Old Aug 30, 2009, 06:30 PM
Cotton17 is offline
Find More Posts by Cotton17
Joined Aug 2009
Help!
Mini super cub battery or charger problem
Hi I'm new to the forums and am just wanting some help with a problem I have with my mini super cub. After flying it last I left the battery connected to the plane , I then went to charge the battery and the charger won't charge it. When you connect the battery to the charger it is supposed to flash red meaning it is charging, then stay red when it is finished, but instead it blinks 3 times then stops. So I don't know if it is the battery or the charger. I did read in the manual that you are supposed to disconnect the battery after using the plane, would leaving the battery connected damage it? So is it the charger or the battery? Thank you for any responses
Cotton17 is offline Find More Posts by Cotton17
Old Aug 30, 2009, 06:37 PM
Challenger 413 is offline
Find More Posts by Challenger 413
Challenger 413's Avatar
Dickinson, Tx.
Joined Sep 2004
Yes, leaving the battery connected to the plane(or to the ESC) will cause it to be drained. What type of battery is it?
Challenger413
Challenger 413 is offline Find More Posts by Challenger 413
Old Aug 30, 2009, 06:47 PM
Cotton17 is offline
Joined Aug 2009
It's a 300mah lipo
Old Aug 30, 2009, 07:09 PM
Dickinson, Tx.
Joined Sep 2004
Verify what the voltage is with a D/C voltmeter.
Challenger413
Old Aug 30, 2009, 07:17 PM
Cotton17 is offline
Joined Aug 2009
The voltage of what the battery or the charger? The battery is 7.4v and on the charger it says input-240v AC. Output-12v DC
Old Aug 30, 2009, 07:29 PM
Dickinson, Tx.
Joined Sep 2004
Use a D/C voltmeter and measure the pack voltage, I am thinking the voltage is too low for the charger...
Challenger413
Old Aug 30, 2009, 07:34 PM
Cotton17 is offline
Joined Aug 2009
I don't have a voltmeter to check it so would it be best to just buy a new battery or is it the charger not having enough volts to charge the battery?
Old Aug 30, 2009, 08:33 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
You really do need to get a voltmeter. It sure sounds like the pack was discharged to the point that the charger will not recognize it.
Take a look at this thread. In that case it was a 3 cell LiPo, but the same procedures apply to your 2 cell.
Bill
ebill3 is offline Find More Posts by ebill3
Old Aug 31, 2009, 05:15 AM
Cotton17 is offline
Joined Aug 2009
Thanks for the help I'll see if I no anyone who has a voltmeter I could use and if not I'll go to my lhs for help
Old Aug 31, 2009, 04:04 PM
Cotton17 is offline
Joined Aug 2009
I got hold of a voltmeter of a friend and measured the battery and it read about 4.5v when on the battery it says 7.4v is this good or bad?
Old Aug 31, 2009, 05:01 PM
ebill3 is offline
ebill3's Avatar
Bad.
After use and a short rest period, ought to be 7.6 volts or so.
OK, the charger will not charge the pack until it sees some minimum voltage - normally about 3 volts per cell. If you can get the battery back up to about 6 volts or so, it will probably charge.
Bill
Old Aug 31, 2009, 05:06 PM
Razor_Racer is offline
Find More Posts by Razor_Racer
Actively makin humans obsolete
Razor_Racer's Avatar
Northern Virginia
Joined Jul 2007
My CX2 lipo experienced the same thing. I used a 6 cell pack from a rc car, and very very quickly applied short bursts to the lipo to get it to an acceptable voltage for the charger to charge. I did notice a large decrease in power though, and there is risk of an exploding lipo
Razor_Racer is offline Find More Posts by Razor_Racer
Old Aug 31, 2009, 05:36 PM
Cotton17 is offline
Joined Aug 2009
How do I charge it up to about 6volts? as when I connect the battery to the charger it won't charge
Old Aug 31, 2009, 05:49 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
You use an NiMH charger and plug it in for about 2 minutes, at the appropriate charge level. Then take it off, and plug it into the charger. NO guarantees it will come back to life, but it's worth a shot.
Also, a fully charged lipo will be 4.20 volts per cell, or in this case 8.4 volts
Xpress.. is offline Find More Posts by Xpress..
Old Aug 31, 2009, 05:50 PM
ebill3 is offline
ebill3's Avatar
See post #8.
Help! Hobbyzone Super cub or Mini Super cub? fuzzynorman Beginner Training Area (Aircraft-Electric) 10 Sep 09, 2013 05:49 PM
Discussion Charge Rate For Mini Super Cub Battery daydreamjay Electric Plane Talk 9 Apr 14, 2009 11:32 AM
Discussion MINI Super Cub or Slo V for small field and wind resistance? insoc Beginner Training Area (Aircraft-Electric) 2 Jan 08, 2009 02:11 AM
Discussion Super Cub or Mini Super Cub 98PaceCar Beginner Training Area (Aircraft-Electric) 10 Jan 06, 2009 01:04 PM
Found Hobbyzone Mini Super Cub RTF $100 or trade 34Ford Aircraft - Electric - Airplanes (FS/W) 8 Jan 03, 2009 10:32 AM
