Old Oct 26, 2010, 06:18 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
man....those mejzlik's are tough to find
rcbirk21 is offline Find More Posts by rcbirk21
Old Oct 26, 2010, 06:24 PM
fltekdiver is offline
Find More Posts by fltekdiver
United States, FL, Melbourne
Joined Jan 2010
Originally Posted by MLT67 View Post
Well I called DA today and they are out of both 20x11e and 18x8e and get this - it will be 6 to 8 weeks before they get them back in stock. Guess it will be Xoar for now.
MLT
You gotta be freaking kidding me ! I was going to order the 20x11e this Friday when i got paid
Thanks for the update, I guess Xoar for now
fltekdiver is offline Find More Posts by fltekdiver
Old Oct 26, 2010, 06:48 PM
refugeefromcalif is offline
Find More Posts by refugeefromcalif
May the Farce be with you...
refugeefromcalif's Avatar
Duncanville, Alabama. USA
Joined Dec 2006
Originally Posted by vienquach View Post
I just sprayed two thin coats of Rust Oleum paint (very light and strong paint). I should check the weight when I paint another prop tonight. All my large APCs now are black. lolz
What about trying a Sharpie for color?
Never tried it myself but, Multiple coats might lighter then paint.?
George
refugeefromcalif is offline Find More Posts by refugeefromcalif
Old Oct 26, 2010, 07:22 PM
G.P. is offline
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Rit dye. Makes them totally black, weighs nothing, doesn't come off, and is cheap and easy to do. The down side is that you can't see the prop when it's turning.
G.P. is offline Find More Posts by G.P.
Old Oct 26, 2010, 07:37 PM
vienquach is offline
Find More Posts by vienquach
vienquach's Avatar
Chicago, IL
Joined Nov 2009
George
Spraying works better for me. Making the prop look good using Sharpie seems a bit difficult for me.
APC 18 x 10 E, before painting m = 62.5 g .... after 2 thin layers of semi gloss spray paint m = 62.9 g - 63.0 g. The weight difference is less than (1g) and very hard to tell.
Vien
vienquach is offline Find More Posts by vienquach
Old Oct 26, 2010, 07:38 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Mejzlik and Xoar now are difficult to find. Can we buy directly from Xoar international? Order like 50 or 100 of them then we can share.
Old Oct 27, 2010, 01:31 PM
banana hobby is offline
Find More Posts by banana hobby
banana hobby's Avatar
United States, CA
Joined May 2008
Come to California in January for the AMA Convention! I am loading up on props there! I always do!
Regards,
Pete
banana hobby is offline Find More Posts by banana hobby
Site Sponsor
Old Oct 27, 2010, 02:46 PM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
Xoar props are easy to find. Xoar 19x10 are not. I think there hasn't been much demand for them, so they only make them occasionally when they get enough requests maybe. They didn't even list that as a size they made when I last checked on their website. But clearly they do, or have, since I have a couple sitting in my garage!
ryan_m is offline Find More Posts by ryan_m
Old Oct 27, 2010, 02:52 PM
MLT67 is offline
Find More Posts by MLT67
Joined Nov 2005
I just ordred 2 18x10's and 2 19x10's from Bob's Hobby in Orlando FL. Said they had plenty in stock so I went ahead and ordered two of each so I'll have a spare.
MLT
MLT67 is offline Find More Posts by MLT67
Old Oct 27, 2010, 03:04 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Someone ran into a weird problem with the size of the center hole on some of the xoar props a while back. Anyone remember what the resolution was to that? I think it was in this thread.
cmala is offline Find More Posts by cmala
Old Oct 27, 2010, 03:06 PM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Originally Posted by RC4x4 View Post
I usually get all my Xoar's from Chief Aircraft. I talked to them to see what size hole was drilled in the center and it was 10mm. Not sure why they did that when usually all the 14 and 15 inch prop holes are around 5-6mm?
I got the 18x8 from Abell RC. They did not have 18x10, only 18x13.
Joe used a piece of Carbon fiber wing tubing to shim the 18x10 he has so it would fit on the 8mm prop shaft. I ordered a 18x10 Turnigy to try also.
Between me and Joe we should have some good numbers by this weekend.
The 18x10 Xoar's are hard to find.
Cory
I guess it was about a year ago. November 2009
Old Oct 27, 2010, 03:20 PM
weaser42 is offline
Find More Posts by weaser42
House of Paine
weaser42's Avatar
United States, AZ, Gilbert
Joined May 2007
The Xoar 18x10 I got about a year ago had 10mm holes which were too big for the prop adapter. I found a nylon spacer at a hardware store with a 10mm od and was able to ream it out to 8mm id and use between the prop and shaft with no problem. Those I've gotten recently were either 8mm or smaller so no adapter was needed.
weaser42 is offline Find More Posts by weaser42
Old Oct 27, 2010, 03:24 PM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
maybe that 10mm hole thing was just a one time slip then.....
Old Oct 27, 2010, 04:03 PM
CFisher1421 is offline
Find More Posts by CFisher1421
CFisher1421's Avatar
Geneva, IL
Joined Jul 2007
George
I sanded mine...grey primed...applied some 3M 777 to some drywall tape...stuck it down to follow the curves on all "4" sides...sprayed a light coat of black...let it dry...pulled the drywall tape off, leaving a nice checkerboard pattern...wet sanded with 800 (I think) very lightly...sprayed a few layers of gloss on top of all that.
Yes, I added a few pounds of paint...but I haven't noticed. I wonder if the masking would hold up to the Rit dye???
Seriously...it took me longer to type this than it did to prep the prop. It looks pretty convincing too. (Sorry I'm at work...no pictures!)
CFisher1421 is offline Find More Posts by CFisher1421
Old Oct 27, 2010, 04:15 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Regards,
Pete
It's cheaper for me to buy 50 Xoars than coming to California to get the props. Drove there last summer, was fun, 7000-mile trip.
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
