The CG of the Spatha is 42% of the chord from the leading edge at the root. So, its a 12" chord at the root, and its 5 inches back from the leading edge. See the photo. I would say that this is the near the foward limit of the CG range. Some times I run a lighter battery, moves the CG back about 3/16" and it still flies fine. The long tail moment and large tail really make this design super stable. If you have any more questions or need a photo I'll do my best to help you out. -Joshua |
Paul,
A couple more things to consider on your dsign: If your nacell/exhaust is going to be in the same place as our jets, consider about 2 degrees of down thrust (point the nozzle down 2 degrees). The little Spaha flies around with about 1/32" of down elevator for level flight. In high power, low speed situations the little jet pitches up pretty hard. Dad added down thrust on the Charger, made a huge difference. If you are planning on flying at high density altitudes or on a short runway I would highly recomend an aerodynamic brake of some sort. Whether its dual flaps, a singe flap (if trailing edge it straight) split flaps, or an airbrake like the Comp ARF Spark, any of which will help control speed on approach. The Spatha is easy to fly but an absolute pain in the butt to land. It's so clean that it refuses to slow down, However, its flight controlls are a little slugish at approach speed. So I end up landing at at about 1.5x stall speed. The Charger is outfitted with large laps that make a huge difference, and more generous flight controll area for better controll authority up to and through a stall. The Charger flies like a trainer. -Joshua |
| Thread Tools | |
| Discussion Spatha 70mm EDF Scratch Build by Phil Wesley | Joshua Wesley | Electric Ducted Fan Jet Talk | 23 | Jun 15, 2009 11:11 AM |
| Cool CRASHED Javelin Sport Jet Scratch Build by Phil Wesley DELTA EXPERT NEEDED | Joshua Wesley | Electric Ducted Fan Jet Talk | 35 | Dec 25, 2008 04:59 AM |
| TEAM Air Bike Scratch Build. | Tram | Parkflyers | 51 | Oct 06, 2006 10:48 AM |
| Fokker B-I ds scratch-build | Looooeeee! | Scale Electric Planes | 14 | Feb 26, 2003 05:08 PM |
| My first Design Scratch Build Project | Heather | Electric Plane Talk | 20 | Jul 22, 2001 11:03 AM |
