Old Dec 02, 2010, 08:17 AM
Team 3DHS
ctunder77's Avatar
USA, DE, Newark
Joined Jul 2008
Originally Posted by vienquach View Post
Do you guys really see much different between a 9.2 lbs and a 9.8 lbs Slick ?
Mine with A50-16s and 6s-4000, AUW is 9.2 lbs. Probably wanna try an 8s-3800 setup later with A50-14L.
Vien
There is no appreciable difference just slightly different post stall characteristics. Dont worry about it just enjoy the extra power from 8s
ctunder77 is offline Find More Posts by ctunder77
Old Dec 02, 2010, 08:42 AM
Artillery! King of Battle!
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
I love my 8S Slick and by using 2 4S 4000 Hyperion 25C packs, I'm not that much heavier than a 6S 5000 setup. The Hyperion are light packs.
Brill 1 is offline Find More Posts by Brill 1
Old Dec 02, 2010, 09:28 AM
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Which one would be the most efficient?
http://www.gravesrc.com/XOAR_ELECTRI.../xor1910ew.htm
http://www.gravesrc.com/XOAR_BEECHWO...p/xor1910b.htm
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Dec 02, 2010, 09:52 AM
Barefoot Birkinsomething
rcbirk21's Avatar
United States, KS, Overland Park
Joined Aug 2004
Originally Posted by johnnyrocco123 View Post
is it for a gas motor or electric motor? if electric...get the e prop. if not, get the other
rcbirk21 is online now Find More Posts by rcbirk21
Latest blog entry: Transmitt
Old Dec 02, 2010, 10:02 AM
twistedgrim's Avatar
San Antonio, TX
Joined Sep 2008
Vien
I saw quite a bit of difference with my 68 Velox on 6s 3000 compared to 6s 5000. The 3000 really made it lighter and pulled out of a hover quite a bit quicker. You can ask everyone who was at TEFF about my light Velox hucking
twistedgrim is offline Find More Posts by twistedgrim
Old Dec 02, 2010, 11:29 AM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
At 9.2 lbs, the Slick flies really good. I mean it.
8s-3300 Slick would be the best for 8s setup (9.5 lbs), but I already invested too much in 2s + 4s +6s-3800 25c, and 2s+4s-4000 30c packs.
Will see, maybe I'll get another Slick with an 8s power system. I got room in my room
It is really annoying that batteries from Hobbypartz weigh 1-2 oz heavier than their listed spec.
vienquach is offline Find More Posts by vienquach
Old Dec 02, 2010, 11:35 AM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
You're right, but there's a half pound difference between 8s-4000 (8s setup on my SC) and 6s-4000 (I am flying at), and that is noticeable.
SC (9.8lbs) vs. Slick (9.2 lbs). 2s-4000 + 2oz extra motor weight = the difference in weight.
My 2 airframes weigh almost the same. The Slick has heavier wings (34 oz vs. 30oz), whereas the SC has heavier fuse (99 oz vs. 92 oz)
Vien
Old Dec 02, 2010, 12:10 PM
You down with EPP?
Houston, Tx
Joined May 2009
How would you get any more than 3-4 minutes of flight time out of 3300mah? Or are you only getting 4 mins?
Old Dec 02, 2010, 12:13 PM
rcbirk21's Avatar
Joined Aug 2004
the key thing is that it would be an 8s setup, instead of a 6s setup. so basically you can remember the age old watts = amps x volts
for the same watts, a higher voltage means less amperage. so really you are pulling a lot less amps with the extra 2 cells in the setup, therefore using the 3300 mah more slowly, which should give you about the same flight times (i think it was decided that 8s3300 is roughly equal to 6s5000 in flight time, i may be wrong on that one)
Old Dec 02, 2010, 12:16 PM
You down with EPP?
Houston, Tx
Joined May 2009
I was figuring about 70 amps on 8S. I believe that would still be shorter flight times than a 6S 5000mah.
If I had a "charge station" I could see the benefit, but I have one 150w Charger that charges one pack at a time. So...... I will go with one 6S pack
Old Dec 02, 2010, 12:28 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
6s-4000, I got about 5-6 min of flight time (with A50-16s). I was gentle with the throttle on the maiden flight. After 4 mins, I only use 40% of the pack.
8s-3300, about the same flight time with the A50-14L. IMO
Old Dec 02, 2010, 12:31 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
+1.
I believe 8s-3300 is about 6s-4400, and 6s-5000 is about 8s-3750
Vien
Old Dec 02, 2010, 12:37 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Unfortunatly, there's no charging station at my local field, and it's so cold to charge. 20-30 F
If I did it again, I'd spend my lipo money on 4s-3300 25c-30c packs.
8s setup for Slick 70" and SC 72, and ultra light setup for SC 57". But too late.
Now I have
3s-3000/4400-20c vs. 4s-2200 25c for Slick 51"
4s-3800/4000-30c vs. 6s-2200 25c for Slick 59" / SC 57"
6s-3800/4000-30c for Slick 70"
8s-3800/4000-30c for SC 72"
Seem to be a mess.
Old Dec 02, 2010, 01:22 PM
rcbirk21's Avatar
Joined Aug 2004
+1.
Vien
i stand corrected
i knew it was something around there...im no 8s expert....6s is too perfect
Old Dec 02, 2010, 01:36 PM
Irg
ol' yellow eyes is back
Irg's Avatar
Brooklyn, NY
Joined Apr 2009
I'm a 6s guy myself...
But I recently saw that HK is selling single 8s packs...I have plenty of 18x10 props so I'm considering snagging an 8s for my 72SC.
Irg is offline Find More Posts by Irg
Latest blog entry: laser repair
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
