Old Jan 30, 2011, 09:56 PM
ssflylow is offline
Find More Posts by ssflylow
TEAM CANUCKER HUCKER
ssflylow's Avatar
Canada, AB, Medicine Hat
Joined Sep 2003
The 85HV is too small for a 6s set-up, you'll cook it.
ssflylow is offline Find More Posts by ssflylow
Old Jan 30, 2011, 09:57 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Originally Posted by JEFFRO503 View Post
I hear ya....I actually bought this ICE 100 about 2 years ago....and have been just sitting on it. I bought for another project that never happened.....so I figured I'd use it.
Is something like the 85HV capable of handling more power than an ICE 100? I know it will handle 4s more ( 8S compared to 12S )......but when I'm running a 6S setup.....would it help?
I didnt trust useing a 85 amp esc thats why I got the 120HV instead (I pondered that purchase for a while). I just wanted more head room just incase I was harder on the throttle or if it was hot out the bigger esc will shead the heat better
losifanatic is offline Find More Posts by losifanatic
Old Jan 30, 2011, 10:00 PM
JEFFRO503 is offline
Find More Posts by JEFFRO503
www.rcdude.com
JEFFRO503's Avatar
Joined May 2006
Originally Posted by losifanatic View Post
Do you really need 2500 watts Thats a ton of power in a 9 pound plane. You will find that the extra power will make your plane jumpy and harder to hover and harrier smoothly. Thats why I took some power out of my 72SC. It still has enough power to pull out of anything instantly but is smoother on the throttle stick.
Wait....what? 9lbs? I was thinking these things were coming in around 10-11.5lbs? Yours is 9lbs?
JEFFRO503 is offline Find More Posts by JEFFRO503
Old Jan 30, 2011, 10:02 PM
ssflylow is offline
ssflylow's Avatar
Joined Sep 2003
Losi has hit the nail on the head. Too much power makes 3D flying twitchy. My 4.5lb 57" Extra had a ton of power(1200 watts), and it was harder to 3D than my 9lb. 2000 watt 70" Slick. Vertical lines were cool, but everything else was more difficult. Unless you have an ultra smooth left thumb, I'd say 2000 watts on the 70" birds is just right.
Old Jan 30, 2011, 10:03 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Actually, I believe that is the ESC that Ben originally recommended for 6S with an A50-16S using an 18X8 0r 18X10 prop.
SteveT
SteveT. is online now Find More Posts by SteveT.
Old Jan 30, 2011, 10:05 PM
ssflylow is offline
ssflylow's Avatar
Joined Sep 2003
Originally Posted by Draknkep View Post
Actually, that is the ESC that Ben did recommend for 6S with an 18X8 0r 18X10 prop.
SteveT
18" prop on 6s will drop your watts to 1600 or so. I run 18x8 on 8s and get 2k.
Old Jan 30, 2011, 10:07 PM
Sippin the Koolaid!
Joined Oct 2007
Most are 9 to 9.5 pounds. I believe safetyHawks 8s slick is only like 9.8pounds (my slick wont be here until tomorrow)
Old Jan 30, 2011, 10:12 PM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
One way to mitigate tons of power on these aircraft is to use a throttle curve. Set the curve so that you get more power at the last half of the stick. That way, at half throttle, you're in your hovering sweet spot, but when you punch out.... LOOK OUT .
BoneDoc is offline Find More Posts by BoneDoc
Old Jan 30, 2011, 10:14 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
the 85HV is severly under rated. it can without problem take 100a continuous. ben has stated on numerous occasions to treat it as a 100a esc
rcbirk21 is offline Find More Posts by rcbirk21
Old Jan 30, 2011, 10:16 PM
SteveT.'s Avatar
San Jose, CA
Please see the last paragraph of this post..... http://www.rcgroups.com/forums/showp...ostcount=12280
SteveT
Latest blog entry: My hangar...
Old Jan 30, 2011, 10:21 PM
www.rcdude.com
JEFFRO503's Avatar
Joined May 2006
I know exactly what you are saying. My 58" PA extra is putting out 1150 watts and it's at an exact 4.0lbs! BUT.....I do most of my 3D type flying at 1/2 throttle and below.
I am going to try a couple other props to see how it performs when I'm flying and just go from there. I'm thinking with the results i just got from the APC and zoar 19x8 props and the one APC 18X8E prop , I think I am going to try a APC 20X8 or possibly a Zoar 20X8. I think that will be the "sweet spot"
for my type of flying.
Old Jan 30, 2011, 10:22 PM
SteveT.'s Avatar
San Jose, CA
Ooooooo you said the bad words....that should be 58" "brand X"...
SteveT
Old Jan 30, 2011, 10:25 PM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
lol... we're tolerant people here. .
Old Jan 30, 2011, 10:35 PM
SteveT.'s Avatar
San Jose, CA
Well, I am sure you know my opinion of P.A. U.S.A.
SteveT
ssflylow is offline
ssflylow's Avatar
Joined Sep 2003
SteveT
Thanks for the link Steve, never read that one before.
Since I'm ordering a 71" tomorrow, I'll buy an 85HV instead of the ICE 100 and give it a go. I am running 8s so my amp draw is decent, and a couple hundred extra watts won't hurt my feelers too much.
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
