Old Apr 16, 2003, 03:03 AM
jackman, tomer
jackman, tomer
Guest
n/a Posts
[RCSE] VAC pump made easy
Here is a much cheaper and easier way (photo will be made available upon
request...):
Go to Wal-Mart and buy a tire inflator pump. $9.99.
On the way home grab a vacuum sensor (mounted on the distributor) from an
old German car at the junkyard ($1)
Some plastic tubing and a spring at the home depot ($5 max) and a micro
switch at Radio scrap ($1.99 !!!!).
Find the air intake and hook it all up together (that's easy, isn't it?).
Pulls over 30", no problem, and with a micro switch and sensor ,I can set it
up for 18" (or any other value) to keep the foam from collapsing. Also good
for molds ($ priceless).
Sure, it makes some noise and requires a 12V power supply, but when it
cycles over night, working off of the battery charger or an old car battery,
it's insignificant. And if anything can break, it's just a $9.99 pump
replacement....
Tomer
MA
RCSE-List facilities provided by Model Airplane News. Send "subscribe" and "unsubscribe" requests to soaring-request@airage.com. Please note that subscribe and unsubscribe messages must be sent in text only format with MIME turned off.
Ed Berris
Ed Berris
Guest
n/a Posts
Re: [RCSE] VAC pump made easy
You know, that's a very inventive idea and the price is really right.
For those that want something ready to use right out of the box I have a
system that costs $150.00 but it sure is nice, reliable, heavy duty, easy to
use etc.
I'll forward a picture to you upon your request) If you are interested let
me know.
Ed
> request...):
it
good
battery,
> replacement....
> Tomer
> MA
MIME turned off.
Silicone hinge made easy. gator Electric Sailplanes 4 Feb 06, 2003 07:53 AM
Source for cheap vac pump? Far4nugn Electric Plane Talk 11 Mar 09, 2002 06:46 PM
