Rex,
The wings are cut from 050 durobatics with about 10mm extra at the leading edge. I carefully score and compress the foam where I need to fold the LE over from the back side. If I don't get it compressed thin enough then the foam will crack when folding. Then, I paint UHU Por on the underside of the LE where it will fold over and fold back on itself, weight it with a smooth board with a brick on top of it, and let it dry. I curve the wing panels over a 1.5 inch dowl with my hands till I get the curve I want. I elevate the wing tip, line the other up with the edge of my workbench, and sand the end of the wing where they will joint together. This requires some repeating until the two wing panels will match up perfectly where they doing with one elevated. The, I apply UHU Port to one wing edge, press to the other wing panel, and let dry on the workbench. Note that this wing is not strong enough on its own and needs bracing via CF rods like my MacZip has. http://www.rcgroups.com/forums/showp...2&postcount=78 Hope this helps. Gordon |
Fairfax Station, VA
Joined Jan 2004
Hi Gordon,
I am building a similar model for the Climb and Glide (1930s Viking - originally for CO2 now electric and Depron). It will be quite crude compared to yours. I have been fiddling with design and build of a Cassutt for the Pylon race too. I am on the fourth build attempt. First with elevons, second with rudder and elevator, and third with rudder only. None flew right. I cannot get the wing angle of attack and adequate control using JMP and actuators. I hope to have something to compete or at least have some fun flying in the dome. See you there. Al |
| Thread Tools | |
| Discussion Need advice on micro Miss America old timer project for KIEF '09! | SixDeuces | Indoor and Micro Models | 15 | Feb 23, 2009 06:53 PM |
| Discussion New (kind of) thermal duration ship for 2009. | T.D. | Thermal | 12 | Feb 18, 2009 03:48 PM |
| For Sale Buzzard Bombshell for sell ! | fred greer | Aircraft - Fuel - Airplanes (FS/W) | 3 | Nov 13, 2008 03:03 PM |
| Build Log A Boomer Bus for KIEF | del | Indoor and Micro Models | 18 | Oct 15, 2008 06:11 PM |
| Duration Battery for Trex? | kenmalecki | Mini Helis | 5 | Dec 15, 2005 04:10 PM |
