Old Oct 25, 2009, 08:31 PM
twister782 is offline
Find More Posts by twister782
twister782's Avatar
Akron, Ohio
Joined May 2008
http://www.hobbycity.com/hobbycity/s...idProduct=4700
the link is for this motor hacker Style Brushless Outrunner 20-22L
18.43 oz without battery
also my foam is 1.9# quite a bit heavier than the kit foam
twister782 is offline Find More Posts by twister782
Old Oct 25, 2009, 09:39 PM
ToyStar is offline
Find More Posts by ToyStar
ToyStar's Avatar
Penang, Malaysia.
Joined Apr 2009
Originally Posted by twister782
Well I got her up today. flies like crap. Like i am pulling around a boat anchor. 10x 4.7 prop 11x4.7 prop 1000mah,1500,2100mah all not good enough. I think I need a larger motor. I can't make the plane lighter. I need more power to pull this thing around the field. I even had an experienced pilot fly it twice and he agreed it is way under powered. any recommendations on a motor?
What is your AUW? Mine weighs in at 820g currently (due to additional glue after repairs and landing gear) but still flies fine with a 1550 mAh 30C bat, Emax 2220-07 outrunner and APC 11 x 3.8 SF prop. Had to put in the landing gear in a bid to stop the foam ripping with a imperfect landing.
I have commenced a new build, this time with 1.3# foam. Thinking of putting in additional reinforcement on the fuselage. I have ripped it in 2 places (at the wing root) as well as just aft of the nose doublers, the foam anti twist panels were not spared either. It happens when the tail tries to whip around after a hard landing. Anyone experienced this phenomenon ?
ToyStar is offline Find More Posts by ToyStar
Old Oct 25, 2009, 09:42 PM
twister782's Avatar
Akron, Ohio
Joined May 2008
LV2soar looks good!!! snoopy looks like he cant wait to take her for a run.
Old Oct 25, 2009, 09:48 PM
twister782's Avatar
Akron, Ohio
Joined May 2008
In flight pics
Here are some shots of the yak on her maiden
Old Oct 26, 2009, 10:04 AM
Slow_Buzz is offline
Find More Posts by Slow_Buzz
United States, MO, Marshall
Joined Sep 2009
Lookin good guys. I've started gluing the horizontal pieces together. I'm still waiting on my harbor freight airbrush to put paint on before I glue verts to horizontals.
Dan
Slow_Buzz is offline Find More Posts by Slow_Buzz
Old Oct 30, 2009, 12:03 PM
Joined Sep 2009
My airbrush arrived and my homemade cable to attach to my air compressor seems to work ok. I've got the compressor set to 30 psi. Time to practice with this new toy and get familiar with it, then on to the real paint job.
Dan
Old Oct 31, 2009, 05:56 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
Slow buzz air brush opens up a whole new meaning to building!!! when I started to airbrush , it opened up another side to plane building than I ever thought. good luck! Don't be afraid to experiment. there are some great you tube instructions. dont be stuck on your 30#PSI remember to move the air pressure around. you will know when the PSI is right.
Old Oct 31, 2009, 06:06 AM
Joined Sep 2009
Thanks twister,
I've been reading the painting tips by adreher (sp?) posted in the scratchbuilt forum. The 30 was just a test of my air line I made. I've got a template of the main horizontal airframe cutout. Now I just need to settle on a scheme to put on it. Question for ya. Did you have the stiffeners glued on before painting or after? I notice I can see the step on the leading edge of the wing and your wedge angles over it. I was thinking of putting Yak 55 in large lettering on the wing, but was not sure how to really go about it with the step. I may just keep it below that raised area to keep it simple for my first airbrush job.
Dan
Old Oct 31, 2009, 06:25 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
Keep it below. it is a pain to spray over the step. I use that blue painters tape. It works well, sticks good to the foam and removes easier. I printed out yak "55" on my smaller version. then I cut out the letters and had a template. worked great. I also use contact paper/ sticky shelf liner. for templates
Originally Posted by Slow_Buzz View Post
Thanks twister,
Dan
Old Oct 31, 2009, 06:30 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
Here is top and bottom pics of my smaller yak. you can see the yak55 on the bottom of the plane
Old Oct 31, 2009, 06:38 AM
twister782's Avatar
Akron, Ohio
Joined May 2008
a few more
Old Oct 31, 2009, 08:08 AM
Joined Sep 2009
Twister,
Good lookin plane. I'll definately go with lettering below the step, so I can use a template.
Dan
Old Oct 31, 2009, 10:58 AM
leadfeather is online now
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Great looking plane Twister!
leadfeather is online now Find More Posts by leadfeather
Old Oct 31, 2009, 01:02 PM
twister782's Avatar
Akron, Ohio
Joined May 2008
Your design!!!
Old Oct 31, 2009, 08:10 PM
twister782's Avatar
Akron, Ohio
Joined May 2008
I removed the motor from the mount, I was right, it was rubbing. I pulled out the dremel and ground more of the mount. hopefully it will rip out of my hand. I hope this solves the problem of lack of power. I hope the weather is ok tomorrow to give her a throw. I will keep you posted
Check up this new Electric Epp flying wing! Ming Foamies (Kits) 365 May 09, 2008 11:45 PM
New Ultimate EPP Bipe from nesail.com SINYFLY 3D Flying 8 Sep 30, 2006 12:44 PM
My new TDS-EPP-3D Plane gneely 3D Flying 4 Nov 23, 2003 11:22 PM
Alfa's Models New La-7 & Yak-3 JFGrn Parkflyers 17 Oct 07, 2003 08:52 PM
New molded Epp flying wing Windrider Foamies (Kits) 18 Jun 08, 2002 05:02 PM
