Old Dec 02, 2010, 01:42 PM
Randidly is offline
Find More Posts by Randidly
Righteous 87
Randidly's Avatar
United States, FL, Port St Lucie
Joined Jun 2009
Originally Posted by Irg View Post
I'm a 6s guy myself...
But I recently saw that HK is selling single 8s packs...I have plenty of 18x10 props so I'm considering snagging an 8s for my 72SC.
I seen that.
What do you do for a charger?
Randidly is offline Find More Posts by Randidly
Old Dec 02, 2010, 01:57 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
Originally Posted by Randidly View Post
I seen that.
i dunno about IRG, but i use this, its the be all end all of chargers
and IRG, dont do it! for when you get the 89 slick and want instantaneous throttle response and no mess, youll love 6s!!!!
rcbirk21 is offline Find More Posts by rcbirk21
Old Dec 02, 2010, 02:20 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
I seen that.
10S charger like the iCharger 1010b+
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Dec 02, 2010, 02:21 PM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
(...or the 3010b )
Old Dec 02, 2010, 02:42 PM
weaser42 is online now
Find More Posts by weaser42
House of Paine
weaser42's Avatar
United States, AZ, Gilbert
Joined May 2007
+1 on both the 3010b and 1010b, I love those chargers. The 3010b on a pair of feathermerchant power supplies in series and some || charging cables is like having a time machine
weaser42 is online now Find More Posts by weaser42
Old Dec 02, 2010, 03:09 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Originally Posted by vienquach View Post
Do you guys really see much different between a 9.2 lbs and a 9.8 lbs Slick ?
Mine with A50-16s and 6s-4000, AUW is 9.2 lbs. Probably wanna try an 8s-3800 setup later with A50-14L.
Vien
I have flown both 6s4900's and 6s4000's in my 70 (today even)....it is light...weighs under 9lb with the light pack....just over 9lb with the 4900......I like the 4000's better.....you can for sure feel the lighter-floatier feeling with only 4 or 5 ounces less......not that the 9.8 is bad.....but lighter will for sure feel better.
Bivens is offline Find More Posts by Bivens
Old Dec 02, 2010, 03:15 PM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
Originally Posted by rcbirk21 View Post
the key thing is that it would be an 8s setup, instead of a 6s setup. so basically you can remember the age old watts = amps x volts
for the same watts, a higher voltage means less amperage. so really you are pulling a lot less amps with the extra 2 cells in the setup, therefore using the 3300 mah more slowly, which should give you about the same flight times (i think it was decided that 8s3300 is roughly equal to 6s5000 in flight time, i may be wrong on that one)
For example....I've got a 6s2200 setup in my 57SC....I fly 8 minutes.....same as others fly on 4s4000's.....MUCH lower amp draw.....and lower amp draw = less heat and wasted energy = more efficiency.
However....I run 6s4000's in my 70 slick....for 7:30 flight times.
Old Dec 02, 2010, 03:25 PM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
+a million. being able to charge 6x 6s5000 packs in an hour through a wall socket is fantastic.
Old Dec 02, 2010, 03:33 PM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
Well I just took the plunge and ordered a motor box, cowl and canopy to try and fix mine. Nosed it in a week or so ago when my thumbs and brain got confused while inverted.
Not looking forward to the motor box repair, but everybody says it isn't bad. We'll see!
ryan_m is offline Find More Posts by ryan_m
Old Dec 02, 2010, 03:42 PM
Safety Hawk is offline
Find More Posts by Safety Hawk
Here We Go!
Safety Hawk's Avatar
United States, VA, White Stone
Joined Jun 2005
It isn't that bad. I even managed to do it. Check out my blog for proof.
Safety Hawk is offline Find More Posts by Safety Hawk
Old Dec 02, 2010, 04:23 PM
vienquach is online now
Find More Posts by vienquach
vienquach's Avatar
Chicago, IL
Joined Nov 2009
I think I'll keep my light weight 6s-3800/4000 setup for now.
vienquach is online now Find More Posts by vienquach
Old Dec 02, 2010, 05:57 PM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
EXCELLENT choice.....
Old Dec 02, 2010, 06:05 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Not sure what to do with my 4s-4000 and 6s-4000 packs in the winter months.
Should I discharge them to 3.8-4.0 V for long time storage?
Vien
Old Dec 02, 2010, 06:06 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Not sure what I should do with my 4s-4000 and 6s-4000 packs in the winter months.
Vien
fly them!!
Manta1 is offline Find More Posts by Manta1
Old Dec 02, 2010, 06:08 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Originally Posted by Manta1 View Post
fly them!!
in sub 20F weather ?
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
