Brunswick, OH
Joined Nov 2005
Remzibi OSD (Poor Man's OSD) integration with ArduPilot
Update 8/15/2010: Please note, this thread has been largely superceded by http://www.rcgroups.com/forums/showthread.php?t=1234310 which includes this same information and a newer version of the ArduPilot firmware. This project is a moving target because I don't think that the ArduPilot project will ever stop development. Please refer to the newer thread for slightly more up-to-date information.
--------------------------------------------------------------------------------------- This thread is a place to discuss the integration of Remzibi's OSD (Poor Man's OSD) and the ArduPilot Opensource Autopilot project. It assumes you're already familiar with Remzibi's OSD and the OSD configuration tool and does not contain any troublshooting on getting your OSD setup and programmed for the first time. The functionality below also requires a minimum firmware version on Remzibi's OSD of 1.60. NOTE: So far I have had almost no success getting anything to work with the ArduShield. I am unable to upload firmware, get GPS lock or do much of anything with the ArduShield attached. Everything below assumes you are not using the ArduShield. NOTE: The instructions and software below have been tested and are intended to be used with ArduPilot V2.3.1 source code. What you need to get started: Rembizi's OSD: ~$110 (Contact Remzibi about ordering). The OSD comes with a the GPS unit and a USB to serial programming cable. For more information about the OSD, please visit http://remzibi.happykillmore.com. ArduPilot: $25 ArduShield (Optional - Has pressure sensor for airspeed and throttle control): $47 FTDI Cable: $20 Bind Plug (for later use when you're actually flying): $1.25 XYZ Sensors: $100 Several rows of Straight Headers: $0.69/ea Female to female jumpers (you might want to get a bunch of these): $3/ea Optional (will help with debugging): Servo Tester: $8 EasyCap (video capture device): $11 Assembling the ArduPilot: I recommend connecting the VCC pins together so the FTDI cable will power both the ArduPilot and OSD during your testing. You will need to solder the straight headers in place and connect the "MUX" wire if you want the Ardu to control your throttle. Please note that it takes 47+ straight headers to complete the ArduPilot board and 18+ straight headers to complete the ArduShield so please buy accordingly (one will not be enough)... You can tell I have soldering skills when you can see a strand of wiring hanging out of the insulation and a bunch of dog hair stuck in the left over flux I never got off my board.... My board also has a few rounded corners from some road rash while testing on my 50MPH Mini-T Programming the ArduPilot: The full ArduPilot manual can be found here: http://docs.google.com/View?id=ddjmqgw3_43gm6gvggf . Below is a brief overview of what software you'll need to download and modify to get the Ardu sending information to Remzibi's OSD. It might not contain all the details of getting the Ardu up and running. 1) Download and unzip the Arduino development environment. http://www.arduino.cc/en/Main/Software 2) Download and unzip the ArduPilot firmware sourcecode (Current is ArduPilot23.zip). http://code.google.com/p/ardupilot/downloads/list . 3) Next download my copy of the ArduPilot source and overwrite the files from step #2. http://www.happykillmore.com/Softwar...emzibiMods.zip 4) Make sure to copy the easystar.h file from step #2 into the arduino-0017\hardware\libraries\ArduPilot as explained here: http://docs.google.com/View?id=ddjmq...67775363847613 5) Open the Arduino 17 development environment and click File Open and browse to the folder in step #2 and open any of the files contained in that directory. 6) Connect your FTDI cable as shown below (you don't need to connect anything else right now) 7) Click Tools, Serial Port and make sure you have selected your correct COM port for the FTDI cable. 8) Click File, Upload to Board (CTRL + U). If the status box at the bottom shows "Uploading to I/O Board" and then "Done uploading" after about 30 seconds, move on to the next steps. Configuring Waypoints on the ArduPilot: 1) Download and unzip the ArduPilot Config Tool and GPS Emulator: http://www.happykillmore.com/Softwar...ConfigTool.zip. You'll need to be on at least IE 7 and you'll need the .NET runtime 2.0 or greater. 2) Run the ArduPilotConfigTool.exe and setup some waypoints. Make sure to select "Set Manually" in the Home Info box. 3) Select File and specify your COM port. 4) Click Write to send it to the ArduPilot 5) Click File, Save Mission (this may be helpful for other testing with the emulator) Running the GPS Emulator: 1) Open the GPSEmulator.exe that was a part of the ConfigTool.zip file from the step above. 2) Make sure you click Options, Baud and select 9600. The ArduPilot source above is meant to be used at 9600 baud. You can adjust this by changing the GPS_NMEA tab of the ArduPilot source. Edit the function called "init_gps" and change the line that reads "Serial.begin(9600)" to whatever baud your GPS runs. ie Serial.begin(38400). 3) Wire up the remaining connections shown above (CTRL to Serivo tester, connection between OSD and ArduPilot and Video Out to EasyCAP). 4) Specify your FTDI cable's COM port and click Connect and Start. After a few seconds, the blue light on the ArduPilot should come on solid. This means you have GPS lock. At this point, the ArduPilot should be sending GPS data along with the $M command string (see below) to the OSD. 5) Launch AMCap.exe (found in the C:\Program Files\Remzibi OSD folder - can be downloaded here http://remzibi.happykillmore.com) and make sure that under Options, Video Capture Filter, Image Tab you have selected the correct NTSC or PAL setting for your region and "Composite Video." At this point you should see something similar to what's shown below in the EasyCAP window. This means it's working. Running the GPS Emulator with feedback from the ArduPilot The emulator has a feature that will allow you to capture output messages from the Ardu to simulate an actual mission. To enable this ability, you will need to add a line to the ArduPilot_EasyStar_V23 tab of the ArduPilot source. Change the void loop function to read: Code:
void loop()//Main Loop
navigation();//Calculate all the setpoints for the roll, pitch and throttle. Function localted in "Amain" tab.
stabilization();//Control of all the actuators using IRs and Pressure Sensor... and the desired Setpoints for each one. Function localted in "Amain" tab.
catch_analogs(); //Reads and average the sensors when is doing nothing... Function localted in "Sensors" tab.
decode_gps(); //Reads and average the GPS when is doing nothing...
print_remzibi(); //Function localted in "System" tab.
//print_remzibi_debug();
print_data_emulator(); //< ---- This is what you need to add
if(gpsFix != 0x00)//No valid GPS
read_Ch1(); //reading the receiver with very short delays... Function localted in "Servos" tab.
read_Ch2(); //Reading the receiver with very short delays... Function localted in "Servos" tab.
refresh_rate++;
1) Open the GPSEmulator.exe 2) Click File, Run ArduPilot Mission 3) Make sure your last uploaded mission file appears in the "Selected Mission" combobox (this is why you should save your missions in the ArduPilotConfigTool.exe) 4) Change the GPS Data Source to "GPS Emulator w/ArduPilot" 5) (Optional) Check the "Listen to Throttle" checkbox. Do not check this to begin with because the ArduPilot's output of the THH command is based on sensor data. Chances are good it will read 0 all the time. 6) Adjust the speed on the Emulator The Status messages should tell you what's going on with the feedback from the Ardu. It includes what "mode" it's in (Manual, Waypoint or Return to Home), distance, pitch and turn information. ![]()
Configuring the $M command to the OSD: The $M command was added by Remzibi in v1.60 of his firmware. It allows other devices including the ArduPilot to send commands to display variable data through the serial port. It's format is shown below: Code:
$MXXYYLLEEabcd $M - means that it is meassage to display (M must be uppercase) XX - is a x coordinate on screen , must be hex value YY - is a y coordinate on screen LL - is leading character hex value from font table EE - is ending character hex value from font table abcd - is a "text message" to display (must be in upper case) when LL or EE is Hx00 - then will be not displayed at all when text message is "" [empty] then also will be not displayed You can choose the large or small fonts by changing the X7 bit in the XX variable. So add 80 to the column you want it to appear in. For example, $M8109B400TESTING would use the small font set in column 01, row 09 and would show the lightening bolt symbol, the words "TESTING" and then a blank space. There are 30 columns (XX) for both NTSC and PAL and 16 rows (YY) for PAL and 13 rows (YY) for NTSC. Code:
. X------> Y 1 2 3 4 5 6 7 8 ... 29 30 : 2 : 3 : 4 v 5 . . . 15 . 16 Code:
void print_remzibi(void)
static unsigned long timer1=0;
double nMult;
int nMeters=0; //Change this to 1 for meters, 0 for feet
if (nMeters==1)
nMult=1;
else
nMult=3.2808399;
if(millis()-timer1 > ATTITUDE_RATE_OUTPUT)
digitalWrite(13,HIGH);
Serial.print("$M");
Serial.print("82"); // Hex Column (01h - 1Eh) for small fonts add 80h (81h - 9Eh)
Serial.print("0A"); // Hex Row (01h - 0Dh for NTSC, 01h - 10h for PAL)
Serial.print("BA"); // Hex address of First Character
Serial.print("00"); // Hex address of Last Character
if ((int)Tx_Switch_Status() == 0)
Serial.println("MANUAL MODE "); //Min = 11
else if ((int)Tx_Switch_Status() == 1)
if ((int)last_waypoint == 0)
Serial.print("HOME:"); //Min length = 7
Serial.print((int)(wp_distance*nMult));
Serial.println(" ");
else
Serial.print("WP"); //Min length = 6
Serial.print((int)last_waypoint);
Serial.print(":");
else
Serial.println("RETURN TO HOME"); //Min = 14
timer1=millis();
delay(10);
digitalWrite(13,LOW);
void print_remzibi_debug(void)
static unsigned long timer2=0;
if(millis()-timer2 > ATTITUDE_RATE_OUTPUT)
Serial.print("$M");
Serial.print("81"); // Column
Serial.print("09"); // Row
Serial.print("A9"); // First Character
Serial.print("00"); // Last Character
Serial.print("P:");
Serial.print(pitch_set_point);
Serial.print(",R:");
Serial.print((int)roll_set_point);
Serial.print(",T:");
Serial.print((int)throttle_set_point);
Serial.print(",S:");
Serial.print((int)airSpeed());
timer2=millis();
void print_data_emulator(void)
static unsigned long timer3=0;
static byte counter;
if(millis()-timer3 > ATTITUDE_RATE_OUTPUT)
Serial.print("!!!");
Serial.print ("STT:");
Serial.print((int)Tx_Switch_Status());
Serial.print (",WPN:");
Serial.print((int)last_waypoint);//Actually is the waypoint.
Serial.print (",DST:");
Serial.print(wp_distance);
Serial.print (",RER:");
Serial.print(",THH:");
Serial.print (",PSET:");
Serial.println(",***");
timer3=millis();
Code:
Serial.print("$M");
Serial.print("P:");
timer2=millis();
If you're using Remzibi's GPS that he shipped with the OSD, then you'll need to make a modification to the plug. I simply pulled out the white wire (TX) and put a single header connector on the white wire. [IMG] |
Brunswick, OH
Joined Nov 2005
http://www.happykillmore.com/softwar...etup/setup.exe |
S. Wales
Joined Jun 2008
Try Hanson Hobbies
http://hansenhobbies.com/products/co...1inconnectors/ |
France/china
Joined Jun 2008
For the wii stuff it is not UPHIEARL ?
picture http://www.rcgroups.com/forums/showp...postcount=1167 Code file http://www.rcgroups.com/forums/showp...postcount=1136 |
Happyk, nice work on the write up. As a quick note though, you can buy the xyz sensors directly from fmas website for $43. See here...
http://www.fmadirect.com/detail.htm?...778§ion=20 If thats the same sensors updating the above info will definately help with the total overall cost. Just a thought. |
| Thread Tools | |
| Build Log A poor man's OSD | remzibi | Video Piloting (FPV/RPV) | 4730 | Yesterday 01:11 PM |
| Poor Man's Heat Shrink for Homemade Battery Packs... | flytowner | Parkflyers | 28 | Mar 12, 2010 11:45 PM |
| Discussion Instruments! OR a really poor man's OSD | mylittlepony | Video Piloting (FPV/RPV) | 7 | Dec 03, 2008 02:59 PM |
| Poor man's Super Slow Stick fun flyer? | uglyplane | Parkflyers | 1 | Jul 03, 2003 11:54 AM |
| Kyosho 180 Poor Man's Power Fix??? | Don Sims | Electric Plane Talk | 41 | May 12, 2001 09:23 PM |
