Espritmodel.com Heli Air
Old Sep 28, 2009, 09:08 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
OK more progress! I used some hot melt glue for the fan unit. The fan I used is a little shorter so I used the back end of a marker and pushed the foam to remove the small lip. I did the same on the EDF hatch as well. The wing panels were epoxied on with 5 minute epoxy. They do give lots of gluing surface which is nice.
Since I am flying with no retracts I only need a Berg 4 receiver and I installed it in the nose gear wheel well and placed some foam to hold it in place. I plan on putting a foam piece in the wheel well to block it off.
Don
The Don is offline Find More Posts by The Don
Old Sep 28, 2009, 10:09 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
All finished!!!!
The model balances perfectly with a Flightmax 4S2650 20C lipo. AUW is 32 ounces. I get just over 1:1 thrust to weight ratio.
Don
Old Sep 29, 2009, 11:06 AM
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Hey don, looks good! How about a profile shot? I want to see if it has the correct look from the side before I order one.
Joe 1320 is offline Find More Posts by Joe 1320
Old Sep 29, 2009, 01:07 PM
John 3:16 Still Applies
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Cool! Let her rip and let us know how it goes
Sammy70 is offline Find More Posts by Sammy70
Old Sep 29, 2009, 02:48 PM
Avoid The Ground!
Flexserve's Avatar
United States, FL, Lutz
Joined Sep 2008
Yup me too as I was thinking the nacelles would have to be enlarged to fit the 64mm edf... giving a thick engine nacelle from the side.
Flexserve is offline Find More Posts by Flexserve
Old Sep 29, 2009, 05:00 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Here is a side view.
Don
Old Sep 29, 2009, 05:17 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Te EDF is centrally located on the bottom of the fuselage then the outlet open to a larger chamber with the six outlet nozzles.
I did some quick calculations:
fan sweep area: 4.87 sq inches
inlet area: 8.31 sq inches
exit area: 5.24 sq inches
so inlet is 170% FSA and the exit is 107%
Don
Old Sep 29, 2009, 11:25 PM
Avoid The Ground!
Flexserve's Avatar
Joined Sep 2008
Don
Thanks Don!
Old Sep 30, 2009, 11:22 AM
Joe 1320's Avatar
Joined Feb 2006
Don, Thanks for the side shot!
Old Oct 05, 2009, 11:22 AM
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Fly her yet?
Old Oct 05, 2009, 11:41 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Nope, winds were 15-20 mph this weekend
Don
Old Oct 05, 2009, 07:42 PM
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Tell me about it But this evening was grand!@!
Old Oct 05, 2009, 08:54 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
what are your power numbers with that 70mm fan ? plane looks sweet good luck with the madien.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Oct 05, 2009, 08:59 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Starts about 700 and settles to about 650 watts. Should fly reasonably well.
Don
Old Oct 09, 2009, 12:14 PM
skunkworks
Dark Angel's Avatar
United States, CA, Clovis
Joined Apr 2008
Where did you get your airframe?
Dark Angel is offline Find More Posts by Dark Angel
Discussion Twin Little Screamers Xb-70 Build corsair nut Pusher Prop Jet Models 50 Feb 03, 2010 08:16 PM
Build Log Nitroplanes Lander 70mm F9F Panther EDF Build Log and Review The Don Foamy EDFs 37 Oct 24, 2009 07:43 PM
Build Log XB-70 Valkyrie Build Log KFC Pusher Prop Jet Models 29 Jun 26, 2008 11:25 AM
Build Log first build log on rcg, 747 edf foam and tape Foamies (Scratchbuilt) 14 Jun 20, 2008 12:35 AM
XB-70 scratch build TeamSME Electric Ducted Fan Jet Talk 24 Jul 30, 2004 11:52 PM
