Old Nov 29, 2012, 06:34 PM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
I haven't got round to it yet, SB. Too many other things to do, at the moment.
I'm still wondering how to check which trees have gone underground. Thinking about it, I'm not sure if what I see when looking under the edge are trees that are underground, or just trees that are on the surface, but seen without the surface. Possibly some of both.
Andy2No is offline Find More Posts by Andy2No
Old Nov 29, 2012, 06:59 PM
SuperBarlow is online now
Find More Posts by SuperBarlow
No place like cloud base......
SuperBarlow's Avatar
United States, VT
Joined Aug 2012
The trees orient themselves on top of the land, as far as I know.
The trees that you see are on top, but you're seeing through the ground.
SuperBarlow
SuperBarlow is online now Find More Posts by SuperBarlow
Old Dec 14, 2012, 01:04 PM
svtdoug is offline
Find More Posts by svtdoug
United States, WA, Gig Harbor
Joined Oct 2009
Hi,
I've installed RC Desk Pilot for my grandson, seems pretty nice. Now hitting lots of confusion on what type of USB cable to use to connect a Spektrum transmitter up to PC. I know there is the mono 1/8" cable method using the auxiliary SmartPropoPlus software. This is the method that I used for FMS and I know it works for FMS. I've searched through this whole thread, and some say to use a standard Spektrum compatible USB connector - but offer no link. What is standard?
There is this connector - http://www.amazon.com/gp/product/B00...rd_i=GWSFM002B But the reviewer says it does not work on his Spektrum transmitter. Does it work or not?
Others have posted that you need an expensive cable with electronics to get decent resolution from your transmitter. Is this true?
So my question is - what specific USB cable are you guys using - and where can that cable be found??
Thanks much.
Doug
svtdoug is offline Find More Posts by svtdoug
Old Dec 14, 2012, 01:40 PM
helicow is offline
Find More Posts by helicow
Gravity gets me down.
helicow's Avatar
USA, FL, Brooksville
This is the cable I have used with both a DX5 and a DX7:
I am sure you can find it cheaper - not sure where I got mine.
Model Number: GWFSM002 is what is on the tag I have.
http://www.amazon.com/Stereo-Plug-Fl.../dp/B0016N18JC
Good luck
helicow is offline Find More Posts by helicow
Old Dec 14, 2012, 01:41 PM
helicow is offline
helicow's Avatar
Has anyone got this working on Windows 8? I searched and nothing came up.
Old Dec 15, 2012, 07:38 AM
GeneralFailure is offline
Find More Posts by GeneralFailure
GeneralFailure's Avatar
Joined Apr 2009
Hi, I've tested it on Win8 and it works fine (at least on one of the release candidates).
Cheers,
Davy
GeneralFailure is offline Find More Posts by GeneralFailure
Old Dec 15, 2012, 11:06 AM
helicow is offline
helicow's Avatar
Thanks - good to know.
Old Dec 17, 2012, 03:52 PM
MyDigitalParadis is offline
Find More Posts by MyDigitalParadis
Callsign: Jolly Roger
MyDigitalParadis's Avatar
Ridgecrest California
Joined Jun 2006
An alternative to the Spektrum connection cable and about the same price is one of the old Eskay flight simulators. It comes with a dummy controller that you can use with Desk Pilot and it saves wear and tear on your Spectrum and it's batteries. It is what I use.
Grayson hobby carries it: (Out of stock right now) http://www.graysonhobby.com/catalog/...ofkuf7i5u7qsk4
HobbyPartz also carries it and is a west coast supplyer: http://www.hobbypartz.com/60p-dyu-1002.html
Both are under 20$ before shipping.
MyDigitalParadis is offline Find More Posts by MyDigitalParadis
Old Dec 17, 2012, 09:29 PM
sonnier00 is offline
Find More Posts by sonnier00
sonnier00's Avatar
United States, TX, Huntsville
Joined Oct 2011
i have a Turnigy tx and 12n1 dogel but dask pilot dose not see them. is there some thing i can do to make them work?
sonnier00 is offline Find More Posts by sonnier00
Old Dec 18, 2012, 03:35 PM
United States, VT
Joined Aug 2012
Set the TX up as a game controller. If you can't do that, you can't use it, I would assume.
Old Dec 26, 2012, 12:25 PM
Ikankrachuhmoll is offline
Find More Posts by Ikankrachuhmoll
United States, NC, Pilot Mountain
Joined Oct 2011
Sim fails with HDMI connected.
Just got a new laptop with HDMI out and this sim will not run with the cable connected. I even tried starting the sim then connecting the cable but it still fails. It does show a report that I can post if that helps but I don't have that available now.
I am hoping that there is a known issue that is easily fixed. This sim would look really nice on a bigger screen, I think.
Edit:
Same or similar problem on two TV. A 1080i @ 30" and a 720p @ 50".
Ikankrachuhmoll is offline Find More Posts by Ikankrachuhmoll
Old Dec 26, 2012, 01:14 PM
Cheese5 is offline
Find More Posts by Cheese5
Cheese5's Avatar
United States, CA
Joined Jul 2010
Interesting, mine works well with the HDMI connector to a 20" and a 48" flat screen. Does your computer switch screens? Does everything on the computer work? I just turn everything on, open flight sim, connect HMDI cable and it works.
Cheese5 is offline Find More Posts by Cheese5
Old Dec 26, 2012, 07:28 PM
Eves is offline
Find More Posts by Eves
Joined Nov 2009
I use HDMI to a large LCD tv just fine too. I have a desktop pc though, not a laptop.
Do you see your desktop screen on the TV? or other programs/3D games?
Try running RCDP in windowed mode. For fullscreen/dual monitor mode I must switch my TV to the #1 monitor in windows for it to work.
RCDP restarts when it senses a screen format change when switching monitors, that must be when you get an error?
Make sure you have the latest video drivers for your laptop too.
A screen shot of the error could help.
Eves is offline Find More Posts by Eves
Old Dec 27, 2012, 03:01 PM
Joined Apr 2009
Hi Ikankrachuhmoll,
Does the problem also occur when you only use the external monitor (so no extended desktop mode)? A screenshot of the error would help. Also: are you using the BMI version of the regular 1.3?
Cheers,
Davy
Old Dec 28, 2012, 09:58 AM
Joined Oct 2011
Product version appears as 0.1.3.* and the file version appears as 0.1.3.0.
Error are either as follows or attached. These were with the TV as primary,, no extended or cloned desktop. But I have tested and the same appears with extended or cloned.
Name: rcdp error.jpg
Description: This appears after the splash screen.
Name: rcdp error2.jpg
Description: Then, after OK is clicked, I see this.
Others asked about other 3D games. I don't run a lot of games on this PC (supposed to be a "work" PC. But, even if its not relevant, FMS does run.
The laptop is new but I will check for latest drivers. That will likely require a reboot so those results will be in the next post. (edit): reinstalled latest driver,, same results.
Discussion Atlanta area micro r/c heli pilot needed ASAP Greg McNair Aerial Photography 1 Nov 13, 2006 06:20 AM
For Sale (71)r/c digest mags up for bid bigtfortulsa Aircraft - Sailplanes (FS/W) 0 Jan 11, 2006 09:29 AM
For Sale Old r/c Digest magazines up for bid bigtfortulsa Non R/C Items (FS/W) 0 Jan 11, 2006 09:24 AM
R/C Airship Pilot Needed - Orlando, FL Stevens AeroModel Parkflyers 4 Mar 18, 2002 10:24 PM
