Old Aug 30, 2009, 04:48 PM
windstar130 is offline
Find More Posts by windstar130
Joined Aug 2009
sr-71 gear and poor support
I purcjased the sr-71 and the f-86 and have had nothing but problems. The sr-71 retracts do not work and the gear just flops around. I have called and emailed many times with no suport. I had to just give up and bite the loss.
windstar130 is offline Find More Posts by windstar130
Old Aug 30, 2009, 05:23 PM
louisiana boy is offline
Find More Posts by louisiana boy
Joined Mar 2009
Wow they just got 22 new phone lines. Surely they all were not busy when you tried to call.
louisiana boy is offline Find More Posts by louisiana boy
Old Aug 31, 2009, 02:14 AM
f355 is offline
Find More Posts by f355
Grant
Alberta
Joined Jul 2009
whats the matter with the retracts I have bought two sr 71's and they worked ok
Are you using the stock transmitter or one of your own?
Be very carefull if using the tsock one because the plane is very twitchy on stock settings.
Just my 2c
f355 is offline Find More Posts by f355
Old Aug 31, 2009, 10:50 AM
KCV6 is offline
Find More Posts by KCV6
lurking in the HOLE :)
KCV6's Avatar
Australia, SA, Edinburgh
Joined Aug 2009
weather it works or not posting the same thing twice is a waste of bandwidth. So whats wrong with the f-86?. hey Lou same old constructive passive agressive.
KCV6 is offline Find More Posts by KCV6
Old Aug 31, 2009, 11:57 AM
Joined Aug 2009
sr71 gear
The gear is dead and will not move at all. I can move them physically ok. Nose wheel steering works fine and Yes, I am using the stock transmitter.
Old Aug 31, 2009, 08:16 PM
KCV6 is offline
KCV6's Avatar
Joined Aug 2009
dead gear
So the gear is not rigid in any position, as in you can freely move it around and it just hangs down? is there any noise at all when attempting to operate the gear? Did the gear work at all at any time? I understand you are frustrated and not pleased but with a little more info we may be able to help out.
Mark
Old Aug 31, 2009, 08:57 PM
f355 is offline
Grant
Alberta
Joined Jul 2009
I would try removing the linkage from the gear servo and then maybe plug that servo into the receiver port for the steering and if it works its a possible receiver problem if not it could be the servo or the wires from the servo. In my experience servos usually do not just quit they always make some kind of noise. Keep in mid these planes are built fairly cheap and require maintanance. Yesterday after my third flight the steering servo fell off. The little screws holding the braket to the shock on the gear stripped so I used a dremel bored it out larger and replaced with a larger screw. If you have had no problems with your steering servo I would pull the bolts and locktite them so they do not strip like mine did.
Old Sep 01, 2009, 04:21 PM
banana hobby is offline
Find More Posts by banana hobby
banana hobby's Avatar
United States, CA
Joined May 2008
I apologize for not answering you sooner. I did not see this post. Can you see if you are getting any power to the retract servos? It is rare to have both nose and main retract not operate. In this case, there is usually a simple explanation. One, check to see if the Y connector is plugged into the servos in the correct polarity. Next the polarity connected to the receiver. Please let me know if there is any thing I can do for you.
Pete
banana hobby is offline Find More Posts by banana hobby
Site Sponsor
SR-71 for EDF 50 (Closer than we might think) Thomas B Electric Ducted Fan Jet Talk 187 Feb 22, 2011 11:56 PM
Discussion sr-71 gear and poor support windstar130 Electric Plane Talk 2 Aug 12, 2009 02:15 PM
SR-71 anyone? steve neill Electric Ducted Fan Jet Talk 71 Oct 08, 2007 08:34 AM
hobbylab sr 71 bushpilotx1 Sport Planes 7 Mar 06, 2002 01:53 AM
Electrics that can outperform the SR-71? SchiessCo Electric Plane Talk 4 Jul 30, 2001 09:44 PM
