Old Sep 02, 2009, 10:54 PM
mickydee is online now
Find More Posts by mickydee
Hemet, California, United States
Joined Aug 2001
Hi,
Our full size Enforcer flys on a Hacker B50-13XL in a Midi Fan Pro on 8S. It flys very well but has fixed gear which limits the top speed.
The new Enforcer is scaled down 10%, has Spring Air retracts, and will take interchangable 70MM or 90MM power pods.
It it flys anywhere near as good as the Spatha, I will be very pleased.....
Mickydee
mickydee is online now Find More Posts by mickydee
Old Sep 04, 2009, 10:29 PM
F7X is offline
F7X
Find More Posts by F7X
F7X
Faster!
F7X's Avatar
United States, NV, Sparks
Spring Air, very disapointing.
I need to vent
Spring Air retracts are some of the finest made products that you can buy for your model. Reliable, strong, and made in the USA. Not to mention the value is great. For the same price as "just the retracts" of another brand, you can get the whole shabang, tubes, valves, T's, tank, everything from Spring Air.
But, (you know there had to be a butt) the web site is terrable. Missing informaiton and misleading information. No drawings for the 600 series. How much do the retracts weigh? Drawings that are present are very misleading. One drawing says the 200 is 1 1/8" deep. Then the drawing on the left says 1/8" down (you mean up?) and points to the trunnion. So are they 1.125" or 1.25"? And its very difficult to distinguish the difference between the 100 and 200 series. And how about some nose gear dimensions? They show a weight limit for the 100 series but not the 200, or 600. And the 700 are bored out... but what size? Bored out 200s or 600s?
No notification or indication of stock status. If the retracts are made to order or they are not currently in stock then say so! Preferably on the website or during the checkout process. At the very least email me the status when you confirm payment. It's nerve racking to paypal someone $160+ and not got a product nor an email notification of the situation within a week or two, or in my case 4 weeks after I email them!
So now I have a set or retracts that are 1/8" too deep. Dad say's he can mod the wing (ya, its already started, just no photos yet) to fit them. But thats not the point.
Sad really. I really like their products....
F7X is offline Find More Posts by F7X
Old Sep 04, 2009, 10:39 PM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
Well, I just tried to assemble my gear and they sent me the wrong sleeves. They sent me 5/32" not 3/16... aaahhh!
Old Sep 04, 2009, 11:15 PM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
Here is the wing being contructed in Dad's non traditional way. I built the wings on both of my scratch builds this way and had great results. No jigs, no bars. Just a nice flat piece of wood. Lay the spar down flat. Glue the root rib in at the propper angle, the glue in the tip rib. Span the trailing edgle across the root and tip ribs. Now all you have to do is fill in the gaps with the remaining ribs.
MH-43 airfoil.
Old Sep 04, 2009, 11:25 PM
Neogenesis is offline
Find More Posts by Neogenesis
Joined May 2005
Looking nice, can't wait to see it finished!!
Neogenesis is offline Find More Posts by Neogenesis
Old Sep 04, 2009, 11:49 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
yeah awesome retracts but imfamous for never actually having them in stock for months at a time.
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Sep 06, 2009, 03:24 PM
LJE4357 is offline
Find More Posts by LJE4357
Closed Account
Joined Jun 2002
Retracts
We make a set of retracts that are the same size as the Spring Air $600 series. Complete 3 gear set is $175. and can be fitted with the optional shock absorbing struts.
Larry E.
SouthEast Model Products
Orlando Fl.
407-381-8060
LJE4357 is offline Find More Posts by LJE4357
Old Sep 06, 2009, 03:51 PM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
Larry E.
Orlando Fl.
407-381-8060
Nice! We'll be contracting you on our next project. Thank you!
Old Sep 06, 2009, 10:40 PM
Joined Aug 2002
ah my favorite foil!! fast enough, but predictable! Well 2nd fave! I'm a speed nut so 32 is a fave also.
Barry
Old Sep 07, 2009, 04:11 PM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
Wing Continued
More progress on the wing. Its going to be sheeted in 3/32" balsa for extra strength. After some discusion we decided that a sharp pull up or turn at 160+mph could create 10 G's of force on the Jet. 10.5lbs x 10 = 105lbs. Thats a lot of weight for some balsa wings to support. Better make it strong. However, I am a little nervouse about the weight, but he assure's me that it will be within its weight limits.
The wing was built with no dihedral. However, the wing tapers up (top is flat) this gives us the same effect as a small amount of dihedral. Besides that, sweeping a wings give the same effect as dihedral.
In the pictures you may notice a slight change in the airfoil where the wheels tuck in. This tiny "bump" will ensure that the wheels tuck in nicely without the need for expensive or custom made ultra thin wheels.
The tubes you see are paper servo wire tubes.
Old Sep 07, 2009, 04:20 PM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
great project Joshua!
I'll be folowing your build with interest!
grtz!
erik
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Sep 08, 2009, 06:18 PM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
I choose Xtreme Power Systems
Ok, I ordered 3x 4S1P 5000mah 30c battery packs along with a 2s 1100mah A123 reciever pack.
Here's why I choose XPS over HobbyCity:
Weight They claim to be 32grams less than the Turnigy 5000s. That's over 3oz of savings with all of them together!
Cycles I've also been doing some reading and have found that the XPS batteries typicaly last at least 2x longer before significant performance loss. The Turnigy's are about 1/2 the price, but once you pay for shipping they're about 2/3rds the price. So if the XPS's really do last 2x as long, they'll have paid for themselves.
Service I've heard that HC can be hard to deal with at times. But I've delt with XPS at the Arizona Electric Fest and they presented them selves in a friendly, knowledgeable, confident and helpful manner.
Hope I made to right choice!
-Joshua
Old Sep 08, 2009, 08:30 PM
Joined Aug 2002
wise choice! lol XPS are grest cells.
Barry
Old Sep 09, 2009, 02:45 PM
Joined Dec 2003
Hi Joshua,
A made a comparison list for xps and Hyperion cells in a thread of mine and the xps are by far a better choice
post 25+26
http://www.rcgroups.com/forums/showthread.php?t=1070119
Pack_cap_cap.85_Cd/Cb_M_M1s_M4s_M8s_M12s_(cap.85/M1s)_$_$1s_Eur_Eur+19%_Eur1s_Eur4s_Eur8s_Eur12s_S+ H
If you read the numbers patiently you may do this for your own setup as well.
My bad luck is that the 3s1p 2500mAh cells are not available anymore. I really fancied a 12s setup myself.
Old Sep 09, 2009, 07:15 PM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
Originally Posted by Erik v. Schaik
Hi Joshua,
post 25+26
Nice! Thanks for making my day! That data is great as well!
Fokker B-I ds scratch-build Looooeeee! Scale Kit/Scratch Built 15 Aug 30, 2013 11:23 AM
Discussion Spatha 70mm EDF Scratch Build by Phil Wesley F7X Electric Ducted Fan Jet Talk 23 Jun 15, 2009 11:11 AM
Cool CRASHED Javelin Sport Jet Scratch Build by Phil Wesley DELTA EXPERT NEEDED F7X Electric Ducted Fan Jet Talk 35 Dec 25, 2008 04:59 AM
TEAM Air Bike Scratch Build. Tram Parkflyers 51 Oct 06, 2006 10:48 AM
My first Design Scratch Build Project Heather Electric Plane Talk 20 Jul 22, 2001 11:03 AM
