Old Sep 27, 2009, 03:04 PM
Sky_Captain is offline
Find More Posts by Sky_Captain
Flying is Freedom
Sky_Captain's Avatar
Annandale, VA
Joined Jul 2007
Originally Posted by wheelnut
While the subject of the blinky came up, I wanted to tell you guys about these little lipo watchers I bought. They keep an eye on the voltage of the lipo cells and notify you by an alarm if one cell gets low. But the problem I had with them is that the light on the device seems to drop the voltage pretty quick. So it seems more like a battery discharger. For now I have quit using them.
So, am I the only one that has any of these things? no ideas from you guys?
Sky_Captain is offline Find More Posts by Sky_Captain
Old Sep 27, 2009, 03:33 PM
NYFlyer is offline
Find More Posts by NYFlyer
Syracuse NY area
Joined Dec 2003
I think they are just for checking the lipos, not leaving installed on them. but if they cause a discharge, they could be used to bring packs to a storage voltage.
NYFlyer is offline Find More Posts by NYFlyer
Old Sep 27, 2009, 03:40 PM
ktaylor is offline
Find More Posts by ktaylor
Oh look I'm bleeding...
ktaylor's Avatar
USA, IL, Rock Island
Joined Dec 2005
Originally Posted by export!
Hay Ken, I don't think there is any chance in hell I can put the Red Bull motor in this mini "Extra" thingee. I think it needs a motor of approx 300W and I might even want to run it on 3 cell - not sure about that yet. I think my Red Bull Lipos are too much for it.
I wish HC had a motor in the 35-30 line with a little less kv. I have the 1700kv in my F1 and it is flat out awesome but I don't think I'm looking for a lot of speed in this plane. I suppose the 1100kv edition would be OK if I want to run on 3S.
I'm thinking I want to swing the largest prop that ground clearance will allow and go for craploads of thrust and a top speed of maybe 50.
motor http://www.hobbyking.com/hobbyking/s..._1000kv_/_470W
run on 4 cell with a 9x6 prop 29 amps 410 watts 3.2 lbs static thrust
ktaylor is offline Find More Posts by ktaylor
Old Sep 27, 2009, 03:45 PM
export! is offline
Find More Posts by export!
Badius Boy
Windsor ON Canada
Joined Mar 2007
Yep - as discussed that should be an awesome option. Thanks. F2 flew awesome.
export! is offline Find More Posts by export!
Old Sep 27, 2009, 04:07 PM
ktaylor is offline
ktaylor's Avatar
Joined Dec 2005
sweet!
Old Sep 27, 2009, 04:19 PM
Gunfighter51 is offline
Find More Posts by Gunfighter51
Joined Jun 2007
yankeefan,
JOBA RULES!
Joba lives in my apartment complex when he's in Lincoln.
Gunfighter51 is offline Find More Posts by Gunfighter51
Old Sep 27, 2009, 04:32 PM
yankeefan is offline
Find More Posts by yankeefan
yankeefan's Avatar
Joined Sep 2009
the yankees win the yankees win
division champs again world series here we come
any back to the real thing does anyone knows if i can cut servo leads and cut the middle wire and put both end wires together will that work for binding i lost my binding plug
yankeefan is offline Find More Posts by yankeefan
Old Sep 27, 2009, 05:40 PM
calvino is offline
Find More Posts by calvino
calvino's Avatar
Joined Aug 2007
You can make a bind plug with an old servo wire. Connect the 2 outer wires together and you have a bind plug. Dont know any more though
calvino is offline Find More Posts by calvino
Old Sep 27, 2009, 06:29 PM
FERNDALE AIR FOR is offline
Find More Posts by FERNDALE AIR FOR
ferndale air force
FERNDALE AIR FOR's Avatar
Joined Jul 2006
Good going Cal and Scott.
Lou, the look on her face on the first take off will be priceless.
Fern
FERNDALE AIR FOR is offline Find More Posts by FERNDALE AIR FOR
Old Sep 27, 2009, 07:18 PM
Flying is Freedom
Annandale, VA
Joined Jul 2007
I think the original idea was for them to remain plugged into the battery and let you know when the battery is getting too low. But, I think the lights draw more power than they should.
I guess I will drop it as it seems like a poor product since no one is interested in it.
http://cgi.ebay.com/Parts-2-3Cells-l...#ht_1806wt_887
Old Sep 27, 2009, 07:44 PM
ktaylor is offline
ktaylor's Avatar
Joined Dec 2005
Wheelnut, actually, it just wouldn't work for me since I have some 5 cell & 6 cell packs.
Now this however I am interested in trying. I can see it being handy to see what kind of torture I really am putting my packs through.
http://www.hobbyking.com/hobbyking/s...idProduct=9282
yankeefan's Avatar
Joined Sep 2009
E-flite P40 warhawk
Ok I Finished My P40 Found That My Rx Ar6100e Is Dead Will Not So I Had To Use My Futaba 2.4 Ghz Tx And Rx Here Are Some Picture Just Hope The Weather Is Good Tommorow For Maiden After Work
Old Sep 27, 2009, 07:49 PM
Flying is Freedom
Annandale, VA
Joined Jul 2007
Taylor,
I think $27.00 is a little excesive for a device that only watches one battery pack. Unless it could be wired to watch more packs at once.
I'm sure it has other uses, but not anything I currently need.
Yankeefan, nice. I wish I had one of those.
That is the first time I have heard of a dead AR6100e, was it DOA?
Old Sep 27, 2009, 08:00 PM
ktaylor is offline
ktaylor's Avatar
Joined Dec 2005
I dunno, $27 compared to the cost of my battery packs... Granted the cost of packs is dropping, but my 5 cell 4000 mah packs were about $100 each when i bought them. Might be worth it to know if I'm beating them too hard.
Old Sep 27, 2009, 08:13 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Hmmmmm.... I gotta catch up on this stuff tomorrow. Homework tonight.
BUT........... Well, today the weather decided that my threats were getting scary enough so it kicked the wind machine into high gear. I got some extreme winds now and two of the battery-rescue tools came down from the tree. No battery yet but it's looking very likely. Probably by tomorrow it'll be down.
I cut a new Weasel Jet blank already out of some Dollar Tree foam that I stripped all the paper off of. It's extremely lighter and weaker but CF will solve that. I'll be putting the little 2212-6 on it; should be wicked fast.
That's all. Homework now.
Piece is offline Find More Posts by Piece
Electric Airplane Thread of the Month - August 2005 jbourke Electric Plane Talk 19 Sep 28, 2005 02:16 AM
Electric Airplane Thread of the Month - May 2005 jbourke Electric Plane Talk 3 Aug 28, 2005 02:16 AM
Fuel Airplane Thread of the Month - May 2005 jbourke Fuel Plane Talk 1 Aug 28, 2005 02:16 AM
Paper airplane thread? windsurfer Parkflyers 4 Jul 25, 2003 04:20 PM
Any airplane building service? Rob R Aircraft - Electric - Airplanes (FS/W) 2 Mar 26, 2002 08:24 PM
