Old Feb 15, 2011, 08:26 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
I use a123 flight packs in mine but the bec pro is very well proven.batteries can go bad just like a bec can.Just whatever you feel the most comfy with.
Manta1 is offline Find More Posts by Manta1
Old Feb 15, 2011, 08:45 PM
jedoug is offline
Find More Posts by jedoug
jedoug's Avatar
United States, CO, Littleton
Joined Jun 2009
Received my 71 today. This thing looks sweet. Question I have for you guys is I fly at about 5400' asl and am wandering what motor, battery, and prop you guys think I should go with.
jedoug is offline Find More Posts by jedoug
Old Feb 15, 2011, 08:50 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Originally Posted by Draknkep View Post
What size are you using?? I use Castle 5.5mm (between ESC and motor) and 6mm between the ESC and battery if I need an extension, and also when I use a BEC, as I can get the 10 gauge wire and the wires from the BEC Pro into the 6MM bullets.
SteveT
What ever came with the motor. It came with the connectors for the esc too.
Originally Posted by rodsmith123 View Post
Anyone ever have a BEC pro problem/failure? I have a CC Bec Pro currently installed in the new Slick but am having second thoughts about using it instead of an A123 rxr pack.
I have run the standard cc bec in my 55" Extra for two years with no issues.
I have been running the A123 rxr packs in the 87" Extra for 130 flights with no problems.
Any input would be welcome. Thanks
Running a BEC in mine without issues and will be useing one in the 89 slick too. I have yet to have a UBEC fail on me (knock on wood)
losifanatic is offline Find More Posts by losifanatic
Old Feb 15, 2011, 08:51 PM
Sippin the Koolaid!
Joined Oct 2007
Originally Posted by ryan_m View Post
man that red looks pretty... I was set on the orange for the 59... but that red sure looks nice!
The red looks even better in person! I want to get a orange 59 but this darn red looks soooooo good
Old Feb 15, 2011, 08:55 PM
ssflylow is offline
Find More Posts by ssflylow
TEAM CANUCKER HUCKER
ssflylow's Avatar
Canada, AB, Medicine Hat
Joined Sep 2003
If your worried about a BEC failure, use one of these:
http://www.western-robotics.com/hercules_plane.html
I've used them in every electric plane I've ever owned. As close to bullet proof as it gets!!
ssflylow is offline Find More Posts by ssflylow
Old Feb 15, 2011, 08:56 PM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
jedoug - At 5400 my reccommendation would be:
Hacker A50-12L motor
APC 18x8 prop
8S 4000mah lipo
Castle HV85 ESC
Proven trouble-free powerful setup for high altitude.
blucor basher is offline Find More Posts by blucor basher
Old Feb 15, 2011, 09:03 PM
jedoug is offline
jedoug's Avatar
Joined Jun 2009
APC 18x8 prop
8S 4000mah lipo
Castle HV85 ESC
Thank you. I was looking at going with that motor but wasn't sure if I could do a 8s set up on it or not.
Old Feb 15, 2011, 09:43 PM
Sippin the Koolaid!
Joined Oct 2007
The 8s setup is awesome!
Old Feb 15, 2011, 09:49 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Probably 4mm then. I have yet to see anything larger than 4mm come on a motor or ESC.
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 15, 2011, 09:54 PM
Sippin the Koolaid!
Joined Oct 2007
I think your right and one I guess wasnt tight enough and fried
Old Feb 15, 2011, 10:00 PM
SteveT.'s Avatar
San Jose, CA
Two things I always do when using bullet connectors is to spray some Caig "De-oxit" (contact cleaner) into the connector before putting them together, I also slide some heat shrink over the connectors before putting them together then once plugged in, I slide the heat shrink on and shrink it down so that the bullet connectors can not come apart.
SteveT
Old Feb 15, 2011, 10:02 PM
aerosheldon is offline
Find More Posts by aerosheldon
No one has more fun than me
aerosheldon's Avatar
United States, CO, Denver
Joined Sep 2003
APC 18x8 prop
8S 4000mah lipo
Castle HV85 ESC
Then you use the BEC Pro??
aerosheldon is offline Find More Posts by aerosheldon
Old Feb 15, 2011, 10:06 PM
E-reevo is offline
Find More Posts by E-reevo
E-reevo's Avatar
Joined Aug 2010
So for the motor and esc wires is it best for them to be soldered together?
E-reevo is offline Find More Posts by E-reevo
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
OK me no trust bullet connectors on my motor anymore Mine burn up today. So I landed the plane OK so thats a good thing but I do have to direct solder the motor wires now( the bullet is no good anymore)
Sorry bro.I tested thos with big prop on that motor and didnt have any trouble with it.I did solder the wires after the test was over but I'm anal and superstitious lol...I also was not running 8s either tho.Terminals can get loose,corroded,etc.The ones i got with my test motor were of very good quality.I'm assuming they are the same type you got too.Sorry one got loose on ya.
Old Feb 15, 2011, 10:20 PM
Sippin the Koolaid!
Joined Oct 2007
I didnt have an issues with the ones on the SC. Though I double and triple checked those and heat shrank them together. I did heat shrink the ones on the 71 together too but it apparently was a little loose in the connector causeing arcking which caused it to burn up. I didnt really check those to see how tight there were so its my fault. If I would have double check and seen if one was loose I could have spread the pins a little to make it tight but I didnt (see what happen when you are in a rush ) I soldered these but if I do this again I will make darn sure they mate tightly next time
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
