This thread is privately moderated by FlMuPhi198, who may elect to delete unwanted replies.
Old Sep 01, 2009, 02:35 AM
FlMuPhi198 is offline
Find More Posts by FlMuPhi198
Trader Rating: 2
United States, FL, Daytona Beach
Trader Rating: 2
For Sale
Thunder Tiger Mini Titan E325 ARF w/Motor, ESC, Gyro & Servos Cheap!!! 250!!!
Here I have a mini titan with tons of extra parts that I need to get rid of!!! Here are the factory specs. My package will include 2 extra main shafts, a main gear, tons of screws, servo gears, 3 flybars, 3 sets of blades (1 wood, 2 carbon) and tons of parts!!! Has a stainless steel flybar, carbon 325 blades, and a set of indestructible aluminum skids on it and it works perfectly!!! Here are the specs!!! The ESC has had tape put over to protect it and to reinforce connections along with the protection braiding on all open wires. The canopy has the tape on for extra visibility, and I have two tail fins, one still new in packaging and the blue one that was given to me, both included.
Thunder Tiger "Ripper" OBL 29/35-10H Brushless Motor
Ace BLC-40 ESC
TG-6100M Heading Lock Gyro & E-CCPM Mixer
Ace C1016 Servos and a C0915 digital high speed servo on the tail!
Ace 11.1V 3S1P 2200mAh Battery
Features
120 e-CCPM electronics cyclic collective pitch mixing
Rigid frame design eliminates flex during 3D maneuvers
Constant driven Auto-Rotation system
Interlocking 3 piece frame design
Rigid one piece-landing skid
Anti-Rotation swash guide
Belt driven tail system
Rear servo mount
Specifications:
Full Length of fuselage: 25.74"
Full width of fuselage: 4.72"
Total height: 8.3"
Main rotor diameter: 28.66" ~ Max 29.45"
Tail rotor dia: 6.14"
Gear ratio: 1:10 ~ 15:4.4
Full equipped weight: 26.50oz
The TG-6100M is an E-CCPM control board, which is combined with heading lock gyro and an E-CCPM mixer. The heading lock gyro helps to control the heli, and the E-CCPM mixer program makes it possible to fly the Mini Titan E325 with a normal 4 ~ 6 channel radio without CCPM mixing. The normal flying mode and aerobatic mode are established in the program, if you are using a 4~5 channel radio, you can do the normal flying, if you are using 6 channel radio, you can perform advance aerobatic flying as well.
Ace C1016 Servos
The Ace Hobby C1016 Ball Bearing Micro Servo is a reliable high torque servo comes with quality bearings and is made of high impact material. This servo works great on airplanes or helicopters. It has a J style connector that will have to be trimmed to work with Airtronics, Jr, and Hitec.
This is the Thunder Tiger "Ripper" OBL 29/35-10H Helicopter Brushless Motor. The Ripper OBL outrunner motors are designed for R/C electric helicopters. Thunder Tiger provides a brand new range of brushless motors to satisfy all your flying needs. Extremely high torque and mass of power for a motor of its size. With the cooling design, you can get the best efficiency out of motor.
Ace BLC-40 ESC
The Ace 8041-H Helicopter Brushless Motor ESC (BLC-40) is designed for the mini-sized electric helicopters. Capable of supplying up to 40 Amps of continuous motor current. Small and lightweight, with a large heat sink surface area. Perfect for the Thunder Tiger OBL series brushless motors. And for safety consideration, there are built-in safety features to prevent accidental motor startup when powering on.
I would like to get 250 for the whole package with all the extra parts, or best offer!!! Don't be afraid to offer, all I can say is no! I am looking for a 50 or engines and cash!!!
FlMuPhi198 is offline Find More Posts by FlMuPhi198
Old Sep 02, 2009, 04:26 PM
Trader Rating: 2
Trader Rating: 2
Up!!!
Old Sep 03, 2009, 09:34 PM
Trader Rating: 2
Trader Rating: 2
up!
Old Sep 06, 2009, 01:55 PM
Trader Rating: 2
Trader Rating: 2
Up!!!
Old Sep 23, 2009, 06:27 PM
Stenz28 is offline
Find More Posts by Stenz28
Trader Rating: 20
Utah
Joined Sep 2009
Trader Rating: 20
PM Sent
Stenz28 is offline Find More Posts by Stenz28
Old Sep 30, 2009, 06:10 AM
Stenz28 is offline
Trader Rating: 20
Utah
Joined Sep 2009
Trader Rating: 20
No? Have you sold this?
What I get for going to play army!
Old Dec 21, 2009, 07:17 AM
Zummy74 is offline
Find More Posts by Zummy74
Trader Rating: 4
United States, FL, Orlando
Joined Oct 2006
Trader Rating: 4
pm sent
Zummy74 is offline Find More Posts by Zummy74
Question Scale bodies that will fit on a thunder tiger mini titan E325? gukke Scale Helicopters 17 Feb 22, 2010 04:29 PM
Discussion My new Thunder Tiger mini Titan E325 oh_my_god Mini Helis 80 May 09, 2009 09:47 PM
Sold Thunder Tiger Mini Titan E325 w/ Kasama Head and Gy 401 frostygt Aircraft - Electric - Helis (FS/W) 4 Jun 08, 2008 07:29 PM
Discussion latest innovation by Thunder Tiger mini Titan E325 heli-hobby Micro Helis 5 Mar 14, 2007 03:06 AM
