Old Jun 15, 2001, 11:07 PM
Joe Elston is offline
Find More Posts by Joe Elston
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
How to make the new APC Electric props fit your adapter
HI I have found that all my E prop APC's are much too thin for my prop adapters and I cant tighten down the prop screw on the adapter.Has anyone else had this problem? IF so can you let me know what the fix is.
Thanks Joe
Joe Elston is offline Find More Posts by Joe Elston
Old Jun 15, 2001, 11:16 PM
Ed Lyerly is offline
Find More Posts by Ed Lyerly
Recruiter - 60 Amp Club
Ed Lyerly's Avatar
Rutherfordton, North Carolina, United States
Joined Apr 2001
Joe,
I had the same problem, my solution was just to scrounge up enough of the appropriate size washers to make up the thickness difference.
Ed Lyerly is offline Find More Posts by Ed Lyerly
Old Jun 15, 2001, 11:20 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Had exactly the same problem.. finally scrounged up a few aluminum washers to fill the gap.
Frustratingly though I've found these props to be less than expected performance/price wise.. I won't be buying more.
Bare is offline Find More Posts by Bare
Old Jun 15, 2001, 11:27 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Yeah, I think I'll stick with the MAS/Grish props myself.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Jun 15, 2001, 11:30 PM
Smitty is offline
Find More Posts by Smitty
Castle Rock, Colorado
Joined Jun 2001
I used the outer plastic stopper, about the diameter of a quarter, from one of my glow fuel tanks and it works great. Made from plastic and adds no weight and is about 1/8" thick. Tom
Smitty is offline Find More Posts by Smitty
Old Jun 15, 2001, 11:33 PM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Thanks Guys, I think I will use the Gruapner cam props and maybe some MAS wood props. If the performance is not what is expected.
Joe
Old Jun 17, 2001, 01:56 AM
BEC is online now
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
The early batches of the APC thin-E props had a very thin hub (and the TE of the blades going well aft of the hub face). Current production all have a thicker hub and the blades project back little or not at all, so a spinner can be fitted.
Bare, what was you application? The MA-E props may work better than the APCs at really low RPMS (say 4000), but beyond that the APCs I find much more efficient. You may need to go up a bit in size, though. I was running a 12X8 MA on the LT-25 and now use an APC-E 14X7 at just slightly higher current draw. MUCH better climb and overall performance is similar. I need to try a 13X10 on that power system.
Just a happy customer - I've gone completely over to APC-Es on my current fleet.
BEC is online now Find More Posts by BEC
APC electric props vs MAS electric props Rod Electric Plane Talk 11 Dec 01, 2001 07:26 AM
Using APC electric props on standard prop adapters Joe Elston Electric Plane Talk 4 Oct 17, 2001 09:39 AM
APC electric props - Strong? climber Sport Planes 6 Sep 18, 2001 02:04 PM
K prop & K eff for APC Electric Props (8x6)? BEC Electric Plane Talk 1 Jul 09, 2001 12:16 AM
Will APC Folding props fit directly on a SP400? Foxtrot Electric Plane Talk 5 May 30, 2001 10:32 PM
