Old Sep 01, 2009, 03:11 PM
I_Gotts_Ta_Fly is offline
Find More Posts by I_Gotts_Ta_Fly
GorillaGlue, Tape...I'm good
SillyCornValley, CA, USA
Joined Jun 2007
Originally Posted by salat
looks like horror movie. especially soundtrek
Kostya
Spooky...is that the Freddy Krueger mask?
I_Gotts_Ta_Fly is offline Find More Posts by I_Gotts_Ta_Fly
Old Sep 01, 2009, 05:54 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Thanks for posting CT2. It's definitely a static cam only.
Dennis - good results for inflight vid that KnObby posted.
My keychain one on the way and I'll be happy if my vid turns out the same.
NitroCharged is offline Find More Posts by NitroCharged
Old Sep 01, 2009, 07:07 PM
Dennis H. is offline
Find More Posts by Dennis H.
Dennis H.'s Avatar
Denton Tx.
Joined Sep 2003
That one reason why I bought one, Its small and cheap. There are other video posted on YouTube too.
Dennis H. is offline Find More Posts by Dennis H.
Old Sep 02, 2009, 11:51 AM
Dennis H.'s Avatar
Denton Tx.
Joined Sep 2003
Well I just got mine, Plug into my pc now charging the battery.
The manual is a joke. Really can't understand it, I'll have to play around with it to get it to work.
Old Sep 02, 2009, 01:40 PM
Dennis H.'s Avatar
Denton Tx.
Joined Sep 2003
Well after an hour of playing with it, I got it to work.
two problem so far WITH MINE, Maybe someone else will not.
The first one is really not a problem, But setting day, time, and year, Mine show the year 1980! etc. Lol.....
The 2nd one, With cam laing flat. Photo and video are facing to the left. Later I'll open up the case and see what I can do.
Old Sep 02, 2009, 02:49 PM
Dennis H.'s Avatar
Denton Tx.
Joined Sep 2003
Well don't bother to open the case up, The cam is solder to the PC broad.
I took the cam for a test drive, I drove around for about 35 min. The video was not bad at all, walk in to a store with it still on, video inside store was not very good. lighting?
But outside in the sun was good.
Maybe this weekend I'll take it flying.
Old Sep 14, 2009, 05:34 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I got my keychain cam in today. What an ordeal......
First thing was to record some video and check out the quality. The brightness was fine but it was out of focus. I opened up the case and trial and error resulted in 1/4 turn clockwise for the clearest image.
Sweet.... Ooooops! .... a part fell off the board....!
Nope - it won't work without it - soldered it back on once I located the place where it belonged.
Great! Now to change the time stamp....
You lucky little campers get a free ride on this one. Two hours it took me to trial and error all manner of things to get it to change.
This is it and I know it seems simple... now..
Create a text file called userconfig.txt
Enter the date and time like this: 2009-09-14 19:50:00 (24 hour time) and save it in the root directory of the cam.
Unplug the cam. Switch it on, record something and then plug it back into the PC. The correct date stamp is now there (you'll see the video file has the right date and time in the file name). The txt file will have disappeared from the root directory now meaning the date update was successful, so don't panic.
This unit is definitely light enough stripped down for Indoors Micro Cam! Most of the weight is the 260mah lipo in there and the casing. By freeloading the models power, you'd eliminate the need for it. The cam is held in place with hot glue blobs. You could streamline things by removing it and just having the cam lens peeping out of the model. I think by using some of that thin heatshrink would be fine for insulating it.
Correct Date and Time now showing on video.
Old Sep 14, 2009, 06:46 AM
salat is offline
Find More Posts by salat
Trying To Takeoff
salat's Avatar
Novosibirsk, Siberia
Joined Dec 2006
Hello NC!
How good is KeyChain compared to Pen? Is it lighter without case and battery?
Kostya
salat is offline Find More Posts by salat
Old Sep 14, 2009, 07:05 AM
Dennis H.'s Avatar
Denton Tx.
Joined Sep 2003
The best run time I got on mine is 45 min. of recording about 362mb
Trying the time stamp trick, No luck yet.
Old Sep 14, 2009, 07:29 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
If it wont let you do the new time stamp, format the cam and retry.
The Pen sucks Salat. This key chain cam is good for the price (20 bucks off of ebay delivered).
I'll see how long I can record for Dennis.
Old Sep 14, 2009, 07:53 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I got 12mins of recording....
I'm cycling the lipo at the moment as it was way down when I measured it this morning while seeing why the cam had such a short record time..
Old Sep 14, 2009, 08:20 PM
Dennis H.'s Avatar
Denton Tx.
Joined Sep 2003
!2 min of recording, Bummer.
Format the cam, How did you put the fat 32 back in?
Old Sep 14, 2009, 08:39 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I right click on the removable drive icon and select format from the list. Then I just click 'start'.
The lipo seems pretty saggy. My guess is it's been on the shelf too long. If I can't cycle it back up, I'll replace it with a 210 I have here. I've soldered on a micro jst lead so I can use my flightmax 138mah for testing record time and make it easier to cycle the lipo.
Old Sep 15, 2009, 12:05 AM
Dennis H.'s Avatar
Denton Tx.
Joined Sep 2003
Sounds like a good idea, Good luck.
Formating works thank you.
Old Sep 15, 2009, 05:35 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Lipo is the problem. Even after cycling, I could only get ~89mah into it each time. I replaced it.
Night vision video camera for RC Ben74 Power Systems 21 May 24, 2009 12:51 PM
Litestick w/ Video Camera ToddL Parkflyers 14 Sep 04, 2002 05:24 PM
Mini Max hauls up a video camera! Vonbaron Parkflyers 0 Nov 05, 2001 04:52 PM
tiny wireless video camera? jas_Qfix Power Systems 19 Jul 14, 2001 07:09 PM
My new LS-FD with new live video camera jas_Qfix Parkflyers 2 Jul 10, 2001 12:41 AM
