Old Aug 30, 2009, 11:15 AM
orlando florida
Joined May 2009
antenna tracking with rssi voltage
has anyone thought about antenna tracking with the rssi voltage? has it been done? Ive searched the forums and found nothing. but couldn't i just make a circuit that uses servos for pan and tilt and points the antenna in the direction that gets the highest rssi voltage? or is that harder than it sounds?
atari7202 is offline Find More Posts by atari7202
Old Aug 30, 2009, 12:44 PM
QUIKSILVER's Avatar
UK
Joined Sep 2002
Noob question here,
RSSI is where the signal is displayed or recorded in regards to how well in % the Rc link is?
QUIKSILVER is offline Find More Posts by QUIKSILVER
Old Aug 30, 2009, 01:07 PM
Aberdeen, Scotland, UK
Joined Dec 2007
Highly innacurate I would have thought. Plus you'd be asking the antenna to continually move off course to see if the signal was any stronger elsewhere.
Ian.
IanJ is offline Find More Posts by IanJ
Old Aug 30, 2009, 01:38 PM
orlando florida
Joined May 2009
would not, it prob would use a voltage comparator to follow the highest voltage, which means follow the highest voltage once it gets below a certain point have it scan for it, so no one has done this?
Old Aug 30, 2009, 02:18 PM
It just keeps getting better!
Blue Sky's Avatar
Eureka, CA
Joined Oct 2002
This is a well tread path on the RC-Cam forums.
http://www.rc-cam.com/forum/index.ph...20rssi__st__80
Blue Sky is offline Find More Posts by Blue Sky
Old Aug 30, 2009, 02:23 PM
Canada, ON
Joined Jan 2009
It can be done but IanJ is correct the antenna has to be sweeping all the time. It needs to sweep a 30 degree limit (relative to the plane) as to not totaly loose your signal. Using a track and hold compartor setup which will slow down (or shorten the sweep rate) of the antenna at the strongest signal. Good for long distance but within say 100 meters and at speed not so good.
Martin Y is online now Find More Posts by Martin Y
Old Aug 30, 2009, 02:47 PM
MelihK's Avatar
Istanbul/Turkey
Joined May 2008
Hi Atari,
Yes i'm working about this project already. If everything is ok, i will produce a device in 2 month. My friend developing search patterns for military rocket guidance. I will use some similar search algoritms for tracking.
If i finish somethings i can share here.
MelihK is offline Find More Posts by MelihK
Site Sponsor
Old Aug 30, 2009, 08:15 PM
Melbourne, Australia
http://video.aol.com/video-detail/mo...nna/1014107601
garris2 is offline Find More Posts by garris2
Old Feb 05, 2011, 12:33 PM
RC pilot by soul
Joined Apr 2005
Can anyone tell me how to check RSSI voltage on a Futaba reciever for example ?
i3dm is offline Find More Posts by i3dm
Discussion EzOSD with EzTelemetry, Live Google Earth, and Antenna tracking! hartwig Video Piloting (FPV/RPV) 3004 Apr 21, 2013 08:41 AM
Discussion Lince 2.0(Lynx 2.0)and DakarOSD 2.7b Tracking Antenna +Telemetry with video signal alastur Video Piloting (FPV/RPV) 210 May 17, 2011 01:50 AM
Discussion Pan/Tilt Antenna Tracker with OSD & Google Earth tracking IanJ Video Piloting (FPV/RPV) 20 Dec 29, 2009 11:01 AM
What's a powersupply with enough voltage for... touser Batteries and Chargers 7 Dec 18, 2002 09:47 AM
Help with 480 Voltage Selection craigw7272 Foamies (Kits) 7 Oct 21, 2002 05:54 PM
