Old Feb 20, 2011, 12:36 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Originally Posted by rcbirk21 View Post
Is that from the US warehouse or the chinese warehouse?
from the US warehouse... they're stocking a lot more packs now too.
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Feb 20, 2011, 12:48 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
sweet. really wish they would start to stock the nanos as well
rcbirk21 is offline Find More Posts by rcbirk21
Old Feb 20, 2011, 02:18 PM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
71 going together
jsmith285 is offline Find More Posts by jsmith285
Old Feb 20, 2011, 02:24 PM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
by all means correct me if im wrong jim, but those look like some servos that are better than 985's
Old Feb 20, 2011, 02:59 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Originally Posted by johnnyrocco123 View Post
So you plug in you motor battery with the throttle stick at full, and then you gradually move up the end point % toward 100 until you hear the beep.
Then you move the stick all the way down and gradually increase % until it arms.
Do I have this?
I don't know how mine is set up but I use a low idle on the gear switch. So before I take off the prop s spinning at a low rate. Any move of the stick gives me more. I have all my 3dhs planes set up like this.
try it.
robj is offline Find More Posts by robj
Old Feb 20, 2011, 03:04 PM
robj is offline
robj's Avatar
Joined Nov 2008
BTW I did find the tail heavy spot on my 70 yesterday. The 8s 2x3600 40c turnigys weigh in at 29oz. I bought these 3 hyperion 2600 from an addict and they are a lot lighter. 9oz to be exact. I move the battery up a bit but wanted to keep it under 2 straps. Well after take off I had about 4-5 clicks of down trim to deal with. Hovered a little easier with maybe the lighter plane and probably more because of the cg. It flew fine but the landing was interesting. Had to come in a little faster to keep the tail up!
I may check it on the sticks to see where i was.
Also this was a maiden after the motor box replacement. No trimming needed with the regular battery packs.
In the pic you can see the normal placement of the heaver setup.
Rob
Old Feb 20, 2011, 03:22 PM
litespeed is offline
Find More Posts by litespeed
Pain? I know pain!
Weldon Spring, Missouri
Joined Mar 2005
I just started building my 71" today (Yea!!!) and second step stopped me cold in my tracks. I tried to install the tail wheel and one screw only goes in about 1 1/2 to 2 turns, the second about 4 or so. I tried to torque them a bit and they feel like they are bottoming out or the threads are not cut through. The screw comes out clean with no thread damage. Don't know what to do and do not have a tap this small.
Help!!!
See pictures,
Tom
litespeed is offline Find More Posts by litespeed
Old Feb 20, 2011, 03:24 PM
aerosheldon is offline
Find More Posts by aerosheldon
No one has more fun than me
aerosheldon's Avatar
United States, CO, Denver
Joined Sep 2003
It is probably glue in there and a tap is the best/safest way to clean it out.
aerosheldon is offline Find More Posts by aerosheldon
Old Feb 20, 2011, 03:44 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Help!!!
See pictures,
Tom
Hi Tom
First, take an undersized drill bit, and carefully drill through the blind nut. Make sure it is undersized, and you go slow, as you don't want to mess up the threads. Then take a screw the same size and thread a nut onto it (to "clean the threads when it is taken off) then grind a short taper (about .125" to .187") onto it. Then using a abrasive "cut-off" wheel in a Dremel tool, cut two grooves (one on each side) length-ways on the screw. Take the nut off, cleaning the threads. Basically you are making a tap. Then carefully work the screw into the hole, do not push on it, as you do NOT want to push the blind nut out inside the fuselage.
SteveT
SteveT. is online now Find More Posts by SteveT.
Old Feb 20, 2011, 03:49 PM
fmidgett is offline
Find More Posts by fmidgett
fmidgett's Avatar
Durham NC
Joined Jul 2004
Wow. Great tip. Cool!
fmidgett is offline Find More Posts by fmidgett
Site Sponsor
Old Feb 20, 2011, 03:52 PM
SteveT.'s Avatar
San Jose, CA
I know I can't give flying tips, as I can't fly like a lot of the guys, so, I help with building tips when I can. A person does tend to learn a little in 52 years (off and on) of building...
SteveT
Latest blog entry: My hangar...
Old Feb 20, 2011, 04:23 PM
fltekdiver is offline
Find More Posts by fltekdiver
United States, FL, Melbourne
Joined Jan 2010
USA Warehouse
fltekdiver is offline Find More Posts by fltekdiver
Old Feb 20, 2011, 04:25 PM
soundchaser is offline
Find More Posts by soundchaser
soundchaser's Avatar
Joined Sep 2009
Originally Posted by jsmith285 View Post
71 going together
Hey Joe,
Those don't look like 985's you're putting in there?
soundchaser is offline Find More Posts by soundchaser
Old Feb 20, 2011, 06:16 PM
PinkYakRC is offline
Find More Posts by PinkYakRC
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
71 going together
Nicey nicey!
PinkYakRC is offline Find More Posts by PinkYakRC
Old Feb 20, 2011, 06:18 PM
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
Originally Posted by Draknkep View Post
Hi Tom
First, take an undersized drill bit, and carefully drill through the blind nut. Make sure it is undersized, and you go slow, as you don't want to mess up the threads. Then take a screw the same size and thread a nut onto it (to "clean the threads when it is taken off) then grind a short taper (about .125" to .187") onto it. Then using a abrasive "cut-off" wheel in a Dremel tool, cut two grooves (one on each side) length-ways on the screw. Take the nut off, cleaning the threads. Basically you are making a tap. The carefully work the screw into the hole, do not push on it, as you do NOT want to push the blind nut out inside the fuselage.
SteveT
Ahhh...reminds me when I lost a blind nut into the fuse on my 68" Velox....then I did it again on my 70" Slick...
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
