posts by Maverick3n1
Old Sep 02, 2009, 01:41 AM
mxspode is offline
Find More Posts by mxspode
If it flies, I will crash it
mxspode's Avatar
USA, CO, Westminster
That is a lot of questions. I find this calculator to be very helpful when setting up a heli. Have a look and see if it answers at least some of your questions.
Rob...
mxspode is offline Find More Posts by mxspode
Old Sep 02, 2009, 08:40 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
* Get a current/Watt-meter, it will save you money and will more than pay for itself!
3$ diy Watt-meter:
http://www.rcgroups.com/forums/showthread.php?t=949923
* E-flight calculators, a compilation
http://www.rcgroups.com/forums/showthread.php?t=606703
* Choosing a power setup
http://www.rcgroups.com/forums/showthread.php?t=739069
http://www.wattflyer.com/forums/showthread.php?t=27019
For a rainy day ...
* Presentation: de-mystifying Electric Flight
http://www.rcaircrafters.org/The%20Electric%20Show.pdf
* http://www.ampaviators.com
-> Beginner Guide
* E-book: Everything You Wanted To Know About Electric Powered Flight
http://homepage.mac.com/kmyersefo/ev...ng-e-power.pdf
Corresponding discussion:
http://www.wattflyer.com/forums/showthread.php?t=31071
* Several Wiki's
http://www.wattflyer.com/forums/vbglossar.php
* http://www.ezonemag.com
-> Faq
* System wiring diagrams:
http://scriptasylum.com/rc_speed/_wiring.html
* LiPo pack and balancer cable wiring:
http://scriptasylum.com/rc_speed/_lipo.html
* Monthly Ampeer newsletter, on paper and online available. Excellent articles in the archives by e-flight pioneers Ken Meyers and Keith Shaw a.o.
* Brushless motor animations and simulations. Mostly outrunners but inrunners are just outrunners turned inside out, nothing fancy:
http://www.rcgroups.com/forums/showthread.php?t=216928
* Current, voltage, Watt, battery-types and -C-rating explained
http://www.rcgroups.com/forums/showthread.php?t=417868
* 'Dry' testing brushless motors after a mishap:
http://www.wattflyer.com/forums/showthread.php?t=35216
http://www.rcgroups.com/forums/showthread.php?t=240993
* How to repair a brushless motor
http://www.rcgroups.com/forums/showthread.php?t=1079423
* Motor_rewinding_101, about poles, winds, delta, star
http://www.gobrushless.com
-> knowledge base
-> basic overview (1-5)
* And I almost forgot, get a current/Watt-meter
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Sep 02, 2009, 09:49 AM
Joined May 2009
Rob...
That has some nice tools. How do you calculate how much amperage you'll be using? From what I read, that motor's max amperage is 35, but it's not going to be pulling 35 amps when it's hovering, but instead when it's doing heavy 3d. So how do I calculate what it's draw will be at hovering so I can get a better idea of what my flight times will be?
Old Sep 02, 2009, 07:41 PM
mxspode is offline
mxspode's Avatar
That calculator does this for you. Look at the upper right section. I have no idea how accurate those numbers may be. I set the timer on my DX6i for 6 minutes and land it then. That is not a full pack but enough for me. After that I need a break.
Rob...
Old Sep 03, 2009, 07:29 AM
Joined May 2009
That portion couldn't be accurate.. it says with a T-rex 450, running a 430XL 3500kv at 3030 RPM head speed with a 13t gear, on 3s 2200mah batteries, I'll get 10 minutes... Everyone on here is getting 4-6 mins, and my other bird that's running a less powerful motor gets 6 mins at 80% with only a 2400 rpm head speed.
Old Sep 03, 2009, 09:01 AM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
There is no way a calculator is going to be able to predict this stuff (at the level you want), unless someone fed in actual real world measurements of your exact setup. Even then I would expect differences.
So you should do it the way most people (I think) do it.
Take off and fly conservatively for ~2 to 4 minutes. Land and see what the battery has left. That will give you a starting idea. Then build up gradually. In the end you want to leave the battery with 20% reserves.
Or stick with what your buddies are telling you. That should already be in the ballpark of what to expect.
Alan Hahn is offline Find More Posts by Alan Hahn
Old Sep 03, 2009, 08:36 PM
mxspode is offline
mxspode's Avatar
Exactly. The calculator I linked is a tool and as I mentioned I am not to sure how accurate the results are. The tool gives you approximations based on a set of standard measurements. I have used it to figure out gearing and how much battery to use several times and I find it handy for that. Alan's point is well taken. I would never be careless enough to just go out and try to fly for ten minutes because a calculator say's I can.
By the way regarding Maverick's comment, I think the 10 minutes is based on draining your battery 100%. I usually only draw mine down 70-80%.
The calculator is a handy tool and good for basic info. I find it very useful.
Rob...
Old Sep 07, 2009, 05:21 PM
Joined May 2009
That was with an 80% draw. It has the option to choose what percentage you want to draw your batteries to.
How about this portion?
What is the difference between a 2 turn/winding, and a 3 turn/winding? How does that effect the performance of a motor?
Also, I have a motor that is 4 pole, and another that is 6 pole. They are both approx 2500kv, so what is the difference? Does one have more torque than the other?
Help! motors for DUMMIES brianjreed Power Systems 8 Dec 02, 2006 07:19 AM
Helpful Questions about cdrom motors for dummies (me) Bill Bergman Power Systems 2 Apr 05, 2004 07:11 AM
Need advice for motors for Velkom ME-110 Aero-BearAZ Scale Kit/Scratch Built 1 Mar 04, 2004 05:52 PM
RC helicopters for dummies procrastination inc Electric Plane Talk 4 Aug 01, 2001 11:27 AM
Motors for ME BF-110 Aero-BearAZ Power Systems 6 Jun 28, 2001 12:59 AM
