Old May 30, 2012, 01:02 AM
YosefAugers is offline
Find More Posts by YosefAugers
da Perfesser
YosefAugers's Avatar
United States, WA, Spokane
Joined Apr 2012
Originally Posted by ggunners View Post
<snip> comes
with some awesome technology for easing a newbie flyer into a
successful flying hobby. They call it Electronic Virtual
Instructor technology and experienced pilots can think of it
as a roll gyro
ggunners,
Are you sure there's a gyro in there?
-Yosef (Augers)
YosefAugers is offline Find More Posts by YosefAugers
Old May 30, 2012, 07:34 AM
ggunners is offline
Find More Posts by ggunners
Bit-Twiddler and Flyer
USA, VA, Chantilly
Joined Apr 2002
Yosef, I talked to Quique at SEFF after flying the model and knew that it wasn't a full AS3X module (3 gyros in ParkZone micros). He said roll gyro only and the rest was mixing. So, I have not taken it apart, but I took his word for it. The new MEMS gyros are about the size of a grain of rice.
If you go up real high and start a dive, you can't get the Stratos to roll. Quique told me it was stopped by the control unit. If you turn off the "Instructor" you shoulld be able to roll it. I have not tested that yet but the time is coming for some flight tests without the instructor.
Quique said everything but motor differential is turned off when you turn off the instructor.
If you like, feel free to rip yours apart and verify it for me.
-- ggunners
ggunners is offline Find More Posts by ggunners
Old May 30, 2012, 05:13 PM
da Perfesser
Joined Apr 2012
-- ggunners
Don't need to.
All the electronics are easily seen once the wing is off.
I have no clue what to look for. If you take the wing off sometime, and you want, see if there's anything soldered on its little printed circuit board that looks like a gyro-like (or ring-laser-like) device to you.
Thanks!!!
Old May 31, 2012, 07:29 AM
ggunners is offline
USA, VA, Chantilly
Joined Apr 2002
There might be some electronics on the bottom side of the board too. And if I were creating the board, I'd probably hide the important bits under some black stuff. These days you need a microscope to find out what's on the board.
That said, I believe the stabilizing "gyro" only works with motor differential while the mixing happens in the transmitter. So turning the instructor off, turns off the mixes but leaves the stabilizing differential thrust. In your movie, you were rolling the airplane slowly, perhaps a quicker roll would make a difference.
-- ggunners
Old Jun 07, 2012, 08:05 PM
spitfire1234 is offline
Find More Posts by spitfire1234
spitfire1234's Avatar
Australia, NSW, Orange
Joined May 2012
Hi, i just made this L-39 in metasequioa it's kind of bad since it is my first attempt. I was just wondering if anyone could either,
1) download it from here, put it into the aircraft editor, fix it and put it back here.
And/ OR
2) tell me how to fix it- these are the problems: I can't work out how to make it roll axial, it rolls around the wing tip, and also it sinks into the ground. I've got one or two collision points but I don't know how to position them.
l-39
many thanks in advance if anyone answers
spitfire1234 is offline Find More Posts by spitfire1234
Old Jun 07, 2012, 09:24 PM
ggunners is offline
USA, VA, Chantilly
Joined Apr 2002
Next time include the .mqo file and maybe we could help.
Old Jun 07, 2012, 09:54 PM
Joined May 2012
l-39 (2)
thanks ggunners i've fixed it, here is the finnished product
plus, here is the Mqo file if anyone wants to muck around with it
L-39
thanx
Old Jun 08, 2012, 02:16 AM
Joined May 2012
how do I add stuff like retracts onto the heirachy?Name: Capture.jpg
Description:
Old Jun 08, 2012, 10:31 PM
numanair is offline
Find More Posts by numanair
numanair's Avatar
United States, WA, Kirkland
Joined Sep 2010
Originally Posted by spitfire1234 View Post
how do I add stuff like retracts onto the heirachy?Attachment 4921809
Right click on "whole center" or whatever the name of your object is and then click "add child item."
numanair is offline Find More Posts by numanair
Old Jun 08, 2012, 10:53 PM
Joined May 2012
thanks
Old Jun 11, 2012, 07:34 PM
da Perfesser
Joined Apr 2012
-- ggunners
I dip the left wing and quickly right it and the right motor briefly comes on. That happens consistently. Dipping the right wing then quickly righting it causes neither motor to come on. When I dip the left wing, shouldn't the left motor come on?
Old Jun 23, 2012, 06:45 PM
Dave K is offline
Find More Posts by Dave K
Dave K's Avatar
Sebastopol, Ca
Joined Jun 2004
Can I use this cable
\http://www.ebay.com/itm/USB-Simulato...item4166a79294
and my JR xp6102 with this program
If that does not work what cable will?
Dave K is offline Find More Posts by Dave K
Old Jun 24, 2012, 06:07 PM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
It looks like it should work, Dave. The picture actually shows a mono jack too. If that's what it has, that's better for JR radios than the one I have, which looks similar but has a stereo jack (I've never dared try it with my DSX11 but I've used it with other radios - an old FF7 and an old Parkzone RTF Tx).
Andy2No is offline Find More Posts by Andy2No
Old Jun 24, 2012, 10:34 PM
Dave K is offline
Dave K's Avatar
Sebastopol, Ca
Joined Jun 2004
Great thanks for the help. Ordering the cable now and will report back when I have it.
Dave
Old Jun 29, 2012, 03:40 PM
oldglider is offline
Find More Posts by oldglider
Joined Jun 2012
Hi,
After having calibrated the radio (joystick) can not I use the rudder and flaps together.
When during the calibration check the "use ailerons channel ..." should not be the rudder and flaps work, if not checked operate the rudder but not flaps!
what is wrong?
ths
oldglider is offline Find More Posts by oldglider
Discussion Atlanta area micro r/c heli pilot needed ASAP Greg McNair Aerial Photography 1 Nov 13, 2006 05:20 AM
For Sale (71)r/c digest mags up for bid bigtfortulsa Aircraft - Sailplanes (FS/W) 0 Jan 11, 2006 08:29 AM
For Sale Old r/c Digest magazines up for bid bigtfortulsa Non R/C Items (FS/W) 0 Jan 11, 2006 08:24 AM
R/C Airship Pilot Needed - Orlando, FL Stevens AeroModel Parkflyers 4 Mar 18, 2002 09:24 PM
