Old Aug 29, 2009, 12:56 AM
superguy6486 is offline
Find More Posts by superguy6486
Joined Aug 2008
Help!
dxi/ar6100 binding problem
Just got my dx6i with an ar6100 in today and I have no clue what I'm doin. I'm new to dsm2 tech n i need help. For starters, how the heck do I bind the rx to tx??? i've gotten as far as plug in the bind plug into the batt/bind slot and dunno where to go from there... i've tried plugging an esc into throttle slot and then battery to esc but the led on the rx doesn't flash like it's supposed to... Pease help!!!!
superguy6486 is offline Find More Posts by superguy6486
Old Aug 29, 2009, 01:02 AM
Twister773 is offline
Find More Posts by Twister773
Private Pilot
Twister773's Avatar
United States, CA, San Luis Obispo
Joined Jul 2009
plug bind plug into rx...plug in battery or turn on receiver, rx should be flashing, now hold the trainer switch down on the tx and turn the tx on while doing this, that should do it.
Twister773 is offline Find More Posts by Twister773
Old Aug 29, 2009, 01:04 AM
Joined Aug 2008
i don't get what u mean by "plug in the battery". Aren't i doing that when i plug it into the esc and esc into rx?
Old Aug 29, 2009, 01:14 AM
Jimmi is offline
Find More Posts by Jimmi
Jimmi's Avatar
Los Angeles Area
Joined Dec 2005
You can click on youtube and it will show you how to bind....
Jimmi is offline Find More Posts by Jimmi
Old Aug 29, 2009, 01:15 AM
Private Pilot
Twister773's Avatar
Joined Jul 2009
yes...have the esc plugged into the rx...then put the bind plug in...THEN plug in the battery, it should be blinking....now turn on the dx6i while holding down the trainer switch, it should say binding on the front screen or bind mode. i dont remember which one.
Old Aug 29, 2009, 01:25 AM
Joined Aug 2008
yeah that's exactly what i'm doin n the rx isn't blinking
Old Aug 29, 2009, 01:27 AM
Private Pilot
Twister773's Avatar
Joined Jul 2009
you have something plugged into the receiver wrong im guessing
Old Aug 29, 2009, 01:38 AM
Joined Aug 2008
bind plug is in batt/bind slot n esc in throttle slot....
Old Aug 29, 2009, 01:40 AM
Joined Aug 2008
got it, had them plugged in backwards :P thanks, much appreciated!!
Old Aug 29, 2009, 01:49 AM
kunclebuc is offline
Find More Posts by kunclebuc
kunclebuc's Avatar
GARNER NC
Joined Apr 2009
Superguy6486
You should have the bind plug pluged into bat/bind port and plug the esc/bec into the throt. port. this is how my ar6200 is hooked up. Check that and make sure your bat. is fully charged. If it still does not work you may have a bad rx.
kunclebuc is offline Find More Posts by kunclebuc
Old Aug 29, 2009, 03:15 AM
Private Pilot
Twister773's Avatar
Joined Jul 2009
Old Aug 29, 2009, 11:39 AM
Fredriksson is online now
Find More Posts by Fredriksson
Just having fun
Fredriksson's Avatar
United States, KY, Hopkinsville
Joined Feb 2008
Just in case you did not get a manual with your DX6i, here is a link to it.
http://www.horizonhobby.com/ProdInfo...nual-LoRes.pdf
Hint: When all else fails, read the manual.
Freddy
Fredriksson is online now Find More Posts by Fredriksson
Old Aug 29, 2009, 05:37 PM
Joined Aug 2008
lol thanks freddy :P
Discussion How do end points work? My solution to binding problem correct? vadim Mini Helis 3 Oct 21, 2006 01:52 AM
Discussion dx6 binding problem pugger Mini Helis 2 Sep 29, 2006 06:02 PM
Build Log Raptor 50 titan washout binding problem rjfon1 Fuel Heli Talk 5 Apr 29, 2006 02:42 AM
Hacker B408L Binding Problem Brett Electric Heli Talk 5 Oct 29, 2001 03:18 AM
