Old Feb 20, 2011, 06:28 PM
joesmith285 is offline
Find More Posts by joesmith285
Game on
joesmith285's Avatar
United States, IN, Fort Wayne
Joined Nov 2008
Originally Posted by rcbirk21 View Post
by all means correct me if im wrong jim, but those look like some servos that are better than 985's
Yah, They are 7945s. Very Fast
joesmith285 is offline Find More Posts by joesmith285
Old Feb 20, 2011, 06:47 PM
litespeed is offline
Find More Posts by litespeed
Pain? I know pain!
Weldon Spring, Missouri
Joined Mar 2005
Originally Posted by Draknkep View Post
Hi Tom
First, take an undersized drill bit, and carefully drill through the blind nut. Make sure it is undersized, and you go slow, as you don't want to mess up the threads. Then take a screw the same size and thread a nut onto it (to "clean the threads when it is taken off) then grind a short taper (about .125" to .187") onto it. Then using a abrasive "cut-off" wheel in a Dremel tool, cut two grooves (one on each side) length-ways on the screw. Take the nut off, cleaning the threads. Basically you are making a tap. The carefully work the screw into the hole, do not push on it, as you do NOT want to push the blind nut out inside the fuselage.
SteveT
Thanks for the tip....just need to buy more sae screws. I have thousands of metrics.....
Tom
litespeed is offline Find More Posts by litespeed
Old Feb 20, 2011, 06:56 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by PinkYakRC View Post
Ahhh...reminds me when I lost a blind nut into the fuse on my 68" Velox....then I did it again on my 70" Slick...
Usually most people learn the first time.... Slow learner?????
Just kidding of course!!!
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 20, 2011, 07:16 PM
djmoose is offline
Find More Posts by djmoose
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
Has anyone received a warped rudder?
I didn't notice it until I glued it on the stab today...but it seems the bottom of the rudder is warped to one side. (when the counter balance it centered, the bottom of the rudder is off to one side by about an inch)
Any tips on correcting this?
djmoose is offline Find More Posts by djmoose
Old Feb 20, 2011, 07:45 PM
MLT67 is offline
Find More Posts by MLT67
Joined Nov 2005
Tape the counterbalance to the stab - carefully bend the bottom of the rudder straight or a little past straight - then use a heat gun to shrink the wrinkles out of the covering and the rudder should stay straight
MLT67 is offline Find More Posts by MLT67
Old Feb 20, 2011, 07:54 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
I use and Iorn to heat up the wood and covering and you will be surprised how much it will flex when heated.
Hold it a little past where you want it and let the covering and wood cool and it should hold where you want it. It might take a few time to get it perfect
losifanatic is offline Find More Posts by losifanatic
Old Feb 20, 2011, 08:12 PM
xsubsailor is offline
Find More Posts by xsubsailor
Pants on the ground
xsubsailor's Avatar
exit 26 Jersey
Joined Jul 2007
the New thread for July's throwdown in Jersey is up
http://www.rcgroups.com/forums/showthread.php?t=1393624
xsubsailor is offline Find More Posts by xsubsailor
Old Feb 20, 2011, 09:07 PM
jedoug is offline
Find More Posts by jedoug
jedoug's Avatar
United States, CO, Littleton
Joined Jun 2009
Started building mine this weekend.
jedoug is offline Find More Posts by jedoug
Old Feb 21, 2011, 12:11 AM
JK13 is offline
Find More Posts by JK13
Goes to eleven!
JK13's Avatar
Bellingham WA
Joined Mar 2009
Joe
Have you tried the HS-7940TGs out? I use them on the 70 Slick and 72 Extra 330 - at 7.4V they are 0.6 sec. You can really feel the quickness!
With your uber-talent I would thing a great fit!
Joe
JK13 is offline Find More Posts by JK13
Old Feb 21, 2011, 08:20 AM
-P> is offline
-P>
Find More Posts by -P>
-P>
Somerset, NJ
Joined Mar 2010
Just a heads up..
Guys,
I couldn't get my elevator halves to line up with the stab. They just were off by about a degree or two. Finally, I came to the realization that the stab was probably warped. I checked with an incidence meter and the left stab tip was indeed higher by a degree or so.
It's probalby not a big deal, but if you're anal about this sort of thing, I'd suggest you check before you glue the stab in.
-P>
-P> is offline Find More Posts by -P>
Old Feb 21, 2011, 10:23 AM
PinkYakRC is offline
Find More Posts by PinkYakRC
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
Originally Posted by -P> View Post
Guys,
-P>
I had the same problem. On of my elevator halves is a little off, just a degree or two. Mine flies just fine, no problems there.
PinkYakRC is offline Find More Posts by PinkYakRC
Old Feb 21, 2011, 01:07 PM
relax1 is offline
Find More Posts by relax1
Tampa , FL
Joined Sep 2003
I have eight flights on the 71" slick,, 4 Sunday and 4 today. This is by far one of best airframe i have flown. It feels like I'm flying a G5 simulator. This is the one i been waiting for. It feel like there is nothing I cant do with this airplane.
ITS AWESOME!!!
Luis
relax1 is offline Find More Posts by relax1
Old Feb 21, 2011, 01:13 PM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
Congrats, glad you like it!
blucor basher is offline Find More Posts by blucor basher
Old Feb 21, 2011, 01:41 PM
Sippin the Koolaid!
Joined Oct 2007
Its 75 out right now. All my batts for the slick are charged and I cant fly b/c it blowing 25+ out right now true meaning of torture
Old Feb 21, 2011, 01:44 PM
djmoose is offline
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
Thanks for this...was worried there for a sec.
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
