Old Dec 17, 2010, 06:15 PM
Thomas Luttrell is offline
Find More Posts by Thomas Luttrell
Thomas Luttrell's Avatar
United States, MS, Southaven
Joined Sep 2004
I used the tint for RC cars any modle shop should have it. I would tell you exaclty but I am in Memphis, TN and my tint is in Japan but I believe it is Tamiya spray tent.
Thomas Luttrell is offline Find More Posts by Thomas Luttrell
Old Dec 18, 2010, 10:31 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Repair all done, it was a little breezy this morning so I opted to finish it instead of flying. Wind has been hairy around here this week.
Mainly just a little sanding, fixing the wheel pant hole in the wing(just broke some none load bearing balsa), and applied the while ultracote. The ultracote was pretty easy once I realized it had a backing that peeled away when I heated it. I've never bought it new.
All in all I'm pretty pleased, giving the flex test it seems strong. The splintered CF that I rubbed GG in and around is very stiff again, I'm sure the foam filled the inside.
If I get some time I will fly it tomorrow with the good set of batterys.
Anyway...some pics...
robj is offline Find More Posts by robj
Old Dec 18, 2010, 12:04 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Wow Rob. That is about as good as it gets. You are going to have to give me a lesson on repairing these big balsa planes one day. Let's hope that day is far off.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Dec 18, 2010, 04:13 PM
robj is offline
robj's Avatar
Joined Nov 2008
Let's hope not soon at all. I think the bigger are easier. Also it seems easier to remove the coating for room to work. I was lucky I only had to deal with the white color. And since I've never bought ultracote, it was only $16 for a large roll, I thought it would be more. And that old iron of mine does wonders!
BTW, did you get a castle link? Can I borrow? I really want to reset the settings and I haven't gotten mine yet. Planning on VP tomorrow but will be in the area today if you are flying? Also close to your house at a grad party. Otherwise if you are out there tomorrow I'll bring my laptop.
Call or text me.
Rob
Old Dec 18, 2010, 07:33 PM
hackdroot is offline
Find More Posts by hackdroot
hackdroot's Avatar
USA, CA, Oakley
Joined Aug 2008
I spent the day repairing my slick but have encountered one problem. The prop adapter no longer clears the cowl. Prior to the crash I was using some spare aluminum wheel collars as standoffs to clear the cowl, those were about 4mm in depth. Now, with the new motorbox installed, I'm short by about 7-8mm with the old collars installed and the same motor.
There were no repairs to the fuse itself since most of the damage was to the motorbox, and the old cowl presents the same depth problem, so the new cowl isn't to blame. I'm hoping this is something obvious I'm overlooking, but can't find any other possible explanation other than the motorbox depth is slightly shorter.
The distance from the end of the fuse to the forward end of the motorbox is approx 6 5/8" (167mm) and from the end of the fuse to the front of the firewall is ~6 3/8 (162mm). I have no idea what it was prior to the crash since most of the wreckage is in the trash.
Any ideas?
-Eric
hackdroot is offline Find More Posts by hackdroot
Old Dec 18, 2010, 07:47 PM
skippy78 is offline
Find More Posts by skippy78
skippy78's Avatar
USA, VA, Narrows
Joined Mar 2009
J
Any ideas?
-Eric
Pretty sure that the newer slicks have a shorter motor box so that the hacker 12l will fit. I would say that the new motor box is like the newer models. Just use some longer standoffs and it will be fine.
skippy78 is offline Find More Posts by skippy78
Old Dec 18, 2010, 08:28 PM
hackdroot's Avatar
USA, CA, Oakley
Joined Aug 2008
Originally Posted by skippy78 View Post
J
I was about to do exactly that, but wasn't sure about standing off the motor that much (11-12mm).
Old Dec 18, 2010, 08:35 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
no issues, go for it
rcbirk21 is offline Find More Posts by rcbirk21
Old Dec 18, 2010, 09:09 PM
robj is offline
robj's Avatar
Joined Nov 2008
Borrowed Johnnyoroccos castle link and got mine reset. From what I can tell it was set to auto lipo, 3.0 volts. So it would hit a HARD cut off at 24v (8s*3.0 volts).
So changed that, then the cut off to soft, then the log to 2 per second. Everything else was ok. Also cleared the log.
Here are some screen shots of what I have. Also is a pic of the way Eddie set up the ESC connector. I thought I was going to have to mess with it but not. He kept all 3 wires from the esc to another extension, but added a 3" extension at the very end..that plugs into the Rx, he removed the center wire from that. So when checking the software, just unhook that connector and plug it into the link. Very nice.
If yall spot anything I missed please jump in.
Rob
Old Dec 18, 2010, 09:12 PM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
Try the 72 SC's... the standoffs I'm using on that are 2.5"!
ryan_m is offline Find More Posts by ryan_m
Old Dec 18, 2010, 11:07 PM
twistedgrim is offline
Find More Posts by twistedgrim
twistedgrim's Avatar
San Antonio, TX
Joined Sep 2008
Rob
yea I taught him that rob It used to be a super clean plane Eddie was like some guys we know who if the plane got a ding in it he couldnt fly it anymore and just sell it. I think he went through 10 helis
twistedgrim is offline Find More Posts by twistedgrim
Old Dec 19, 2010, 03:54 PM
vienquach is offline
Find More Posts by vienquach
vienquach's Avatar
Chicago, IL
Joined Nov 2009
A50-16s, Blue Lipo 6s-4000-30c (4s + 2s), fresh charged
a) Turnigy 19 x 10, 89 A, 24.8 V --> 24.1 V (drop 0.7 V), 2145 w
b) Xoar 19 x 10, 92.5 A, 24.4 V --> 23.7 V (drop 0.7 V), 2192 w
c) Xoar 19 x 8, 80 A, 23.9 --> 21.9 V (drop 2.0 V), 1752 w
Temp: stator 127 F, rotor 109 F
Amp draws at 3/4 and max throttle were almost the same in all cases (max was about 2A lower).
Vien
vienquach is offline Find More Posts by vienquach
Old Dec 19, 2010, 03:57 PM
danamania is offline
Find More Posts by danamania
Advocating for RC Aviation
USA, NJ, Phillipsburg
Joined Jul 2010
Hi Vien, I'm flying your prop (a) above with good results. How do you like props (b) & (c)? Thanks! Dana
danamania is offline Find More Posts by danamania
Old Dec 19, 2010, 04:03 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
I was flying the same prop (a) with good result too (probably a tiny bit slow).
Just got the 19x10 this week, but freezing outside, .... should give you a bit more speed and thrust, just my guess.
Vien
Old Dec 19, 2010, 07:00 PM
robj is offline
robj's Avatar
Joined Nov 2008
Rascal...not me, I do care about how it looks but also how/if it'll fly!! Considering what happened, I think it looks pretty good.
A couple shots from the Castle Ice from this afternoon. It flys as good as ever!!
Rob
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
