Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread
THE BIG Easy Fly THREAD WARNING!WARNING!WARNING!WARNING!WARNING!WARNING!WA RNING TONS OF BUILD PICTURES! DIAL UP USERS, GO MAKE A SANDWICH... WARNING!WARNING!WARNING!WARNING!WARNING!WARNING!WA RNING For those that do not know, the Easy Fly Powered Glider is a Chinese version of the Easy Glider accept it comes with a brushless motor and ARF (Just add RX/TX). Quite a bit larger than the Easy Glider so it can hold more weight.. Ill try and detail every thing I did to make this inexpensive bird FPV ready. 0: The Manual... You gotta love Direct English Translations of Chinese ![]() 1: My Easy Fly Powered Glider Arrived from Hobby King $70.00 US! 2: I open the box to find it well packaged. ![]() 3: The Shipping box was slightly larger than the Easy Fly itself so there is plenty of room for accessory orders should you include them. ![]() 4: I Remove the Easy Fly from the box to inspect the goods. ![]() 5: Immediately I measure the cockpit to get an idea of what I'm up against. ![]() PLENTY OF ROOM! ![]() 6: Hrrrmmmm... Uh oh, I pop the hood to find they filled the space with Servo's and foam.... ![]() ![]() I have some work to do finding the optimal location for battery and OSD gear. The Bottom is wide enough I may be able to cut out an opening to fit a 5000mAH 3S LiPO HERE IS THE ADD... Gives you an idea of the end product. ![]() Specs. Length: 1210mm WingSpan: 1960mm Wing Area: 38.40dm2 Flying Weight: 960g Wing Load : 25g/dm2 Flying Speed : 12m/s Included ; Motor : 950kv Brushless outrunner ESC : 18A Servo : 4pcs Required ; Battery : 11.1V 1300mah ~ 1800mAh 20C 2S Receiver: Your own TX & RX Price $69.99 ($40 shipping = $110 FPV Foamy platform!) It's FOAMZILLA! Search after search on RCGROUPS to only find reviews but no fpv build shots! I know its similar to the Multiplex Easy Glider just WAY BIGGER but com'mon not even one Easy Fly build thread? My Build: 1. My CG is 79mm back from the Leading Edge of the wing. 2. Avionics (RX,OSD), in the belly under the wing 3. GPS above the wing, OSD, etc? 4. 2650Mah 3S LipO Battery in custom cut belly hatch closer to the CG point 5. Any 900-1200kv motor will give you 45+ degree climbs with a 10x8 or larger prop. 6. Stock Servos (ATENTION: They center poorly and one Aileron servos is a custom reverse servo so it cant be replaced without a servo reverser purchase.) 7. Started using a Corona RP6D1 to control it, but I needed mor channels for OSD operation so Im running a Corona 2.4Ghz DSSS 8CH RX now. |
Pdemon - it's a great question. I have absolutely no idea whether it should have up-thrust or down-thrust. I must admit that on the basis of this, I was going for upthrust.
Fortunately, if I've got it wrong, the aluminium pylon bends easily! Views, anyone? Simon |
" Good performance motor for 500g - 1000g weight plane. ...... EagleTree data logger & Hyperion Emeter. Propeller Volt Amps rpm Epwr Speed Thrust ETA. APC E 9x4.5 10.98V 15.50A 9652rpm 170.19W 66km/h 910.8g 74 APC E 9x6 10.86V 18.87A 8928rpm 204.93W 82km/h 914.6g 67 APC E 10x5 10.86V 19.18A 8928rpm 208.29W 68km/h 1128.2g 79 APC E 11x5.5 10.83V 18.45A 7763rpm 199.81W 65km/h 1153.2g 79 APC SF 11x4.7 10.56V 27.48A 7190rpm 289.91W 51km/h 1469.8g 65 If that is the EASY FLY cockpit there sure isn't much room Looks like I'll be cutting Styro 1st day for the FPV gear and battery. I went conservative on the motor because I want to get at least 1 hour of flight time out of her. What would you folks recommend for a battery? |
Cralis - yes I think I saw on Reckless Bill's "set up" video that he did a hatch on the bottom of the fuselage, with a cover attached by velcro. Maybe it was not the exact same plane.
SoMoney - I changed over from the stock motor (underpowered for FPV) to a Turnigy 35-30 1100kv that I expect to draw btwn 10 and 20 amps on a 10x5 - so I will try running with a 2200mAH 20C 3S to start with, but I'm flexible. cheers, Simon |
| Thread Tools | |
| Discussion Ritewing Zephyr FPV build thread | webdr | Video Piloting (FPV/RPV) | 436 | Feb 01, 2011 11:01 AM |
| Discussion Official F4d Skyray By 6mm Fly Rc Build Thread | corsair nut | Pusher Prop Jet Models | 944 | Aug 12, 2010 12:20 PM |
| Discussion From Plane to HELI FPV (Build Thread)! | jetstreaming | Video Piloting (FPV/RPV) | 13 | Aug 12, 2009 01:40 AM |
| Yippee! Easy Pro "Ozzie" Build thread | flybaby2000 | Slope | 53 | Jan 13, 2008 06:53 PM |
| An easy Fun to build / fly w Plantrco system | rodair | Indoor and Micro Models | 1 | Sep 16, 2005 06:56 AM |
