i had thought something was wrong too as mine did the same thing but i noticed that the voltage wasnt 5 but less and it kept changing too then i had an aha moment. it was actually off but the capacitors still had energy stored. So after you turn it off it can still run the ignition for a seconds or so. Without a load it can take a while for the voltage to go down. if you have a harbor freight get a cheap multimeter when you turn it on it should go to 5V and stay there. When you turn it off it should slowly drift down to 0 |
Ok, I have a plan for rebuilding the sides of the fuse but I need a little help.
I was looking over DPHOYE's 70" slick prototype rebuild and he made a photocopy of the fuse side and used that to help recreate a template to replace it. That seemed like a really good idea to me but I don't have enough left to determine the exact shape. I thought I could print out his picture of the finished template and then just scale it on the copy machine until I get it just the right size but then realized that if the camera was not exactly perpendicular to the piece then it won't be right. Does anyone have a 70" slick with the covering removed from the sides that could scan it for me? This was his post on that topic http://www.rcgroups.com/forums/report.php?p=12594327 Also, I'm open to any other suggestions. Also, I need some dimensions for that former just aft of the motorbox kit as well if anyone has a way to get that ![]() Craig |
Craig Hypersprint was using a piece of paper and charcoal to do a "rubbing" like they do over tombstones etc to trace shapes of trim schemes. I wonder if the same idea would work for the side of a fuse without having to remove the covering? I'll try it on my 70 and see if I can come up with something workable for you. If so I can just mail it to you.
MLT |
Thanks, Starzen. I'm gonna go pick one up tomorrow.
Got my engine mounted and the throttle servo and linkage set up. Man setting up a gasser is a PITA! Started messing around with my choke and can't really find a way to set it up without interfering with the throttle. I may just run a rod back into the fuse and set the choke on and off with the canopy off. I've never been a very good DIYer so I'm feeling way out of my element right now. couple of quick questions... 1. When I put the cowl on, the prop hub is about 1/8" closer to the right side of the hole (looking at the front of the cowl) than the left. I took the motor off and pressed the drill guide back on the firewall to double check that my holes are correct and they are. Is this normal? I'm using 1" standoffs with 2 1/10" washers from PSP to mount the motor. I've got about 1/8" clearance between the spinner back plate and the cowl so I'm pretty sure I got the right length. Maybe it's play in my bolts and I just need to hold it centered when I'm mounting the engine? Any tips? 2. How tight should I screw in the spark plug? 3. Do I need to mount the A123 pack on foam? I built a battery tray that goes over where the pull-pull servo would normally go. Thanks again for the help! |
the cowl is normal. the spakr plug not too tight. Good hand tight. I mounted my A123 packs on velcro only and a velcro strap |
Rob |
| Thread Tools | |
| Poll 3D hobby shop 51" slick or 55" SHP? | appleflyer | 3D Flying | 24 | Mar 24, 2009 06:29 PM |
| Video 3D Hobby Shop's AJ Slick | Clark Warfel | Electric Plane Talk | 3 | May 08, 2008 07:31 AM |
