Old Jun 14, 2010, 08:11 PM
F7X is offline
F7X
Find More Posts by F7X
F7X
Faster!
F7X's Avatar
United States, NV, Sparks
Originally Posted by Paulofthenorth View Post
Just found this thread after reading about your plane in Fly RC.
Are plans available?
No plans, sorry. We've been asked a thousand times for plans of our varous aircraft... you think we'd do something about that.
Unfortunately the aircraft was destroyed shortly after AEF. The elevator servo, an HS-5245MG failed due to what I can only guess was excessive voltage from an unregulated 2S A123 receiver pack. It went in nearly straight down at a very high speed (150mph+). Better than a $1000 crash.
"Charger II" is nearing completion. It sports a thinner wing, main gear doors, more exhaust pinch, and a much more durable fiberglass finish. All that's left is painting the upper surface of the wing and setting up the servos.
Expect a new thread soon for the Charger II.
F7X is offline Find More Posts by F7X
Old Jun 14, 2010, 08:20 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
sorry to hear that josh! glad you got another going though! ive been using A123 unregulated for a while with no issues....so far...
corsair nut is offline Find More Posts by corsair nut
Old Jun 14, 2010, 08:43 PM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
I know, right? It was that second flight of the day. I clearly lost elevator control in flight. I still had roll and throttle control, don't know about any of the other systems. I had enough time to yell out "I've lost elevator" a couple times before the crash. After an NTSB style invesigation we determined the pushrods had not failed, nor did the horn on either the elevator or servo. The receiver (what was left of it) departed the aircraft, but all the pins were bent n the same manner from the departure, thus making us believe that the elevator servo was still plugged in at the time of the crash.
So now it's down to the servo or the radio system (tx & rx). I pulled the servo apart and it stank like burnt electronics. The elevator servo was the only digital servo on the aircraft.
After some research on the net, I discovered numerous complaints about certain digital servos failing due to voltages of over 6 volts.
I'm going to run 2 Castle 10amp BECs in parallel at 5.5volts for the radio from a single 2s 900mah to 1350mah pack on the Charger II.
-Joshua
Old Jun 14, 2010, 11:38 PM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
HI Joshua,
I am sorry to read your plane went down.
I was thinking about demagging edf motors and figured out small servo motors cannot dissipate heat because they sit in plastic houses. Higher Voltage=higher current=heat waste=demagging and this is the reason why I don't use 2s A123. Now one cannot use 2s A123 and regulator on 6V output (my plane Jetmach60 went down in a cornfield, no damage) so I went to 2s Lipolly and regulator which is fine. However, A 2s1p 900(20c?) pack can only handle 18A and the Voltage will drop so I beefed my Rx pack to 2000mah,25C for extra stability and no recharging during a day. I have extended info about regulators+2.4gHz in my A123 blog.
All the best,
Erik
Btw, it is possible to connect telemetry to the Rx pack to measure max current and Voltage sag during flight.
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Jun 15, 2010, 06:08 AM
Paulofthenorth is offline
Find More Posts by Paulofthenorth
Paulofthenorth's Avatar
Owen Sound, Ontario
Joined Jan 2006
Charger crash
Sorry to hear about the loss. Looking forward to Charger II!
Paulofthenorth is offline Find More Posts by Paulofthenorth
Old Jun 15, 2010, 08:06 AM
Lboogie is offline
Find More Posts by Lboogie
Lboogie's Avatar
Sebastian Fla
Joined Nov 2005
Gutted. Sorry for your loss.
Regards,
Leonard
Lboogie is offline Find More Posts by Lboogie
Old Jun 29, 2010, 07:06 PM
Owen Sound, Ontario
Joined Jan 2006
What airfoil?
Can you tell me what airfoil you used on this plane, or on the Sparta?
Appreciated,
Old Jun 30, 2010, 07:10 AM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
Appreciated,
Both the Charger and the Spatha use the MH-43 airfoil. The airfoil was modified lightly around the wheel wells for clearance.
Seems to be a very fast airfoil, with forgiving characteristics.
-Joshua
Old Jul 16, 2010, 07:56 PM
Owen Sound, Ontario
Joined Jan 2006
questions
I'm seriously considering building a plane similar to yours in a 90 mm fan size. I've looked at the basic dimensions you give in the Spatha thread and am scaling them up to about a 45 inch span.
Would you be willing to share the c of g location of the Spatha or the Charger?
Any help would be appreciated.
Old Jul 16, 2010, 08:15 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
The HS-5245MG servos are rated for 5 cell Nimh (7.2v) packs. I personally use A123 packs with all of my Hitec servos, including the 5245 series, unregulated.
JimDrew is offline Find More Posts by JimDrew
Old Jul 16, 2010, 09:51 PM
tehachapi, CA
Joined Jan 2006
Any pics josh???
Old Jul 16, 2010, 10:41 PM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
Jim,
We are exploring one other possible cause. Is it possible to overload just one channel of a receiver? The servo was dawing all of its power through the receiver, rather that "Y"ing into the A123 pack. Do you think this could have caused the failure?
Bret,
Not yet... we've been slacking. I'll get new photos of the Charger II and some of the carnage soon.
-Joshua
Old Jul 16, 2010, 10:42 PM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
Ya, Let me messure it when I get back to the house, and I'll let you know.
-Joshua
Old Jul 16, 2010, 11:38 PM
F7X is offline
F7X
F7X
Faster!
F7X's Avatar
Jim,
Check your math: 5 cells at 1.2 volts = 6v.
7.2v would be a 6 cell pack.
The manual included in the HS-5245MG shows operating voltage at 4.8v to 6v. I still think I smoked the servo.
-Joshua
Old Jul 17, 2010, 03:08 AM
Joined Dec 2003
You cannot use an 2s A123 pack+ regulator because the regulator will brown out. You cannot use 3s A123 pack + regulator because the regulator will overheat, reduce current limits and shut down on thermal.
NiCd=1.2V
NiMh=1.1V
Voltage will be reduced under load like Lipolly.
Fokker B-I ds scratch-build Looooeeee! Scale Kit/Scratch Built 15 Aug 30, 2013 11:23 AM
Discussion Spatha 70mm EDF Scratch Build by Phil Wesley F7X Electric Ducted Fan Jet Talk 23 Jun 15, 2009 11:11 AM
Cool CRASHED Javelin Sport Jet Scratch Build by Phil Wesley DELTA EXPERT NEEDED F7X Electric Ducted Fan Jet Talk 35 Dec 25, 2008 04:59 AM
TEAM Air Bike Scratch Build. Tram Parkflyers 51 Oct 06, 2006 10:48 AM
My first Design Scratch Build Project Heather Electric Plane Talk 20 Jul 22, 2001 11:03 AM
