Old Dec 16, 2010, 11:26 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Originally Posted by robj View Post
Well I bougnt mine used, didn't see a card and I'll have to see if I have the little connector for the bec, looks like I can make one of those if needed.
Rob
Just call Castle. They sent me a free castle link USB when I bought my first Ice 100 used. My other two were bought new and they come with a coupon for the USB adaptor.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Dec 16, 2010, 11:27 AM
You down with EPP?
Houston, Tx
Joined May 2009
BTW, can anyone share their Ice 100 settings for a 6S setup on the SLick?
Wondering what to set my LVC at as well as a few other points.
Old Dec 16, 2010, 11:38 AM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
a lot of the setup depends on your motor. i put my LVC as low as possible
rcbirk21 is offline Find More Posts by rcbirk21
Old Dec 16, 2010, 11:41 AM
You down with EPP?
Houston, Tx
Joined May 2009
I'm going to go with the Motrolfly 4325-380
Old Dec 16, 2010, 12:08 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
I set my LVC to way lower than the motor will turn,that way I have a chance to feel the motor lose a bit of power so I can land versus getting caught in a hover or something "plane killing without power" if the LVC kicks in.Id rather kill a battery than a plane.
P.S. perfect motor choice.
Manta1 is offline Find More Posts by Manta1
Old Dec 16, 2010, 12:37 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
You bet! Hopefully folks will check theirs, not good to loose all power. Actually it sucks!
robj is offline Find More Posts by robj
Old Dec 16, 2010, 12:58 PM
You down with EPP?
Houston, Tx
Joined May 2009
That's probably how I lost my Osiris. I set my LVC high on accident. Didn't notice until afterwards when I was changing the settings in my Ice 100.
Old Dec 16, 2010, 01:26 PM
robj is offline
robj's Avatar
Joined Nov 2008
That and a timer!!
Old Dec 16, 2010, 01:58 PM
Safety Hawk is offline
Find More Posts by Safety Hawk
Here We Go!
Safety Hawk's Avatar
United States, VA, White Stone
Joined Jun 2005
Originally Posted by losifanatic View Post
If we get a nice warm weekend I might have to ride up your way to fly with you again! I will have the 72 and 42 with me
I'm down for that! Of course that might be a little while.
Safety Hawk is offline Find More Posts by Safety Hawk
Old Dec 16, 2010, 02:27 PM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
ESC settings -
low timing, pwm of 8. LVC I set to 4.0 volts. Not 4/cell, but 4. Like Manta said, feel the power drop rather than lose the plane. Castle idea of soft cut and mine are drastically different... theirs is not enough to fly the plane on! So I avoid it.
I set my motor start power to ~75, and throttle response to about 3/4 of the way to the top of the scale. But those two are personal preference. I also adjust logging to 2 samples/sec and only record watts/amps/volts/temp. Read issues of knocking with logging at default settings.
And robj - regarding logging, default is logging turned on. At 5 samples/sec and all data points monitored. It only records something like 30-40 mins of flights at these settings, and once the log buffer is full it stops recording anything. So if you haven't been clearing the buffer most likely there was no log data to view for the last flight. Unfortunately it doesn't clear the buffer and keep logging, it just stops when full.
ryan_m is offline Find More Posts by ryan_m
Old Dec 16, 2010, 02:34 PM
You down with EPP?
Houston, Tx
Joined May 2009
Quote "Not 4/cell, but 4."
So in other words, NO LVC. 4.0 Volts
Old Dec 16, 2010, 02:41 PM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
yessir. that means the pack would have to be all the way down to 4 total volts (<1.0 v per cell), which means it wont kick in
last time i checked the castle link software doesnt allow you to completely disable the LVC, so most of us just put it as far down as possible
Old Dec 16, 2010, 02:56 PM
You down with EPP?
Houston, Tx
Joined May 2009
Got it. It makes sense. I would rather lose a pack.
...and Robby, I did have my timer set btw, in fact it had just gone off and I was circling around to make my approach when it died. Not much you can do when you are caught down wind and your club field that you pay to fly at has you flying over 8' pine trees.
Seriously, to thoughs in Cyber land, our club is like a beautiful runway in the middle of an active volcano.
I'll take it easy on you since you just had a mishap with your Slick
Old Dec 16, 2010, 03:12 PM
robj is offline
robj's Avatar
Joined Nov 2008
It's cool, mishaps happen. We all know that right. I haven't worked on the 70 since the other night, been in Lake Charles for 2 days. Hopefully some time to put the coting on before Saturday if I can make it out.
And it's IE.not a Y...Robbie!
Old Dec 16, 2010, 08:27 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Originally Posted by Thomas Luttrell View Post
Saw this the other day at the toy store and thought it would look good in the 70" Gas Slick. His facial expressions say it all. Now I just need to finish reparing it ang git it back into the air.
How'd you tint that canopy....?
Bivens is offline Find More Posts by Bivens
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
