Old Nov 26, 2011, 07:16 AM
Mode One is offline
Find More Posts by Mode One
Closed Account
Joined Dec 2006
Although not to a new builder, I just got through sending plans and instruction for a Pica Aeronca Sedan to someone else for free, as I determined that my R/C "to do list" needed paring down! I have offered help and opinions to people who have posted here with questions on many occasions. When I have done so, I have done it through PMs, so it is more of a personal conversation, which I think is important as there is less chance for confusion; or, being overwelmed by the amount of different ways a task can be accomplished!
The above thought has caused me to go back to a contact to see how he is progressing.
Mode One is offline Find More Posts by Mode One
Old Nov 26, 2011, 03:51 PM
Taget is offline
Find More Posts by Taget
Taget's Avatar
United States, MI, Marquette
Joined Dec 2010
Originally Posted by cracksmeup View Post
Hi guys ! i just got my plans for Ivans twin otter and albatross both 84 inch wing span and its thanksgiving, it dont get any better than this! TO ALL YOU BUILDERS OUT THERE , HAVE A GREAT HOLIDAY . joe
I am looking at doing Ivan's albatross next winter, hope to see a build log.
One thing I found daunting about building from plans was figuring out the materials needed. I spent quiet a bit of time going over the plans checking and rechecking before I ordered. Any tips ?
Taget is offline Find More Posts by Taget
Old Nov 26, 2011, 04:18 PM
cracksmeup is offline
Find More Posts by cracksmeup
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
Taget after me building his solent already i have a few tips . First if you dont have one buy a balsa stripper and make your own balsa strips .The ones you buy you have no control over how soft they are and will most likly break when trying to bend. Second go to Luke z ,s ivan thread and look for capt ahab s albatross build ,A picture is worth a thousend words and the capt can build. third ,build it just like the plans and try not to change a thing . The only thing i changed on the solent was to add some light ply behind and in front of the wing i did not trust just 1/8 balsa where the wing bolts and dowl went through. And last but not least if you have any questions go to lukes thread and ask, there are alot builders of Ivan and happy to help you including me. joe http://www.rcgroups.com/forums/showthread.php?t=710485
cracksmeup is offline Find More Posts by cracksmeup
Old Nov 27, 2011, 07:34 AM
Mode One is offline
Closed Account
Joined Dec 2006
If you live close to a hobby shop that has a supply of balsa simply buy the balsa you need to complete whatever portion of the build your working on. In other words, start with small steps maybe the wing or tail feathers and get a taste of how the process works. By the next time you do your next "Scratch from plans build", you'll understand the process enough to buy all your Bill of Materials at one time.
If you do not live close to a hobby shop and need to drive some distance; or, order from a supplier such as Balsa USA; or, other, basically do the same thing, start with the tail feathers and figure out what you will need. Then do the wing and finally the fuselage. Break it down into manageable portions. Generally, if I find I need 4 sheets of 3/32nds for ribs, I'll buy 5, etc. I like having a stock pile of balsa around, also, if a sheet is unusable or I screw it up, I have an extra, ready to be used.
The entire process of building models is breaking the process down into manageable portions.
Old Nov 27, 2011, 08:08 AM
cracksmeup's Avatar
Joined Jun 2009
balsa
Most of ivans frames are 3/16 sticks i make my own sticks out of sheets. Most of the sheeting is 1/16 sheets . Like i said it takes getting use to building ivans desighns cause they are so light . I most have broken 20 sticks before i finaly got sheeting on things to stop the wreckage,lol I get my balsa here and they had good stuff. joe http://www.nationalbalsa.com/default.asp
Old Nov 27, 2011, 08:47 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Just to show I hadn't nodded off, yet.....
Carrying on from my posts on the start of a Depron version of a balsa Spitfire, (posts #1296 and #1394), she has come on a little.
But I'm still in no rush.
By the way, it's all held together with pins and tape, so if it looks a little crooked........
eflightray is offline Find More Posts by eflightray
Old Nov 27, 2011, 09:36 PM
Mode One is offline
Closed Account
Joined Dec 2006
National Balsa, Balsa USA, there are many companies selling balsa.
Old Nov 27, 2011, 10:13 PM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
Why use a naturally available renewable resource when you can make a petroleum product fly and then take 500 years to break-down in landfill?
I can't think of a single good reason. []
Curare is offline Find More Posts by Curare
Old Nov 28, 2011, 05:38 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Someones got to keep the poor petroleum industry going, wouldn't wont them to go out of business and lay off all those happy workers.
Old Nov 28, 2011, 06:22 AM
Mode One is offline
Closed Account
Joined Dec 2006
Do we really need to go down this road? Certainly, what your saying has some validity. However, let's just get people building and not worry about the very, very small amount of polution being created by R/Cers building in foam!
Also, unless you cover in silk, silkspan or tissue, the coving material your using lasts a goodly long time in the landfill, too!
Old Nov 28, 2011, 06:48 AM
Mode One is offline
Closed Account
Joined Dec 2006
Looking back over your interests here at RCGroups, the above statement would seem incongruous, as you do build in FOAM! Maybe the above was said tung in cheek! If so, you fooled me, really funny, Ha ha!
Old Nov 28, 2011, 06:06 PM
Mode One is offline
Closed Account
Joined Dec 2006
Moving on from the subterfuge; or, joking, if that is what it was, I just hope that people look at building in what ever material they feel will work for them!
If you've read over this thread which now has more then 100 pages of posts in it. It is confusing what the actual health is of model building is in the U.S. Some people feel it is alive and well and some feel it is down for the count. My opinion is it is likely somewhere in the middle; but, I don't think it is growing and is most likely declining. What I think, isn't important to you and it's not very important to me, as long as I can find the materials I need to build the way I want from what I want, I'll be O.K. I can only do my best to promote this part of the hobby and that's about it!
Old Nov 28, 2011, 06:36 PM
cracksmeup's Avatar
Joined Jun 2009
I think you are correct about being in the middle of the road for new builders and i also think alot of the new builders are going to be building with depron and foam witch doesent bother me at all as long as they are building something at all. I wonder what builders sad when ca came out cause back then we were using ambroyd glue ,if i spelled that right. I was there when 4 cycle motors came out and i was trying to fly helis with no gyros on the tails cause theywere not invented yet. My club had john calland in it and he made hardware for the first flight sim put out by dave brown products and we got to fly it at a meeting before it was sold. We have seen 2.4 radios come out so we dont have to grab a pin before we fly now. There will always be builders and inventers in our hobby and just like mode one ,i try to help new builders any time i can. joe
Old Nov 30, 2011, 02:31 PM
toki891 is offline
Find More Posts by toki891
builds more then he flies
toki891's Avatar
United States, WI, Almena
Joined Oct 2010
i didnt read this whole thread. so there.
But heres a thought / my story.
I always wanted to fly and build rc planes. when i was 10 (17 years ago) i always got tower hobbies catalogs and would shuffle through them till the pages were falling out. but of course could never afford or talk my parents into getting me anything. so 2 years ago i was working a new job and tons of overtime. i had money and broke down and bought a dynam hawk sky. i crashed and rebuilt that foam disaster over and over. but i taught myself to fly, fix, improvise, setup a plane, the do's and don'ts, and the importance of safety. i then moved on to scratch built foamies. loved them and still do. i got a edf rtf jet as a gift but never bought another rtf/rtf plane. I then met an old guy getting out of the hobby and bought a giant glider and a crashed plane from him for cheap. then some 40 size motors and such, and then he threw in his old field box and a BUNCH of stuff. spent my time rebuilding a wrecked sig lt40 that was given to me in a garbage bag.
so i feel i graduated to balsa kits. if i had spent the time building a balsa kit and then tried flying it like i did my hawk sky... it would have been game over lol.
toki891 is offline Find More Posts by toki891
Old Nov 30, 2011, 03:41 PM
cracksmeup's Avatar
Joined Jun 2009
You forget that when me and others started flying in the early 70s there were no arfs or foamys .If you did not build a kit you did not fly. I could have given up and waited for 20 years but i would have missed out on so much fun and all the flying friends i have made in the last 35 years .I also would not have a basement and garage full of airplanes either like i have now.lmao
Question How do I bring my batteries back to life? mr_ken Batteries and Chargers 2 Dec 28, 2003 11:28 AM
How do we make accurate motor mounting holes Al P Electric Plane Talk 3 Jun 17, 2003 09:15 AM
How do we download photos on a Mac from Canon digital camcorder ? Al P Life, The Universe, and Politics 2 Mar 12, 2003 06:19 PM
How do I determine model/engine size? tolladay Scale Kit/Scratch Built 9 Sep 19, 2002 06:44 AM
How do we make commercial aviation more secure? ShinySteelRobot Life, The Universe, and Politics 24 Sep 17, 2001 10:16 PM
