Old Oct 09, 2009, 01:55 PM
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Nice build and info Don. This model doesn't look as bad as I thought it would. Look forward to your flight report and vid.
Jason
FresnoJay is offline Find More Posts by FresnoJay
Old Oct 09, 2009, 02:57 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Maiden is hopefully tomorrow. Weather has been goofy lately, tomorrow is 10 mph winds, today is no wind but rain
The Don is online now Find More Posts by The Don
Old Oct 09, 2009, 03:41 PM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
I know how that goes. Waited 2+ weeks to maiden my SU-34. lastnight just before dark conditions were perfect so it happened.
Best of luck on the maiden.
Jason
Old Oct 10, 2009, 09:13 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Well the flight lasted about 6 seconds. Gave it a toss and out it went and was slowly going down, I pulled full up and it slowly started to pull up but ran out of space. Broke the nose off right at the body. Fix is easy so will repair and try tomorrow possibly. Seemed quite nose heavy.
Don
Old Oct 10, 2009, 10:51 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
canards have wierd C/G's ...is the canard fixed?...if so pm C/N he had a prop job XB he could give you a good guess
AIR SALLY is offline Find More Posts by AIR SALLY
Old Oct 10, 2009, 11:01 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
The canard is fixed. I am going to measure it all up and run through my CG calculator and see what I get. It acted like a nose heavy model with not enough up elevator travel. If I had another 3 feet I would have made it but it felt like if it did go I would have had full up to fly level. I think longer elevons would have been a better choice.
Don
Old Oct 11, 2009, 11:20 AM
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Cool model...hope you have better luck today.
pdawg is online now Find More Posts by pdawg
Old Oct 11, 2009, 05:14 PM
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
I flew a Kangaroo converted to electric power.It took whole field to rotate,and only then because I hit a big bump and it bounced into the air.I flew it 2 passes holding mostly full up elevator just to keep it level.You know it had to land eventually..... Cut power and tried to setup for a landing,nose going down fast,and long time out of any more up elevator.It did make a nice plowed mark into the dirt.Too nose heavy can be almost as bad as to tail heavy sometimes....
fh64_lucky is offline Find More Posts by fh64_lucky
Old Oct 11, 2009, 05:15 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
It flies!!! Just got back from the park next to the house, the winds were about 3 mph. Have only a head cam video but it flies! I rechecked my CG and I was too far forward, so I moved the lipo back about 1.25" and set elevator to high rates to be safe and off it went. A few clicks of up and then it was OK. It actually grooves pretty good once it is going. Definitely needs more power for my taste, it dopplers at 70 mph. I would like it to be about 90 mph but based on a quick calculation I would need like 1200 watts The outlets seem to really rob the speed. Tighter turns look kind of funny as the nose goes out of the turn a little. So larger sweeping turns seem better.
Uploading to Youtube now will post link.
Don
Old Oct 11, 2009, 05:18 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
That was it. Not sure how I messed that up. The CG is suppose to be 17.9" from the TE of the wing, I was about 18.75"
Don
Old Oct 11, 2009, 05:20 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Here is the link
XB70 EDF Maiden Flight (3 min 42 sec)
Old Oct 11, 2009, 06:01 PM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Don, Sure you know this but helps to be repeated once in a while. Delta's are always safer to er towards tail heavy. Conventional always safer to er towards nose heavy. Learned this the hard way with my 117.
Waiting for video to buffer .
Jason
Old Oct 11, 2009, 06:13 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I almost toasted my F117 with a too far forward CG as well.
Old Oct 11, 2009, 06:20 PM
fh64_lucky's Avatar
Joined May 2005
1st thing...I could hear ya setting trim tabs,I know that sound all to well...
2nd,It looked really stable up there,did it roll axial?70mph is not to bad for that draggy airframe,it does not look slow up there anyways,and I see you discovered it has a nice glide ratio on landing.... Nice job as always Don! Joe
Old Oct 11, 2009, 06:21 PM
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Mine suffered 2 crashes before I got it right. My poor 117 has been through hell but still going strong and flying great. But the one thing is it taught me alot about C/G.
Just got done watching the video. She looks good and think your right with the loses at the exit nozzles. Wonder how hard it would be to mod in extra fan units? Say maybe 3 55's or 60's? Maybe 2 64's?
Jason
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 38 Jun 03, 2014 10:09 PM
Discussion Twin Little Screamers Xb-70 Build corsair nut Pusher Prop Jet Models 50 Feb 03, 2010 08:16 PM
Build Log XB-70 Valkyrie Build Log KFC Pusher Prop Jet Models 29 Jun 26, 2008 11:25 AM
Build Log first build log on rcg, 747 edf foam and tape Foamies (Scratchbuilt) 14 Jun 20, 2008 12:35 AM
XB-70 scratch build TeamSME Electric Ducted Fan Jet Talk 24 Jul 30, 2004 11:52 PM
