Espritmodel.com Heli Air
Old Dec 31, 2010, 10:50 PM
probro 2567
kwj48's Avatar
Midlothian,VA
Joined Jan 2006
Originally Posted by robj View Post
That is an interesting starting point. As AJ says balance it with the cowl off, fingers holding it up at the former with with the magnets. Pretty much where mine is.
Couldn't fine a pic of mine but found this and it's pretty close with the 2 3600 4s(8s total) location. When I put the 2 2650 4s, the lighter battery set is forward by 2 inches or more.
I think I'd start a lot more forward than that just to be safe. JMHO.
http://www.rcgroups.com/forums/attac...mentid=3618855
I agree. My 6s 5000 setup is about where it is in that pic. Maybe a bit more forward. Flys neutral inverted.
kwj48 is offline Find More Posts by kwj48
Old Jan 01, 2011, 05:52 AM
Advocating for RC Aviation
USA, NJ, Phillipsburg
Joined Jul 2010
Reminds me of the build last summer: I put the 6S 5000 where it looked to be in the picture too. The Slick balanced right away which was the fastest CG set-up of all my ARFs! I also marked another spot for a 6S 3900 but never flew that batt.
danamania is online now Find More Posts by danamania
Old Jan 01, 2011, 01:56 PM
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
It is a little scary that mine seems to balance perfectly where my 6S pack is positioned in the picture. I balanced it at 160mm right at the wing spar.
We are talking a good 3" if I moved it to the location that seems to be working for everyone else.
I guess there is only one way to find out. Looks like the weather will be good for a maiden tomorrow.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jan 01, 2011, 02:30 PM
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
The Slick, as well as most 3DHS planes, has a broad CG. As long are your equipments are where others put theirs, you'd be good to go .
BoneDoc is offline Find More Posts by BoneDoc
Old Jan 01, 2011, 07:20 PM
stickybeatz's Avatar
USA, AZ, Phoenix
Joined Apr 2010
Maidened the slick today! First time flying a big plane and first time flying a gasser. It was awesome! I need to mess with my throttle curve a bit. It seems like full power at about 40% throttle.
stickybeatz is offline Find More Posts by stickybeatz
Old Jan 01, 2011, 07:24 PM
You down with EPP?
Houston, Tx
Joined May 2009
Anyone using expo on the throttle?
IF so how much?
Old Jan 01, 2011, 07:42 PM
starzen's Avatar
USA, FL, Stuart
Joined Jul 2009
IF so how much?
not expo but throttle curves
mostly on gassers but even some electrics
the problem with throttle is that it isnt quite the same as surfaces. With control surfaces we want them a little softer around center and then allow us to use full deflection.
With the throttle you want to have the most resolution in the band that matters the most to you and sometimes you may need to cancel out some peculiar throttle response in certain areas
on my 57 i use a throttle curve pretty much only to tame the power. I would be hovering at about 1/3 throttle and i moved that to about 1/2 throttle stick
on my 87 the engine has a little sag at the beginning where it doesnt quite catch on which i skip with a curve and then use the curve the other way to even out throttle response (kind of an odd shaped inverted s)
starzen is offline Find More Posts by starzen
Old Jan 01, 2011, 08:20 PM
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
On throttle also, don't set your endpoint till you totally max out the carb at WOT and bind the servo arm. That kills your resolution. Set it to where it's just BARELY at WOT on full power.
Old Jan 01, 2011, 10:32 PM
Fort Worth, Texas
Joined Nov 2002
I was looking at this 70" Slick, or the EF 70" Extra for an powerplant I have laying around... but noticed that on 3dhs' site it list them as "not for sale". Does anyone know why?
Next, I am new to electric power, but dove head first into a 2m pattern plane and love it. The extra powerplant I have is a Plettenberg Extra 30-10 evo and a Ice HV 80. I am looking for an airfame that will be less than 11lbs. The motor is 550g, and will pull 1700w on a 20x10 on 10s, and can be propped to 3500w. I was checking batts and found 10s 3000 weights the same as 6s 5000. Could this powerplant suit this size plane well??
DBA-FW is offline Find More Posts by DBA-FW
Old Jan 01, 2011, 10:38 PM
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Kitty Hawk
Joined Oct 2007
The 70 slick is listed not for sale b/c its getting a new scheme and haveing a few tweeks done to it.
losifanatic is offline Find More Posts by losifanatic
Old Jan 01, 2011, 10:49 PM
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
That should work with a 10S 3000 to keep weight similar.
You can also put that to the 72" SC and it's be a perfect match as well.
Old Jan 01, 2011, 11:03 PM
Sippin the Koolaid!
Joined Oct 2007
Heck Im flying the 72SC with an 8s 5000mah set up and it 3d very well and is still very floaty. I am going to set up a 70 slick with a 8s 4000mah setup
Old Jan 02, 2011, 12:21 AM
You're good!
Safety Hawk's Avatar
United States, VA, White Stone
Joined Jun 2005
Originally Posted by stickybeatz View Post
They weren't in the box. Tyler shipped some out for me earlier this week.
I was just messing with ya.
Safety Hawk is offline Find More Posts by Safety Hawk
Old Jan 02, 2011, 12:26 AM
Fort Worth, Texas
Joined Nov 2002
Yea!!! (clapping to myself!!!) Any idea's on how far out??
Old Jan 02, 2011, 12:28 AM
Fort Worth, Texas
Joined Nov 2002
I was hoping this would be the case.
I am having a hard time loving the SC's color scheme....
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
