Old Sep 26, 2010, 11:13 PM
Safety Hawk is offline
Find More Posts by Safety Hawk
Here We Go!
Safety Hawk's Avatar
United States, VA, White Stone
Joined Jun 2005
Yes.....it does come with the LG plate.
Check this out: http://www.rcgroups.com/forums/showthread.php?t=1309123
Safety Hawk is offline Find More Posts by Safety Hawk
Old Sep 26, 2010, 11:35 PM
bobunobu is offline
Find More Posts by bobunobu
bobunobu's Avatar
Yokosuka, Japan
Looks alot like the damage to mine. Gives me hope that I can repair it. Now if Rob has the kit in stock, I should be good to go.
Bob
bobunobu is offline Find More Posts by bobunobu
Old Sep 26, 2010, 11:55 PM
Zimm98 is offline
Find More Posts by Zimm98
Zimm98's Avatar
USA, SD, Rapid City
Well today I put the slick in from about 5' wing tip first, it hit fairly hard. I walked up no apparent damage, look inside just a couple of cracked formers. I can't believe how tough this plane is many others would of had the wing through the side of the fuse. It has quickly become my favorite, but I wish they sold them in pairs its WAY to easy to get stupid with it.
Zimm98 is offline Find More Posts by Zimm98
Old Sep 27, 2010, 12:01 AM
Here We Go!
Joined Jun 2005
Originally Posted by bobunobu View Post
Bob
Mine is about in the same condition. Just waiting one some parts and then I'll be putting it back together.
Old Sep 27, 2010, 12:37 AM
SEAL is offline
Find More Posts by SEAL
I'm all for global warming
SEAL's Avatar
Yokosuka, Japan
Joined Nov 2009
Originally Posted by Thomas Luttrell View Post
Toady was the maidend of my gas Slick went very well only had two problems; busted wheel hub and the CF spar under canopy magnets came loose other than that it was a great flight. Just took a few turns one the high needle getting 7400 with 19x8 Xoar and low turned for good throttle transition, this is the first run up of the motor and it flew great and no dead sticks on the DLE 30 or quitting after landing. I must confess I did remove the stock ring and install a Bowman ring instead no burbling like my buddies DLE 30 know I will have to adjust it as she breaks in will post some pictures of my setup later.
There was a mishap with another 70 Slick at the field Bob lost power with his electric and busted the landing gear out hated to see that because it used to be my Slick.
Bad break on Bob's Slick yesterday (Used to be my Slick too). Looks really fixable though.
SEAL is offline Find More Posts by SEAL
Old Sep 27, 2010, 12:42 AM
SEAL is offline
SEAL's Avatar
Yokosuka, Japan
Joined Nov 2009
[QUOTE=Thomas Luttrell;16144466]Toady was the maidend of my gas Slick went very well only had two problems; busted wheel hub and the CF spar under canopy magnets came loose other than that it was a great flight. [QUOTE]
Good flying yesterday Tom!
Old Sep 27, 2010, 08:29 AM
Randidly is offline
Find More Posts by Randidly
Righteous 87
Randidly's Avatar
United States, FL, Port St Lucie
Joined Jun 2009
Flew my Slick yesterday several more time I guess I have about 20 flights on her. anyway on my last landing, right at touch down I seen a big puff of dirt come up, guess I hit a ant mound I noticed it tore one of the wheel pants no biggie, when I get it home and start looking at I noticed it cracked the landing gear mount, easily fixable. Do you guys do the gorilla glue thing in the landing gear area, I didn't do it, I'm thinking I might ought to.
Randidly is offline Find More Posts by Randidly
Old Sep 27, 2010, 08:32 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
gorrilla glue in the lg plate=good
Manta1 is offline Find More Posts by Manta1
Old Sep 27, 2010, 08:59 AM
CFisher1421 is offline
Find More Posts by CFisher1421
CFisher1421's Avatar
Geneva, IL
Joined Jul 2007
As my buds will attest...there's almost nowhere Gorilla glue *isn't* good...
CFisher1421 is offline Find More Posts by CFisher1421
Old Sep 27, 2010, 09:13 AM
Randidly is offline
Righteous 87
Randidly's Avatar
Joined Jun 2009
On that note are there any other areas on the 70" that you guys who have been flying it for a while think needs to be beefed up for hard flying?
I also had one of my canopy dowels fall out I replaced it with a piece of carbon fiber.
Old Sep 27, 2010, 09:18 AM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Canopy dowels fell out of my 70" slick and my 103" Extra.
Both of the ones in my Extra fell out and I didn't even notice it till after at least several flights. Good thing the cowl overlaps the canopy on the Extra.
I didn't have any dowels but I had a new dremel tool and a 1/2" hardwood stick so I shaped some with a sanding wheel. I think it worked out pretty well because it left a flange on the back side of the "dowel"
cmala is offline Find More Posts by cmala
Old Sep 27, 2010, 09:46 AM
GoldCraft is offline
Find More Posts by GoldCraft
GoldCraft's Avatar
United States, GA, Woodstock
Joined Jan 2007
I used some CA on mine when they came out and they came out again...used epoxy the next time and they havnt came out since.
GoldCraft is offline Find More Posts by GoldCraft
Old Sep 27, 2010, 09:53 AM
Lonelasso is offline
Find More Posts by Lonelasso
Lonelasso's Avatar
United States, TX, Austin
Joined Dec 2006
I used 22 cal. brass (minus the round of course )
Lonelasso is offline Find More Posts by Lonelasso
Old Sep 27, 2010, 09:56 AM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
carbon fiber rod here when mine came out
Old Sep 27, 2010, 10:16 AM
GoldCraft's Avatar
Joined Jan 2007
Why does that not surprise me
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
