Old Aug 28, 2009, 04:52 PM
helivsFMX is offline
Find More Posts by helivsFMX
helivsFMX's Avatar
Arizona USA
Joined Mar 2009
how do you make a foam wing airfoil???
How exactly do you "roll" an airfoil shape into foam? Do you hang foam off the edge of a table and roll a rolling pin over so the foam bends down? Or do you put the foam on top of a rolling pin and heat it? Or do you draw lines equally spaced lengthwise across the wing and bend at those lines? I just dont get it. All the threads I have read, people say "just roll an airfoil into the wing"... Easier said than done! haha So anyone that can describe how to do it, please do! or if there is somewhere else I should look, let me know.
James
helivsFMX is offline Find More Posts by helivsFMX
Old Aug 28, 2009, 05:00 PM
Pukin_Dog is offline
Find More Posts by Pukin_Dog
Åtvidaberg, Sweden
Joined Jul 2008
I read that some guys heat the Depron and then rols it or bend it over and edge small steps at a time. I have tried it on a fuselage and it worked fine. But the heat is hard to get just right. It melts quick if it gets to much.
Pukin_Dog is offline Find More Posts by Pukin_Dog
Old Aug 28, 2009, 05:37 PM
djacob7 is offline
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
EPP foam is hard to deform except maybe with heat.
FFF can be deformed cold by rolling it with your hands on a pipe.
djacob7 is offline Find More Posts by djacob7
Old Aug 28, 2009, 05:42 PM
helivsFMX's Avatar
Arizona USA
Joined Mar 2009
Well I am using FFF. I should have mentioned that. So I can just bend it across something? It will hold a shape like that? Should I heat it at all?
Old Aug 28, 2009, 07:05 PM
chaosMurphy is offline
Find More Posts by chaosMurphy
Registered HotGlue Addict
chaosMurphy's Avatar
Joined Dec 2006
Quarter inch FFF
Skin one side
Rolled across PVC
No heat
Couple ribs, every thing stays put, no problem
chaosMurphy is offline Find More Posts by chaosMurphy
Old Aug 28, 2009, 07:34 PM
PatricMichigan is offline
Find More Posts by PatricMichigan
PatricMichigan's Avatar
United States, MI, Hillsdale
Joined Apr 2008
http://www.rcgroups.com/forums/showp...8&postcount=75
is a link to see how it was done in the Blu-baby thread.
depending on the wing in question, you might not need the ribs even. My 33" BB doesn't need any ribs to keep the airfoil.
It just sounds terrible - really thought I was going to ruin it the first panel I curved like that.
Patric
PatricMichigan is offline Find More Posts by PatricMichigan
Old Aug 28, 2009, 07:39 PM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
FFF rolled w/o heat is weak. The GPW foam bender is popular. I use a couple 2x4s spaced 1/2" apart and a cheap Harbor Freight heat gun.
Note that "heat tempering" the non-skin side, even areas that are not curved, will increase strength and stiffness significantly.
rich smith is offline Find More Posts by rich smith
Old Aug 28, 2009, 07:42 PM
helivsFMX's Avatar
Arizona USA
Joined Mar 2009
wow I guess it really is easy... That video makes it look really easy! It kinda made me laugh at myself haha
thanks guys
Old Aug 29, 2009, 03:02 AM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
An alternative method is my three-bend airfoil. See my blog.
Note, this works wonderful with BP Hobbies White Construction Foam. I have not tried this with other foam material yet. I use either a flat wing or a KFm with Depron.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Aug 29, 2009, 07:07 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
FMX, the cold bend process is good if you're making ONE wing panel , for two identical panels , the Bendfoam jig is the easiest choice .. and you can bend one wing or 4000 + and have them all come out the same ... "D
gpw is offline Find More Posts by gpw
Old Aug 29, 2009, 11:04 AM
djacob7 is offline
djacob7's Avatar
Joined Jan 2009
Rusty: Your 3-bend airfoil is simple and works well I'm sure.
But I noticed that the airfoil doesn't go up to the end of the rib. Why is that?
Dan
Old Aug 29, 2009, 08:34 PM
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
I made the rib longer for the sole reason to add a bit of stiffness at the end of it, where it tapers to a point. I've also made them shorter to match, too.
Question how do you make a foam fuse? Scorch Scratchbuilt Indoor and Micro Models 15 Dec 18, 2007 12:25 AM
Question How do you make wing struts? rcwilbur The Builders Workshop 5 Aug 24, 2005 12:07 PM
How do you make yu wing cutting templets ? blacksheep Slope 4 Dec 10, 2004 04:31 PM
How do you make your own wing??? pooorboy Foamies (Kits) 2 Nov 03, 2002 02:21 PM
How do you make channels in foam? Jim McPherson Foamies (Kits) 8 Sep 21, 2001 09:00 PM
