TACO II Scratch Build
Another thread got me interested in building a profile Fun Fly design named the Taco II. http://www.rcgroups.com/forums/showt...highlight=taco
It was originally designed for a .25 engine and has a 37" wingspan. I plan on using the "Golden Ticket" setup everyone is using on their 3D machines. (hacker 15L 4:1, 9 KAN 950's, 12x6 E prop) The control surfaces on this plane are HUGE as it was designed as a hovering, knife edging, tumbling 3D machine. So far I have the wing completely built, per plan. On this plane the wing is the largest part, therefore the heaviest. Mine weighs in at 4.4 oz. and is constructed of mostly 1/16" balsa, 2, 1/4" balsa spars and a 1/4" CF ribbon running along each spar. Here's the wing. It took about 3 hours to build from scratch. -- Acer http://speedwing.net |
I think the empty weight of the plane will be around 12-15 oz. Estimated weight with battery/motor will be around 24 oz.
The Hacker setup pulls 47 oz. static and 37 oz. in flight thrust, so it should fly this plane great! -- Acer http://speedwing.net |
Without ailerons the wing area is 347 sq. in. Including the ailerons the wing area is 461 sq. in.
Those thrust figures were what P-Calc gave me, they're probably wrong though. cound that 35 oz. somehow be the inflight thrust? Its awful close to the 37 oz. figure. I did my own scientific test to find the thrust of the Hacker setup though. What I did was hold onto the motor very tightly with my arm above my head and hit the throttle!! Just about pulled me off the ground -- Acer http://speedwing.net |
| Thread Tools | |
| Build Log SR-71 Mk.II Scratch Build...again | Willmsy | Electric Ducted Fan Jet Talk | 685 | Jan 24, 2013 09:28 AM |
| Gulfstream II (Scratch build photo essay) | Lift Crazy* | Slope | 38 | Feb 28, 2005 03:04 AM |
| Rave Taco II Build FINALLY FINISHED!!! | Acer | Parkflyers | 10 | Nov 01, 2003 09:20 AM |
| Scratch building the Taco II Profile FF | Acer | Sport Planes | 4 | Apr 15, 2003 06:49 PM |
| Firebird II Speed Wing for 1st Semi-Scratch Build? | Dave Hederich | Power Systems | 16 | May 21, 2002 09:50 AM |
